I tried to use the RFSwitches Plugin from https://www.domoticz.com/wiki/Plugins/RFSwitches.
Now i´m stuck at point 5.
5. ENABLE THE PLUGIN
Restart Domoticz, and under 'hardware' enable the RFSwitches plugin.
If you use different receive (rx) and transmit (tx) pins, enter the pin numbers here.
Restart Domoticz again, and now the plugin is active.
Other Python Scripts works without problems.
