Python Plugin: Chromecast Topic is solved
DutchHans
Re: Python Plugin: Chromecast
Got it working... This is just brilliant!
5 Google Homes... fantastic...
One question...
Is it also possible to determine which Chromecast is active?.. i mean.. if I ask in the livingroom if the dishwasher is ready...that the Chromecast from the livingroom answers.. and when I ask the same question in the bedroom..that the Chromecast in the bedroom answers
Hans
One question...
Hans
snellejellep
- Domoticz version: 2020.2
It is working now but i forgot one of the dependencies that came with the update.
Note: it now does not turn to other when i stop playing but it stays on the app it was playing, is that intended behaviour or somthing you are figuring out because i would like my stuff to turn on when i start casting amd turn off when i stop but right now i do not get the off report.
raspberry pi | xiaomi vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | zigbee2mqtt | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
assenzuid
Updated to the latest plugin.py.
Now i get this error message
I have filled my local network under Local Networks in Domoticz setting page.
(Chromecast status) You have set a password, but have not excluded your local ip. Please do so, then restart domoticz-
dextm80
- Domoticz version: 4.10159
2018-11-22 21:49:09.116 Error: (Chomecast) Error on line 233 Error is list index out of range Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
Ewaldharmsen
I have just published version 1.1.5. Please check again
toutazimuth
Rasberry PiEwaldharmsen wrote: Friday 23 November 2018 8:29 I have just published version 1.1.5. Please check again
Domoticz beta V4.10224
Ewaldharmsen, thank you for the work done
Network error for me.
Should I change network addresses and port in the plugin (my Domoticz adress is not 127.0.0.1) ?
2018-11-23 11:17:06.298 Error: (chrome) Error on line 355 Error is HTTPConnectionPool(host='127.0.0.1', port=8080): Max retries exceeded with url: /json.htm?type=command¶m=saveuservariable&vname=TVcuisine&vtype=2&vvalue= (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x672c3bf0>: Failed to establish a new connection: [Errno 111] Connection refused',))
2018-11-23 11:17:06.298 Error: (chrome) 'onStart' failed 'UnboundLocalError':'local variable 'result' referenced before assignment'.
2018-11-23 11:17:06.298 Error: (chrome) ----> Line 317 in '/home/pi/domoticz/plugins/ChromecastPlugin/plugin.py', function onStart
2018-11-23 11:17:06.298 Error: (chrome) ----> Line 210 in '/home/pi/domoticz/plugins/ChromecastPlugin/plugin.py', function onStart
2018-11-23 11:17:06.298 Error: (chrome) ----> Line 359 in '/home/pi/domoticz/plugins/ChromecastPlugin/plugin.py', function createDevices
2018-11-23 11:17:15.815 Error: (chrome) Error on line 244 Error is list index out of range-
Ewaldharmsen
toutazimuth wrote: Friday 23 November 2018 11:22Rasberry PiEwaldharmsen wrote: Friday 23 November 2018 8:29 I have just published version 1.1.5. Please check again
2018-11-23 11:17:06.298 Error: (chrome) Error on line 355 Error is HTTPConnectionPool(host='127.0.0.1', port=8080): Max retries exceeded with url: /json.htm?type=command¶m=saveuservariable&vname=TVcuisine&vtype=2&vvalue= (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x672c3bf0>: Failed to establish a new connection: [Errno 111] Connection refused',)) 2018-11-23 11:17:06.298 Error: (chrome) 'onStart' failed 'UnboundLocalError':'local variable 'result' referenced before assignment'. 2018-11-23 11:17:06.298 Error: (chrome) ----> Line 317 in '/home/pi/domoticz/plugins/ChromecastPlugin/plugin.py', function onStart 2018-11-23 11:17:06.298 Error: (chrome) ----> Line 210 in '/home/pi/domoticz/plugins/ChromecastPlugin/plugin.py', function onStart 2018-11-23 11:17:06.298 Error: (chrome) ----> Line 359 in '/home/pi/domoticz/plugins/ChromecastPlugin/plugin.py', function createDevices 2018-11-23 11:17:15.815 Error: (chrome) Error on line 244 Error is list index out of range
Wow I didn't even know that was possible, but fixed in version 1.1.6
Last edited by Ewaldharmsen on Friday 23 November 2018 13:42, edited 1 time in total.
DutchHans
What do you mean?...
Ewaldharmsen wrote: Friday 23 November 2018 12:06 Wow I didn't even know that was possible, but fixed in version 1.1.6
DutchHans
Hi Ewald,
Just installed the latest version 1.16 and from all Google Minis(5) I got the same Error:
2018-11-23 19:12:43.241 Error: (CC) Error on line 244 Error is list index out of range
every 10 seconds.
And.. its not speaking the variable string anymore....
any Ideas?
Regards, Hans
every 10 seconds.
any Ideas?
Regards, Hans
dextm80
DutchHans wrote: Friday 23 November 2018 19:15 Hi Ewald,
every 10 seconds.
any Ideas?
