Find My iPhone implementation in LUA script
Irmin
Re: Find My iPhone implementation in LUA script
I tried it with a script with just the curl and the output just gives a nil. 1 thing I noticed that I dont even get a error if I use wrong username or password.
If you can make a script whenever you have time please do so.
- Egregius
- Domoticz version: v2024.7
Apple changed something in their ssl. I had to add a option to disable the ssl check to get it working again in my php script.
landaisbenj
- Domoticz version: stable
I try tomorrow or in 1 week
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
JohnBoy32
Hi Egregius,Egregius wrote: Friday 03 August 2018 21:28 Apple changed something in their ssl. I had to add a option to disable the ssl check to get it working again in my php script.
Can you give me a clue how to disable the SSL-check in the PHP script?
And on me search for a solution I walked into this solution for java: https://community.openhab.org/t/icloud- ... blem/48314
Maybe it's an option to add the certificate instead of disabling the SSL-check? What is your opinion on this? And do you foresee this is possible for our application?
Thanks in advance for your help!
- Egregius
This is the php script I use, the solution is mentioned in this issue https://github.com/albeebe/PHP-FindMyiPhone/issues/16
Nautilus
I changed to pyicloud (https://github.com/picklepete/pyicloud), a lot of additional functionalities implemented in this library...
Irmin
I still do not have it working, can some help?
MarceldeJongNL
- Domoticz version: 3.5108
I just added -k to every curl statement in the lua, and it works again
Hardware: Raspberry Pi 2B | RFXCOM RFXtrx433E v1 | Synology DS213+ | KaKu Clones | Conrad RSL switches | KAKu Doorbell Clone | USB Webcam | ICY Thermostat | Resol DL2 | Imatic Relay Board | Eminent 6230 | Eminent 6220 | iMatic 16 ports Relay Board
Irmin
That did the trick, thanks!MarceldeJongNL wrote: Friday 10 August 2018 8:34 I just added -k to every curl statement in the lua, and it works again
Hempie
Were in the line(s) will i add this -k
RFXTRX433E, Aeon Z-Stick Gen 5, Harmony Hub, Nefit Easy, Homebridge, Somfy RTS, Fibaro
landaisbenj
stage1command = "curl -sk -X POST
stage2command = "curl -sk -X POSTPlatforme: Rpbi3b
Hempie
Thank You...
niwreg
Anyway in this thread
https://community.openhab.org/t/icloud- ... m/48314/28
they extract the key and signed the certificate with the apple root CA
So if we use that as trusted CA (maybe trick Curl into to that) the ssl should work again
ropske
- Domoticz version: V3_8394
is this still working for you guys?
Mine is not updated anymore for a month
Hempie
Mine also not working, any other script that will do the job?
Superpjeter
Mine works like a charm
Hempie
Do u mind sharing your script? (without your credentials ofcourse)
krizzz
I am curious alsoHempie wrote: Tuesday 25 December 2018 16:24Do u mind sharing your script? (without your credentials ofcourse)![]()
Superpjeter
I only skipped the google maps position name because that is not working anymore
Still interested in the script, just let me know
Marcvdp
I’m also interested in your script! Thank you in advance for sharing!
