There seems to be some different zigbee controllers out There, but which one is the best and easiest to set up and use?
Is There anyone that has full support in domoticz yet?
Best zigbee stick for domoticz?
Re: Best zigbee stick for domoticz?
I use "zigate"
Ok, does zigate have full support in domoticz?
- Target OS: -
Yes, like others, if by full support you mean your ikea+philips color bulbs, I can confirm all have "full support".
compatible with Phillips hue , ikea, xiaomi (aqara ,switch ,temp,motion ,cube,doors Switch etc...) and others.
full list :
https://zigate.fr/le-materiel-compatible-zigate/
full list :
The plugin is currently under development of new features like Group management. Of course you can use group from Domoticz but then the implementation will manage each single element of the group. While a native group management will be much more efficient.
Wiki is available here.
Zigbee for Domoticz FAQ
On my side, I m using the deconz framework with a conbee, I used it on another application before and I realy think nothing is missing, and now with a domoticz plugin.
https://github.com/Smanar/Domoticz-deCONZ.
^^, make your choice.