Regards, Hans
2018-11-23 22:06:07.404 Error: (Chomecast) Error on line 244 Error is list index out of range and before this error:
2018-11-24 17:53:10.644 Status: (Chomecast) Connected to Chromecast
2018-11-24 17:53:10.725 Error: (Chomecast) Error on line 355 Error is Expecting value: line 1 column 1 (char 0)
2018-11-24 17:53:10.726 Error: (Chomecast) 'onStart' failed 'UnboundLocalError':'local variable 'result' referenced before assignment'.
2018-11-24 17:53:10.726 Error: (Chomecast) ----> Line 317 in '/home/x/domoticz/plugins/ChromecastPlugin/plugin.py', function onStart
2018-11-24 17:53:10.726 Error: (Chomecast) ----> Line 210 in '/home/x/domoticz/plugins/ChromecastPlugin/plugin.py', function onStart
2018-11-24 17:53:10.726 Error: (Chomecast) ----> Line 359 in '/home/x/domoticz/plugins/ChromecastPlugin/plugin.py', function createDevices
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
Ewaldharmsen
Check you hardware, I have added an extra field which nerds to be filled.Somehow the default foes not work on upgradedextm80 wrote: Friday 23 November 2018 22:07DutchHans wrote: Friday 23 November 2018 19:15 Hi Ewald,
every 10 seconds.
any Ideas?
Regards, Hanssame error hereCode: Select all
2018-11-24 17:53:10.644 Status: (Chomecast) Connected to Chromecast 2018-11-24 17:53:10.725 Error: (Chomecast) Error on line 355 Error is Expecting value: line 1 column 1 (char 0) 2018-11-24 17:53:10.726 Error: (Chomecast) 'onStart' failed 'UnboundLocalError':'local variable 'result' referenced before assignment'. 2018-11-24 17:53:10.726 Error: (Chomecast) ----> Line 317 in '/home/x/domoticz/plugins/ChromecastPlugin/plugin.py', function onStart 2018-11-24 17:53:10.726 Error: (Chomecast) ----> Line 210 in '/home/x/domoticz/plugins/ChromecastPlugin/plugin.py', function onStart 2018-11-24 17:53:10.726 Error: (Chomecast) ----> Line 359 in '/home/x/domoticz/plugins/ChromecastPlugin/plugin.py', function createDevices
dextm80
which fields?
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
assenzuid
Updated to the latest version
2018-11-24 21:36:44.327 Error: (Chromecast status) Error on line 355 Error is Invalid URL '/json.htm?type=command¶m=saveuservariable&vname=Chromecast Video&vtype=2&vvalue=': No schema supplied. Perhaps you meant http:///json.htm?type=command¶m=saveuservariable&vname=Chromecast Video&vtype=2&vvalue=?
2018-11-24 21:36:44.327 Error: (Chromecast status) 'onStart' failed 'UnboundLocalError':'local variable 'result' referenced before assignment'.
2018-11-24 21:36:44.327 Error: (Chromecast status) ----> Line 317 in '/home/pi/domoticz/plugins/ChromecastPlugin/plugin.py', function onStart
2018-11-24 21:36:44.327 Error: (Chromecast status) ----> Line 210 in '/home/pi/domoticz/plugins/ChromecastPlugin/plugin.py', function onStart
2018-11-24 21:36:44.327 Error: (Chromecast status) ----> Line 359 in '/home/pi/domoticz/plugins/ChromecastPlugin/plugin.py', function createDevices-
mark.sellwood
A new field has been added "Domoticz url and port:" you need to fill this in. ie http://xxx.xxx.xxx.xxx:8080
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
dextm80
Yes, already did it but errors still remainsmark.sellwood wrote: Saturday 24 November 2018 23:07 A new field has been added "Domoticz url and port:" you need to fill this in. ie http://xxx.xxx.xxx.xxx:8080
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
nice plugin, happy with it!
One thing I wonder though: can't get the talking to work. After entering the text in the variable I heard the regular ding but no spoken text. The plugin did tell me name of the song being played though it is functioning.
Any idea how I could debug this?
Thanks for the plugin. I was also struggling to get it up and running.
For everyone having the list index errors please try the following.
- Ssh into your domoticz instance
- Execute `curl http://127.0.0.1:8080/json.htm`
When you get a 401 unauthorized, this is your problem. This means your domoticz instance cannot access the API without a username/password.
You can set this up in "Setup" -> "Local networks". Make sure you add 127.0.0.* there.
Try again using the the curl command. If you get a JSON response you can re-enable the chromecast plugin and it should start creating devices.
dextm80
for me not resolve problem, thanksbramski wrote: Sunday 25 November 2018 10:09 Thanks for the plugin. I was also struggling to get it up and running.
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
What is the output of the curl command?dextm80 wrote: Sunday 25 November 2018 10:32for me not resolve problem, thanksbramski wrote: Sunday 25 November 2018 10:09 Thanks for the plugin. I was also struggling to get it up and running.
dextm80
bramski wrote: Sunday 25 November 2018 10:34What is the output of the curl command?dextm80 wrote: Sunday 25 November 2018 10:32for me not resolve problem, thanksbramski wrote: Sunday 25 November 2018 10:09 Thanks for the plugin. I was also struggling to get it up and running.
"status" : "ERR"
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
