So far from inclusion? I imagine it's not possible to block new sub-devices adds a few minutes after inclusion as a lot only expose them at the first measurement sent... so unchecking accept new hardware will not fix this?gizmocuz wrote: Wednesday 28 November 2018 17:26 it's a problem that this is reported by the zwave node
And now for a solution... it might be possible to configure (in the node configuration file), not not report the humidity value
Temp sensors suddenly recognized as Temp+Hum
lost
Re: Temp sensors suddenly recognized as Temp+Hum
- Egregius
- Domoticz version: v2024.7
Same story here...
I updated Domoticz on September 23th to version 4.10007.
Several weeks later, on November 17th, one of my Fibaro smoke detectors (badkamer_temp) stopped reporting temperature. When I looked in the device table a new device was added:
In my case not a huge problem, I strip of the humidity in pass2php so only the temp stays, but a very strange thing.
I think this is the relative part of my zwave xml:
<CommandClass id="49" name="COMMAND_CLASS_SENSOR_MULTILEVEL" version="8" innif="true">
<Instance index="1" />
<Value type="decimal" genre="user" instance="1" index="1" label="Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="22.6" />
<Value type="decimal" genre="user" instance="1" index="5" label="Relative Humidity" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="18.8" />
<Value type="decimal" genre="user" instance="1" index="9" label="Barometric Pressure" units="kPa" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="20.4" />
</CommandClass>
- gizmocuz
@gerardvs, well i have specifically designed it like this, so it is definitely not a flow
But, you could make an 'advanced' setting to not combine multiple sensor types in one type
Also, you are not the average user, please keep that in mind ! Most users buy (for example) a zwave temp+hum sensor, so... a temp+hum sensor
Anyways, please make a PR with a setting that , when enabled, will not combine sensors.
gerardvs
- Domoticz version: latest-1
ok, fair enough. Thanks for the suggestion.
bjacobse
I have just deleted stuff in my zwave xml file: /home/pi/domoticz/Config/zwcfg_0x014cdf33.xml
before anything, make a backup
I searched for COMMAND_CLASS_SENSOR_MULTILEVEL and the below sensors appears that I don't have (have only Temperature) Relative humidity and CO2 level. I did this for deletion for each "faulty" sensor in my Qubino relay with DS18B20
and after deleting:
And then OpenZawe looks better, those annoying humidity and CO2 sensors are gone
cp zwcfg_0x014cdf33.xml backup_zwcfg_0x014cdf33.xml Code: Select all
<CommandClass id="49" name="COMMAND_CLASS_SENSOR_MULTILEVEL" version="7" request_flags="1" innif="true">
<Instance index="1" endpoint="2" />
<Value type="decimal" genre="user" instance="1" index="1" label="Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="21.5" />
<Value type="decimal" genre="user" instance="1" index="5" label="Relative Humidity" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="21.5" />
<Value type="decimal" genre="user" instance="1" index="17" label="CO2 Level" units="ppm" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="24.0" />
</CommandClass>
</CommandClass>
- gizmocuz
@bjacobse, good to see this !!... i hope in a few days it will stay the same...
Also try to power off/on the node... just in case
bjacobse
Yes I will monitor and try power cycle as you propose, Thank you @gizmocuz for pointing me to this directiongizmocuz wrote: Thursday 29 November 2018 21:20 @bjacobse, good to see this !!... i hope in a few days it will stay the same...
BTW I have created a bug in OpenZwave, as I am unsure if this is similar for other manufactures, I have only created this as Qubino ZMNHADx Flush 1 specific bug
https://github.com/OpenZWave/open-zwave/issues/1658
TheeDude
I have suddenly had this problem also, with a Fibaro FGBS-222.
It was installed 11th November, and has been working flawlessly, until a month ago, in the beginning of march.
In my domoticz config folder I didn´t have a zwcfg file, so I took a backup of the ozwcache file, and I think that I also took that file and renamed to a zwcfg file, maybe that doesn´t work?
Well, now a month later, the problems started again with the same temp sensors.
So, I did as "lost" pointed out in this thread, to delete those lines in the zwcfg that are sensors that I don´t have.
Before deleting:
Efter deleting:
My ozwcache file reports this
Is this really correct? The config file seems to me that it contains veeeery much information for that node, is it that advanced?
Why does this keep happening for me?
Or have I solved it by now?
It seems to show correct values for now, but it have changed instance numbers for the sensors, so I don´t know which is which.
But I can live with that, it´s easy to check.
I tried to paste the whole "node 55" config from zwcfg, but that was too many characters for the forum.
