LG TV WebOs 3.0
Nefsolive
Re: LG TV WebOs 3.0
Thanks for sharing the plungin.
All working fine, but whit some lag. And i can´t power ON my tv! Just power OFF.
I see all settings on TV and they are enable.
Anythink i need for take my TV ON?
Best Regards
Best Regards
Nefsolive
Re: LG TV WebOs 3.0
I have instead, i can take my tv off and i can´t take on!basmaaks wrote: Tuesday 31 July 2018 21:33 got it running (sort of)
Some small problem, status isn't showing the channel I'm watching. Input selector doesn't work, can't switch my tv off. But I can switch my TV on.
Any help ?
Bluelightcrew
- Domoticz version: 3.6708
Re: LG TV WebOs 3.0
I found for a other home automation a script where you can send notifications to the LG tv. A very cool thing. But I have no idea how to include that in domoticz or the LG tv script. Maybe some one other have the know how to include that. I would spend some money onver PayPal.
https://www.home-assistant.io/component ... y.webostv/
nono212
- Domoticz version: 3.6179
Re: LG TV WebOs 3.0
Hello
Thanks for your great Job .
I would like to know How you did to command your TV ...
I mean Now that is working ,what is the next step ?
I do not think that people do cli to change channel
Maybe integration on alexa ?
for example Alexa ,put cnn on Tv ...
What should be the next step for that any idea ?
Nautilus
Re: LG TV WebOs 3.0
I'm using pylgtv (https://github.com/TheRealLink/pylgtv) for notifications. Not sure about the best way to set it up, but I have a python script (lgnotify.py):Bluelightcrew wrote: Wednesday 08 August 2018 9:03 I found for a other home automation a script where you can send notifications to the LG tv. A very cool thing. But I have no idea how to include that in domoticz or the LG tv script. Maybe some one other have the know how to include that. I would spend some money onver PayPal.
#!/usr/bin/env python3
from pylgtv import WebOsClient
import sys
try:
webos_client = WebOsClient('xxx.xxx.xxx.xxx')
webos_client.send_message(str(sys.argv[1]), icon_path="/home/pi/domoticz/scripts/domoticz.png")
except:
print("Error connecting to TV")Code: Select all
os.execute('/usr/bin/python3 /home/pi/domoticz/scripts/lgnotify.py "This is my message!" &')-
Bluelightcrew
Re: LG TV WebOs 3.0
Cool i will try it ,thanksNautilus wrote: Thursday 20 September 2018 0:08I'm using pylgtv (https://github.com/TheRealLink/pylgtv) for notifications. Not sure about the best way to set it up, but I have a python script (lgnotify.py):Bluelightcrew wrote: Wednesday 08 August 2018 9:03 I found for a other home automation a script where you can send notifications to the LG tv. A very cool thing. But I have no idea how to include that in domoticz or the LG tv script. Maybe some one other have the know how to include that. I would spend some money onver PayPal.
https://www.home-assistant.io/component ... y.webostv/which I then call from event system (i.e. form Lua scripts, or Blockly), e.g.Code: Select all
#!/usr/bin/env python3 from pylgtv import WebOsClient import sys try: webos_client = WebOsClient('xxx.xxx.xxx.xxx') webos_client.send_message(str(sys.argv[1]), icon_path="/home/pi/domoticz/scripts/domoticz.png") except: print("Error connecting to TV")I think the icon is optional but if you want to specify certain icon to be shown with the notification you need to specify it here: icon_path="/home/pi/domoticz/scripts/domoticz.png" I'm currently using just a plain domoticz icon for all notifications.Code: Select all
RapTile
Re: LG TV WebOs 3.0
Thanks for sharing!
marrossko
Re: LG TV WebOs 3.0
I have finally managed to connect my LGTV and Domoticz, but the interface respond is very-very slow. I dont know where is the problem. I have reinstalled pylgtv (sudo pip3 uninstall pylgtv) first and than install it again. But it didn't help. In my domoticz I can see the status of the TV, volume and option to change the inputs but every time when I click on any of them it takes number of seconds until anything happen on the TV. I'm running my Domoticz on RPI3 but I don't thing the problem is with my HW. Any ideas? Any help is much appreciated. Thanx!
rirethy
Re: LG TV WebOs 3.0
Hello, I'm trying to use this plugin .... but I have an issue installing pylgtv
I tried to install it for Pyton 3.4. in the documentation, this pylgtv is supposed to be compatoble with pyton >= 3.3 : here https://github.com/TheRealLink/pylgtv and here https://pypi.org/project/pylgtv/
Running sudo pip3 install pylgtv, I have this output :
If someone has any clue for this, it will be very helpfull.
