LUA print statements in Domoticz log not working
joremkes
Domoticz version: 4.10224
Post by joremkes »
Hi All,
I'm doing some LUA script debugging and I like to see the output of the print statements in de LUA script somewhere in the log. I've been playing with the DAEMON_ARGS setting in the domoticz.sh but so far no result playing around with the loglevel and debuglevel. This is what I currently have:
DAEMON=/home/$USERNAME/domoticz/$NAME
DAEMON_ARGS="-daemon"
#DAEMON_ARGS="$DAEMON_ARGS -daemonname $NAME -pidfile $PIDFILE"
DAEMON_ARGS="$DAEMON_ARGS -www 8080"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
#DAEMON_ARGS="$DAEMON_ARGS -log /tmp/domoticz.txt"
#DAEMON_ARGS="$DAEMON_ARGS -syslog"
DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error,debug"
DAEMON_ARGS="$DAEMON_ARGS -debuglevel eventsystem"
Any idea on how to get this working?
Thanks, Joep
Re: LUA print statements in Domoticz log not working
joremkes wrote: Wednesday 28 November 2018 1:41 I'm doing some LUA script debugging and I like to see the output of the print statements in de LUA script somewhere in the log.
Change line
to
and restart domoticz. You will see the loglines coming in the file /tmp/domoticz.txt
For normal use the lines
can be changed to
#DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error,debug"
#DAEMON_ARGS="$DAEMON_ARGS -debuglevel eventsystem"
joremkes
Post by joremkes »
Ok, I got it working and I also realized my mistake.... :shock: :shock: :shock: :shock:
I was actually changing the domoticz.sh in my ~/domoticz folder. (I run Domoticz on a Raspberry Pi). After making the suggested changes still no logging and also there was no tmp/domoticz.txt file. My logs are in the tmp/log/domoticz.log file. Then I realized that ages ago I made a ramdisk for the domoticz db file and the log. I looked up the article and actually found out I had to use the /etc/init.d/domoticz.sh to make the changes to :oops: . After making the changes here (removed -loglevel 1) I have LUA logging in my logs again including the output of the print commands.
Thanks for helping out!
Joep
