Door phone and camera
Gleneroo
Post by Gleneroo »
Hello forum
I am looking for a door phone (Domoticz-capable of course) and also cameras for checking and recording outside the house. My first idea was to put them just under the roof, at the 4 corners of the house.
I was looking at Dahua for the door phone (VTO2000A + screen VTH + VTNS for POE) because it seems we can receive calls also on smartphones, so naturally also Dahua for cameras. If I understood correctly, this would allow to show camera on the door phone screen.
Ultimately (but that's a bit too far), ideal scenario would be to have this screen showing as well Domoticz dashboard ! But I don't know if this is reasonably possible. I would like it stable, not something we have to troubleshoot every two weeks because something changed somewhere... So I am doubtful it is possible, so just the Dahua solution (if I understood correctly how it is supposed to work) would be a good first step.
There are so many types of cameras that I don't know which one to pick.
Any help on this or indication of simple material resource would be helpful, as long as it is understandable. I don't even know the technical vocabulary.
Basically I want to see and record my garden, cameras moving, ability to record and notify if something happens...
Instinctively, I was more attracted to dome cameras because we cannot see where they are looking...
But I don't know much on the subject.
Everywhere I read, feedbacks seem generally quite positive about Dahua. The thing then is to pick the right model I need.
Thanks in advance for any feedback...
Justintime
Re: Door phone and camera
Post by Justintime »
Funny nobody replied to your topic.....
Or no one knows if and what type is possible or they find it a stupid question because it is not possible.
I guess it's the last one....
I found it strange because there are camera's with an external chime which sends 433mhz so it could be regonizable by RFXCom?
I am in the same boat.... Just want a message from domoticz with a snapshot from a doorbell camera.
hoeby
Domoticz version: V2022.1
Post by hoeby »
i using a normal doorbell which is connected to domoticz. it triggers a script that takes a snapshot of the camera that is mounted near the frontdoor and sends it whit telegram.
the reason het doing it with the script. is that i can die camera's which are bot support by domoticz. the camera must me able to give a stream/snapshot by http or https string
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