Thanks in advance.
And, It doesn't install.sudo pip3 install pylgtv
Downloading/unpacking pylgtv
Downloading pylgtv-0.1.9-py3-none-any.whl
Downloading/unpacking asyncio (from pylgtv)
Downloading asyncio-3.4.3-py3-none-any.whl (101kB): 101kB downloaded
Downloading/unpacking websockets (from pylgtv)
Downloading websockets-8.1.tar.gz (58kB): 58kB downloaded
Running setup.py (path:/tmp/pip-build-vuxwm67e/websockets/setup.py) egg_info for package websockets
File "<string>", line 17, in <module>
File "/tmp/pip-build-vuxwm67e/websockets/setup.py", line 12, in <module>
long_description = (root_dir / 'README.rst').read_text(encoding='utf-8')
AttributeError: 'PosixPath' object has no attribute 'read_text'
Complete output from command python setup.py egg_info:
Cleaning up...
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-vuxwm67e/websockets
Storing debug log for failure in /root/.pip/pip.log
Thanks in advance.
2 Raspberry Pi (xbian + Domoticz)
Synology NAS 214 Play
NAS and Raspberrys monitoring
Sigma design Zwave+ USB controler
1 Aeon MiniMote
1 Qubino ZMNHAA2 (Flush 1 relay)
1 Qubino ZMNHCA2 (Flush shutter)
4 1-Wire Temp Sensor DS18B20
1 relay GPIO controled
1 Aeon MiniMote
qmax
- Domoticz version: 2020.1
Re: LG TV WebOs 3.0
Hello
At first I want to apologize for my English
Anyone helps??
Domoticz does not start, I have such an error
This happened after installation LGTV Plugin
After clean installation of Domoticz and after plugin installation i have an error, Domoticz does not start, I have a problem removing the device
Anyone helps??
2020-03-27 19:09:27.282 Error: Domoticz(pid:3569, tid:3583('MainWorker')) received fatal signal 11 (Segmentation fault)
2020-03-27 19:09:27.282 Error: siginfo address=0x27206465, address=(nil)
2020-03-27 19:09:29.730 Error: Thread 12 (Thread 0x701fd430 (LWP 3583)):
2020-03-27 19:09:29.730 Error: #0 __waitpid (options=0, stat_loc=0x701fc0f0, pid=3586) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2020-03-27 19:09:29.730 Error: #1 __waitpid (pid=3586, stat_loc=0x701fc0f0, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2020-03-27 19:09:29.730 Error: #2 0x00109454 in dumpstack_gdb(bool) ()
2020-03-27 19:09:29.730 Error: #3 0x00109a20 in signal_handler(int, siginfo_t*, void*) ()
2020-03-27 19:09:29.731 Error: #4 <signal handler called>
2020-03-27 19:09:29.731 Error: #5 0x00097004 in std::map<unsigned char, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<unsigned char>, std::allocator<std::pair<unsigned char const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >::operator[](unsigned char const&) ()
2020-03-27 19:09:29.731 Error: #6 0x0007c12c in CEventSystem::UpdateJsonMap(CEventSystem::_tDeviceStatus&, unsigned long long) [clone .constprop.1290] ()
2020-03-27 19:09:29.731 Error: #7 0x0008ece8 in CEventSystem::GetCurrentStates() ()
2020-03-27 19:09:29.731 Error: #8 0x0008f644 in CEventSystem::StartEventSystem() ()
2020-03-27 19:09:29.731 Error: #9 0x000d8444 in MainWorker::Do_Work() ()
2020-03-27 19:09:29.731 Error: #10 0x0077dd94 in execute_native_thread_routine ()
2020-03-27 19:09:29.731 Error: #11 0x76c3e648 in start_thread (arg=0x701fd430) at pthread_create.c:479
2020-03-27 19:09:29.731 Error: #12 0x76b06778 in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
Naruszenie ochrony pamięci
2020-03-27 23:37:37.997 Error: (LG TV) failed to parse parameters, valid Notifier Name expected, received 'LG TV 1'.
