Amount of levels of a Scene group
gschmidt
Post by gschmidt »
Does a Scene group have a max. amount of levels?
A Yamaha plugin has created a switch with 20 different DSP programs...they all work when selecting levels of the Switch.
However when a Scene group is created in domoticz, and this switch is added, the max. amount of working levels appear to be 10 (100%), so level 110% also selects the same DSP program which is located at position 100%, and not the the 11th. Level 120% also selects the same...so it look like the max. amount of levels in a Scene group is 10...
Can somebody confirm this? And is there a workaround?
Greetzzz,
Gerben
Re: Amount of levels of a Scene group
Last time I checked there was still this restriction. Work around options are very much depending on what needs to be achieved.
I suggest to create an issue for this on the GIT issue page of the Yamaha plugin.
gschmidt
Post by gschmidt »
Ok thanx, I'll figure out a workaround.
