What is wrong  [Solved]
havnegata
Domoticz version: V4.10162
What is wrong
Post by havnegata »
Someone has an idea of why this is not working?
            devices = {
                ['Bad2etg'] = {'at 06:00-07:00 on mon,tue,wed,thu,fri'},
                ['Yttergang'] = {'at 06:00-07:00 on mon,tue,wed,thu,fri'}
            if ((device.name == 'Bad2etg' and device.active) or (device.name == 'Yttergang' and device.active)) then
                domoticz.notify('Noen har våknet', domoticz.NSS_PUSHOVER)
Re: What is wrong
havnegata wrote: Thursday 22 November 2018 15:11 Someone has an idea of why this is not working?
            devices = {
You are quite close but misplaced one }
This one works on my system
                on =    { devices = {   ['Bad2etg']     = {'at 06:00-07:00 on mon,tue,wed,thu,fri'},
                                        ['Yttergang']   = {'at 06:00-07:00 on mon,tue,wed,thu,fri'}}
        if (device.name == 'Bad2etg' and device.active) or (device.name == 'Yttergang' and device.active) then
havnegata
Re: What is wrong
Post by havnegata »
Brilliant! Thanks a lot!
havnegata
Re: What is wrong
Post by havnegata »
OK, so I was waken by hammering notifications today, so the script is working, but needs a little tuning ;) I figured a variable could fix this so that I only get one notification. I tried with adding a variable Vaken. The variable changes, but this is ignored the next time it runs.
            devices = {
                ['Bad2etg'] = {'at 06:00-11:00 on mon,tue,wed,thu,fri'},
            local Vaken = domoticz.variables('Vaken')
            if ((device.name == 'Bad2etg' and device.active) or (device.name == 'Yttergang' and device.active) and (Vaken.value == '0')) then
                Vaken.set('1')
Re: What is wrong
havnegata wrote: Friday 23 November 2018 11:54 OK, so I was waken by hammering notifications today, so the script is working, but needs a little tuning ;) I figured a variable could fix this so that I only get one notification. I tried with adding a variable Vaken. The variable changes, but this is ignored the next time it runs.
Again it's in the brackets..
            devices = {
            Vaken.set('1')
        domoticz.log("Current logic : (true or false and false)   ===>> " .. tostring(true or false and false) )
        domoticz.log("What you want : (true or false) and false   ===>> " .. tostring((true or false) and false) )
havnegata
Re: What is wrong
Post by havnegata »
2018-11-27 17:33:08.228 Status: User: Admin initiated a switch command (16/Bad2etg/On)
2018-11-27 17:33:08.447 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-11-27 17:33:08.461 Status: Notification: Noen har våknet
2018-11-27 17:33:08.464 Status: Set UserVariable Vaken = 1
The script is triggering on first switch "Bad2etg" and the uservariable is set and the notification is sent. So far so good 🙂 However it's not triggering on second switch "Yttergang" and the uservariable doesn't seem to have any effect because if first switch is triggered again the notification is sent again, which it was not supposed to do, at least according to my intentions :? Does this have anything to do with brackets?
Re: What is wrong
havnegata wrote: Tuesday 27 November 2018 17:45
What is the type of the uservariable ? integer / float / string ?
havnegata
Re: What is wrong
Post by havnegata »
Integer
Re: What is wrong  [Solved]
havnegata wrote: Tuesday 27 November 2018 19:21Integer
OK then the script should look like the one below. Do you have another script to reset the uservariable ? Because based on this code the uservariable will be set once and after that the notification will never come again.
            devices = {
            execute = function(domoticz, device, info)
        if ((device.name == 'Bad2etg' and device.active) or (device.name == 'Yttergang' and device.active)) and Vaken.value == 0 then
            domoticz.notify(info.scriptName,'Noen har våknet', domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_PUSHOVER)
            Vaken.set(1)
            domoticz.log("notification send and Vaken set")
            domoticz.log("device " .. device.name .. " active: " .. tostring(device.active) )
            domoticz.log("variable " .. Vaken.name .. " value: " .. Vaken.value )
havnegata
Re: What is wrong
Post by havnegata »
Great! Thanks for the swift replies and your last solution is working perfect! It was the quotation marks around the uservariable values. It's supposed to be uservariable.set(1), not uservariable.set('1')
Re: What is wrong
havnegata wrote: Tuesday 27 November 2018 22:18 Great! Thanks for the swift replies and your last solution is working perfect! It was the quotation marks around the uservariable values. It's supposed to be uservariable.set(1), not uservariable.set('1')
Yes if the var is defined as integer then we do not need the ''