Fatal Python error: Segmentation fault
Thread 0x76f89010 (most recent call first):
2020-03-27 23:38:51.602 Error: Domoticz(pid:1631, tid:1637('WebServer_8080')) received fatal signal 11 (Segmentation fault)
2020-03-27 23:38:51.602 Error: siginfo address=0x65f, address=(nil)
2020-03-27 23:38:54.646 Error: Thread 7 (Thread 0x72d3b220 (LWP 1637)):
2020-03-27 23:38:54.646 Error: #0 __waitpid (options=0, stat_loc=0x72d39180, pid=1685) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2020-03-27 23:38:54.646 Error: #1 __waitpid (pid=1685, stat_loc=0x72d39180, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2020-03-27 23:38:54.646 Error: #2 0x00109454 in dumpstack_gdb(bool) ()
2020-03-27 23:38:54.646 Error: #3 0x00109a20 in signal_handler(int, siginfo_t*, void*) ()
2020-03-27 23:38:54.646 Error: #4 <signal handler called>
2020-03-27 23:38:54.646 Error: #5 raise (sig=11) at ../sysdeps/unix/sysv/linux/raise.c:50
2020-03-27 23:38:54.646 Error: #6 <signal handler called>
2020-03-27 23:38:54.646 Error: #7 0x676c7970 in ?? ()
2020-03-27 23:38:54.646 Error: #8 0x72409ab0 in ?? ()
qmax
Re: LG TV WebOs 3.0
Problem solved after another clean instalation.
Plugin works fine, downloaded from :
I just don't know how to do automatic pairing with the TV, I have to confirm pairing every time I start it.
I found a modified lg.py file, it has automatic pairing but unfortunately it doesn't work.
https://github.com/GameDevHobby/Domoticz-LGTV-WebOS-Plugin
Romel
Re: LG TV WebOs 3.0
remote control in domoticz panel can switch channel UP and DOWN . Volume is working too.. but button OK not. Is there some script to control own command ? for example - switch channel no 31, set volume to 8.
EDIT:
ok. I found:
Here are commands
EDIT:
ok. I found:
/usr/bin/python3 /home/pi/domoticz/plugins/LGTV/lg.py -c send-message -a "Message shown on TV" 192.168.88.214How I can use set-channel ?self.commandLines = {
'off': self.off,
'on': self.wakeonlan,
'software-info': self.software_info,
'volume-up': self.volume_up,
'volume-down': self.volume_down,
'current-app': self.current_app,
'apps': self.apps,
'services': self.services,
'get-volume': self.get_volume,
'get-inputs': self.get_inputs,
'app': self.app,
'set-volume': self.set_volume,
'close-app': self.close_app,
'mute': self.mute,
'unmute': self.unmute,
'get-mute': self.get_mute,
'get-input': self.get_input,
'set-input': self.set_input,
'channel-up': self.channel_up,
'channel-down': self.channel_down,
'channels': self.channels,
'get-channel': self.get_channel,
'info': self.info,
'set-channel': self.set_channel,
'play': self.play,
'pause': self.pause,
'stop': self.stop,
'close': self.close,
'rewind': self.rewind,
'fast-forward': self.fast_forward,
'send-message': self.send_message,
'enter': self.enter,
'delete': self.delete,
#'3d-on': threeDOn,
#'3d-off': threeDOff,
lamama1234
Re: LG TV WebOs 3.0
I installed Domoticz-LGTV-WebOS-Plugin from scratch (including pylgtv libary) and defined IP + MAC address within Domoticz hardware configuration. However, I'm not able to get my TV show the pairing code no matter what I tried.
Any tips?
Any tips?
bramv
Re: LG TV WebOs 3.0
@Mayki
I included a few new sources like Disney+, Spotify, Apple TV, and the LG app PhotoVideo .
It's on : https://github.com/bramvreugd/Domoticz- ... bOS-Plugin
It did not work well on my OLEDE9. I've made some changes and you can find it at my fork of this project. I hope the creator of the plugin will merge it with the original. My new plugin might not work well with older LG TVs.Does it work for anyone on the new TV? For example, OLEDC9?
drwurn
Re: LG TV WebOs 3.0
I've got this running on my B9.