Before deleting:
<CommandClass id="49" name="COMMAND_CLASS_SENSOR_MULTILEVEL">
<Compatibility />
<State>
<CCVersion>11</CCVersion>
<InNif>true</InNif>
<StaticRequests>1</StaticRequests>
</State>
<Instance index="1" endpoint="3" />
<Instance index="2" endpoint="4" />
<Instance index="3" endpoint="7" />
<Instance index="4" endpoint="8" />
<Instance index="5" endpoint="9" />
<Instance index="6" endpoint="10" />
<Value type="decimal" genre="user" instance="3" index="0" label="Unknown" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="2" min="0" max="0" value="12.6">
<Help></Help>
</Value>
<Value type="decimal" genre="user" instance="6" index="0" label="Unknown" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="2" min="0" max="0" value="4.5">
<Help></Help>
</Value>
<Value type="decimal" genre="user" instance="1" index="1" label="Air Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="2" min="0" max="0" value="11.5">
<Help>Air Temperature Sensor Value</Help>
</Value>
<Value type="decimal" genre="user" instance="3" index="1" label="Air Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="2" min="0" max="0" value="12.0">
</Value>
<Value type="decimal" genre="user" instance="4" index="1" label="Air Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="2" min="0" max="0" value="2.1">
</Value>
<Value type="decimal" genre="user" instance="5" index="1" label="Air Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="2" min="0" max="0" value="3.4">
</Value>
<Value type="decimal" genre="user" instance="6" index="1" label="Air Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="2" min="0" max="0" value="2.9">
</Value>
<Value type="decimal" genre="user" instance="5" index="5" label="Humidity" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="2" min="0" max="0" value="1.5">
<Help>Humidity Sensor Value</Help>
</Value>
<Value type="decimal" genre="user" instance="1" index="15" label="Voltage" units="V" read_only="true" write_only="false" verify_changes="false" poll_intensity="2" min="0" max="0" value="10.73">
<Help>Voltage Sensor Value</Help>
</Value>
<Value type="decimal" genre="user" instance="2" index="15" label="Voltage" units="V" read_only="true" write_only="false" verify_changes="false" poll_intensity="2" min="0" max="0" value="10.07">
</Value>
<Value type="decimal" genre="user" instance="6" index="17" label="Carbon Dioxide" units="Ppm" read_only="true" write_only="false" verify_changes="false" poll_intensity="2" min="0" max="0" value="3.2">
<Help>Carbon Dioxide Sensor Value</Help>
</Value>
<Value type="list" genre="system" instance="3" index="256" label="Air Temperature Units" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Help>Air Temperature Sensor Available Units</Help>
<Item label="Celsius" value="0" />
</Value>
<Value type="list" genre="system" instance="4" index="256" label="Air Temperature Units" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
<Value type="list" genre="system" instance="5" index="256" label="Air Temperature Units" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
<Value type="list" genre="system" instance="6" index="256" label="Air Temperature Units" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
<Value type="list" genre="system" instance="1" index="270" label="Voltage Units" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Help>Voltage Sensor Available Units</Help>
<Item label="Volts" value="0" />
</Value>
<Value type="list" genre="system" instance="2" index="270" label="Voltage Units" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
</CommandClass>Code: Select all
<Compatibility />
<State>
<InNif>true</InNif>
</State>
</Value>
</Value>
</Value>
</Value>
</Value>
</Value>
</Value>
</Value>
</Value>
</Value>Code: Select all
<Compatibility />
<State>
<InNif>true</InNif>
</State>
<Instance index="3" endpoint="8" />
<Instance index="4" endpoint="10" />
<Value type="decimal" genre="user" instance="1" index="1" label="Air Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3.0">
</Value>
<Value type="decimal" genre="user" instance="3" index="1" label="Air Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="6.1">
</Value>
<Value type="decimal" genre="user" instance="4" index="1" label="Air Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="4.8">
</Value>
<Value type="decimal" genre="user" instance="1" index="15" label="Voltage" units="V" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="10.71">
</Value>
</Value>
</Value>
</CommandClass>
danny
Same problem as descibed. Worked perfect for few months. After that same problem. Missing 1 or 2 sensors. And having a temp/rv sensor. Regarding the fibaro first version of binaire switch.
lamama1234
Same issue here. New devices created with subtype "WTGR800" (used to be "LaCrosse TX3") on a Fibaro UBS FGBS-001 hooked up to 4 DS18B20 sensors.
My Domoticz version is 2020.1 running on Win7 and using Aeotec Z-Stick for Z-Wave connectivity.
Any tip on how to revert or should I just use the new added devices instead? From my experience, it will happen from time to time (every x months) resulting in loss of temperature readings history + messing up JSON requests with the old devices id.
TheeDude
This has just happened to me again.lamama1234 wrote: Tuesday 01 June 2021 9:33 Same issue here. New devices created with subtype "WTGR800" (used to be "LaCrosse TX3") on a Fibaro UBS FGBS-001 hooked up to 4 DS18B20 sensors.
Did you found a solution?
lamama1234
There seems to be a workaround, as described here: viewtopic.php?p=264337#p264337TheeDude wrote: Monday 07 June 2021 21:40This has just happened to me again.lamama1234 wrote: Tuesday 01 June 2021 9:33 Same issue here. New devices created with subtype "WTGR800" (used to be "LaCrosse TX3") on a Fibaro UBS FGBS-001 hooked up to 4 DS18B20 sensors.
I haven't tried it yet..
lost
I did not dig into this for now, but one fibaro "eye" PIR did it again in July... Last time I was on OZW 1.4 and zwcfg file change did the trick. Looking at files dates in Config directory, looks this file was not updated since I first upgraded to a domoticz version that's OZW 1.6 based. Only ozwcache file looks in use now.
If someone can confirm that this last file must now have temp+hum related lines purged (while domoticz/OZW is stopped, of course) to restore temp readings?
Also, if some progress was made on the root cause of this issue & ways to avoid this in the future, please let me know!
lost
Looks changing ozwcache file (removing bad temp+hum lines + restoring original temp ; I have another same device, this helps) while domoticz service is stopped did the trick to restore temp readings. But looks a device wake-up close to controller was needed and this wake-up than hanged zwave driver, as this occurs sometimes. Before wake-up/hang, after waiting for all nodes queried message, every triggered devices (Like PIRs) reported on then off several times in a few hundred ms.
So I would not recommend it as this triggered a weird z-wave behavior, even if this looks OK now after a second domoticz restart and no more device manual wake-up.
