Controlicz - Easy Domoticz to Alexa Integration Topic is solved
hayman
- Domoticz version: 3.8153
Re: Controlicz - Easy Domoticz to Alexa Integration
Colors.works good ,but from Coolwhite to Warmwhite to daylight got frozen at Warmwhite with Alexa ,
Madgeni
ah ok - will fix as priority
tlkg
- Domoticz version: 2021.1
Is the Amazon Contact and Motion Sensor APIs and integration for Alexa routines fully implemented or planned in Controlicz?
When creating an Alexa routine using the "When this happens" -> voice it seems to work ok controlling known devices, however if you try and use "When this Happens" -> Device, it just displays "We were unable to find and supported devices."
Using the "Device" for the "When this happens" you can have Alexa say something based on the state change of the device. For example a door sensor when open could be set to have Alex say "Front door is open".
Madgeni
hi tlkg
i am looking to implement this - the challenge is less around the Contact & Motion Sensor API, than it is in getting Domoticz to proactively report to Controlicz in a simple and secure way. It's on the roadmap for sure
- BazsoDombiAndras
- Domoticz version: v4.10717
Hello Everybody!
Tried to set up a new Domoticz server with Controlicz today. On the Controlicz website all my devices are shown. But Alexa finds none. Any idea what could be wrong?
Madgeni
Hi there - make sure you have a subscription
- BazsoDombiAndras
Yeah.. I thought that you get something for free and you only have to pay for extras. But it seems you get nothing for free. I've deleted my account.
Madgeni
fair enough
hayman
please still have the problem with the Warmwhite and coolwhite (milight rgbcct) alexa
skybehind
Please don't make this a priority, because it's really not, but did you ever figure out how to have Alexa respond with Fahrenheit values? So when I ask what the upstairs temperature is, Alexa will respond with 161 degress, the Celcius equivalent of the temperature, which is 72 Fahrenheit.
Madgeni
Hi -
Will add it to the list
tristanp
- Domoticz version: 4.10215
I am having problems with a setpoint device.
The current (set) temperature is displayed, but I cannot change the value.
The switches are greyed out, and status is reported as "other"
please see screenshot attached.
what am I doing wrong?
Pandabeer
- Domoticz version: 10265
Hi TriStanp,
I face the same 'problem' but if you say to Google Assistant / Home 'zet verwarming in ruimte x op y graden' seems to work
So control with voice works but as interface on mobile it doesn't work at this moment ?
Little expert running Domoticz on a Raspberry Pi
Toon Thermostat | Mi-Light | Z-Wave Thermostat valves and CO2 / fire detection units | KiKa | Heat-IT Zwave thermostat |-
Madgeni
Hi, it's a wider issue with the home app - it works with the Home Hub, but not the phone app.
It does work with the Google Assistant however
PHIL63
If I create a routine in the Alexa application under Android to open a blind, the "ON" command is not executed as an "ON" command but as a "Set Level" command at 100%.
Domoticz receives a "Set Level" command (without percentage in logs) that does not work for me.
No problem with the "OFF" command.
Is it a communication problem of the application or Controlicz?
Madgeni
Hi - can you PM me your controlicz ID, and i'll see what was sent, see where the issue is - thxPHIL63 wrote: Monday 10 December 2018 8:20 Hi,
CardboardNinja
Another thermostat question.
I have a nefit easy thermostat in my living room and a Spirit radiator valve in my bedroom. Now both of these devices present a temperature sensor and a setpoint. What I'm finding is that if I ask what the temperature is, that the setpoint is picked up as a temperature and averaged into the mix.
So if I ask for the temperature in the living room I get an average of the setpoint and the actual temperature. If I ask for the house temperature it seems to use all four values.
Is there something I'm missing on the config side to stop this happening?
Madgeni
o_0 that's definitely not right! If the thermostat has ambient temperature, then it should show it, otherwise it will show the setpoint.
Re: House temp, I've not observed that, so I wonder if there's a way of specifying which temp sensor/thermostat to use for that case
Madgeni
Pleased to announce Controlicz is now compatible with Ngrok, so another way to secure your connection is open to you.