The data on the LG TV STATUS is '{'returnValue': True} ({'returnValue': False, 'errorCode': -106, 'errorText': 'No resource: 9A8adAeFA301AFE6Ba348d857362Dd5'} )'
I've only got the status and source, fine by me because I only use the status to dim one light in the room when the TV is on.
DarkG
- Domoticz version: 4.10076
Re: LG TV WebOs 3.0
bramv wrote: Monday 17 August 2020 8:18 @MaykiIt did not work well on my OLEDE9. I've made some changes and you can find it at my fork of this project. I hope the creator of the plugin will merge it with the original. My new plugin might not work well with older LG TVs.Does it work for anyone on the new TV? For example, OLEDC9?
How do you change it? I need buttons for SkyQ and Plex
RPi4 Shelly1 Shelly2.5 ESPEasy Tuya Domoticz Beta Dashticz 3.6
bramv
Re: LG TV WebOs 3.0
If you want them to be added to the pull down list it's easy.
First turn on debugging in domoticz. Then start the app you want to add on the LG TV.
Search for the text: "App: " in the logging of domoticz. The text after the semicolon you have to remember.
Now open the plugin.py file. Add the name of the app you want to add just before unknown in the following line.
"LevelNames" : "Off|TV|HDMI1
Change the following lines. The bold text is added or changed. If you add another please be sure you update unknown to 160
elif "photovideo" in self.tvPlaying.lower():
self.tvSource = 130
UpdateDevice(3, 1, str(self.tvSource))
elif <a part form the tet you found in the debugger" in self.tvPlaying.lower():
self.tvSource = 140
else:
self.tvSource = 150
UpdateDevice(3, 1, str(self.tvSource)) # Set source device to Unknown
add after the lines
if Level == 130:
self.tvPlaying = "PhotoVideo"
self.run("app", "com.webos.app.photovideo")
add the following lines:
if Level == 140:
self.tvPlaying = <you appname>
self.run("app", "<the text from the debugger>")
and add 10 to the level of unknown.
if Level == 140:
you can restart a plugin by disabling it then click update. Enable it and click update again.
You can also send the text from the debugger to me and I will do it for you.
I can also change the plugin with an extra option where you can add extra sources.
self.tvSource = 130
self.tvSource = 140
else:
self.tvSource = 150
add after the lines
if Level == 130:
if Level == 140:
if Level == 140:
bramv
Re: LG TV WebOs 3.0
I'm working on an almost complete rewrite of the LG tv plugin.
Is there anyone who like to test it or have a feature requests.
Status so far.
-Inclusief pylgtv library because of is no longer maintained and it had soms bugs in it.
Of is also a little faster because pylgtv is inckuded instead of running a new python for each command.
- status device now reports also the program you are watching.
- extra device in witch you can select witch tv channel hou want to see.
Possible thjngs to do:
- Code cleanup. There was a lot of code of the bravia plugin that should be removed.
- now the channel includes all posibilities of channels of tv, radio and satelite. That is a long list in my csse because all HD channels are also broadcasted in SD. It's several hjndreds long.. I plan to make a filter in which you van filter to have only High definition (no SD) and no radio.
- Maybe all the radio chanels in seperate device
- Custom screen with all remore buttons.
Status so far.
Nautilus
Re: LG TV WebOs 3.0
Sounds excellent. If it is compatible with B7 model I'd be happy to test...
DarkG
Re: LG TV WebOs 3.0
I habe this error in log
2020-11-12 00:59:49.946 Error: (tv) 'onHeartbeat' failed 'NameError':'name 'out' is not defined'.
2020-11-12 00:59:49.946 Error: (tv) ----> Line 466 in '/home/pi/domoticz/plugins/Domoticz-LGTV-WebOS-Plugin-master/plugin.py', function onHeartbeat
2020-11-12 00:59:49.946 Error: (tv) ----> Line 298 in '/home/pi/domoticz/plugins/Domoticz-LGTV-WebOS-Plugin-master/plugin.py', function onHeartbeat
2020-11-12 00:59:49.946 Error: (tv) ----> Line 351 in '/home/pi/domoticz/plugins/Domoticz-LGTV-WebOS-Plugin-master/plugin.py', function GetTVInfo
