Play audio file on Google home
Alexa, Google Home and Siri
thecosmicgate
Domoticz version: newest
Post by thecosmicgate »
Can somebody tell me or assist me how it's possible to play some kind of an audio file on Google home using domoticz.
I want to push a button (dummy switch) on domoticz which would play a sound on Google home.
At the end I should use this as a chime so when somebody presses the doorbell (z-wave) Google home plays the chosen file =sound
Thnx for helping
Sent from my ONEPLUS A6003 using Tapatalk
It's nice to be important, but it's more important to be nice
Scooter ;)
sincze
Domoticz version: 2024.4
Re: Play audio file on Google home
Post by sincze »
Have a look around at the forum and look for 'stream2chromecast'.
After installing that you can for sure call a script from within domoticz that will play the sound for you when somebody presses the doorbell.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
thecosmicgate
sincze wrote:Have a look around at the forum and look for 'stream2chromecast'.
Thnx @sincze , will have a look
Scooter ;)
pvm
Domoticz version: 4.10538
Post by pvm »
Did you get this to work? Stream to Google home (mini?) and not chromecast?
freijn
Domoticz version: Stable
Post by freijn »
Yeah, Please note Google Home has its own speaker :-) interested too
alanlsmith
Domoticz version: Latest β
Post by alanlsmith »
The easiest way is probably to put the mp3 files in '/var/www/html/mp3/xxx.mp3' so that they can be reached in a browser at
'<your IP address>/mp3'
This way the 'built-in to the system' Apache server (not the web-server in Domoticz)is being used to store and stream the audio files.
Then create a Node-Red flow that can be triggered by a switch in Domoticz and use a 'node-red-contrib-cast' node to play the audio file.
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
