Telldus Termo/Hygro Sensor
kimhav
- Domoticz version: 2023.2
Has anyone been looking at getting the Telldus Termo/Hygro Sensor to work with Domotivz and RFXCom together? Quite sure that these sensors works with Domoticz but as far as I can see RFXCom isn't picking them up? As they've been around for 2 years, just wondering if there was any particular issue to get them to work or just that it was never requested.
b_weijenberg
- Target OS: -
Re: Telldus Termo/Hygro Sensor
This sensor should be received by the RFXtrx with the FineOffset protocol enabled.
Check with RFXmngr and enable only FineOffset and use the latest firmware.
Contact rfxcom support if the sensor is not received by your RFXtrx.
RFX-433, RFX-433EMC, RFX-868
kimhav
Thank You! Enabling FineOffset protocol did the trick to get them to work! So that was easy. Highly appreciated for the help!
