Zigate 4.0.0 Topic is solved
pipiche
Zigate 4.0.0
Post by pipiche »
Today we are releasing version 4.0.0 au Zigate-Plugin for Domoticz.
Version 3 didn't stay for long as we have reconsider part of the architecture and we have made the plugin compliant with the Domoticz database.
This version brings a new Transport mechanism with the Zigate, which makes the communication more reliable and much faster than in version 3.
You can cross-check the Release notes to see what are the various addon.
Last but not least, please use the forum channels to ask questions and report problems, we would like to focus the usage of the GitHub Issue only for confirmed Bugs and Enhancement
big thanks to the contribution of some of you in the testing of the Beta3.2 and 3.3 @ricky74, @d2e2n2o
In case you are on the master branch ( 3.0.x ) this branch is not compatible with the versions 3.2 and above. A miration will be needed and is documented https://github.com/sasu-drooz/Domoticz- ... de-IEEE.md
https://github.com/sasu-drooz/Domoticz-Zigate
Support of IKEA trådfri Bulbs, most of the Xiaomi sensors, recently added the Salus plug
Wiki is available here.
Zigbee for Domoticz FAQ
LouiS22
Re: Zigate 4.0.0
Post by LouiS22 »
Had problems with the migration tool, so I simply removed and readded all my 5 devices. Now it's ok and really like this version!
pipiche
Re: Zigate 4.0.0
Post by pipiche »
Thanks for the feedback.
It would be great if you could share what the difficulty was on the upgrade, so we could address it.
LouiS22
Re: Zigate 4.0.0
Post by LouiS22 »
pipiche wrote: Monday 03 December 2018 9:43 Thanks for the feedback.
If I recall it, there was a problem within the script at line 80. Didn't fiddle it with though, solved it with the easeier way: remove and readd :D
pipiche
Re: Zigate 4.0.0
Post by pipiche »
@LouiS22 ok. Indeed with 5 objects to commission it was even much better.
Line 80 is a query in the Domoticz database . Let see if someone else get the same trouble.
hkhk
Re: Zigate 4.0.0
Post by hkhk »
How do I move from beta-3.3 to 4.0 ?
pipiche
Re: Zigate 4.0.0
Post by pipiche »
@hkhk
from Domoticz-Zigate directory
git pull
git checkout stable
pipiche
Re: Zigate 4.1 (beta)
Post by pipiche »
Short announcement,
We have push a version to beta branch.
- This version provides
- Native support of Groups. Which means your group is defined inside the Zigate and when you switch on a group All devices associated to that group are switch on. (more information here : https://github.com/sasu-drooz/Domoticz- ... e-on-beta) )
- Network Topology display ( more information here : https://github.com/sasu-drooz/Domoticz- ... LQI-report )
In order to switch to beta
git pull
git checkout beta
If you want to switch back to stable
git pull
git checkout stable
