[REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
Re: [REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
I did a new install...
And again received errors...:
Nov 15 20:41:24 Domoticz.labots.nl systemd[1]: ikea-tradfri.service: Service hold-off time over, scheduling restart.
Nov 15 20:41:24 Domoticz.labots.nl systemd[1]: Stopped IKEA Tradfri COAP-adapter.
Nov 15 20:41:24 Domoticz.labots.nl systemd[1]: Started IKEA Tradfri COAP-adapter.
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: Unhandled Error
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: Traceback (most recent call last):
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: File "/home/pi/.local/lib/python3.5/site-packages/twisted/application/app.py", line 674, in run
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: runApp(config)
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: File "/home/pi/.local/lib/python3.5/site-packages/twisted/scripts/twistd.py", line 25, in runApp
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: runner.run()
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: File "/home/pi/.local/lib/python3.5/site-packages/twisted/application/app.py", line 381, in run
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: self.application = self.createOrGetApplication()
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: File "/home/pi/.local/lib/python3.5/site-packages/twisted/application/app.py", line 453, in createOrGetApplication
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: application = getApplication(self.config, passphrase)
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: --- <exception caught here> ---
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: File "/home/pi/.local/lib/python3.5/site-packages/twisted/application/app.py", line 464, in getApplication
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: application = service.loadApplication(filename, style, passphrase)
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: File "/home/pi/.local/lib/python3.5/site-packages/twisted/application/service.py", line 416, in loadApplication
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: application = sob.loadValueFromFile(filename, 'application')
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: File "/home/pi/.local/lib/python3.5/site-packages/twisted/persisted/sob.py", line 177, in loadValueFromFile
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: eval(codeObj, d, d)
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: File "/home/pi/domoticz/plugins/IKEA-Tradfri/tradfri.tac", line 34, in <module>
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: deviceConfig.read(INIFILE)
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: File "/usr/lib/python3.5/configparser.py", line 696, in read
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: self._read(fp, filename)
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: File "/usr/lib/python3.5/configparser.py", line 1108, in _read
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: raise e
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: configparser.ParsingError: Source contains parsing errors: '/home/pi/domoticz/plugins/IKEA-Tradfri/devices.ini'
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: [line 41]: '[]\n'
Nov 15 20:41:25 Domoticz.labots.nl twistd[969]: Failed to load application: Source contains parsing errors: '/home/pi/domoticz/plugins/IKEA-Tradfri/devices.ini'
Nov 15 20:41:25 Domoticz.labots.nl systemd[1]: ikea-tradfri.service: Main process exited, code=exited, status=1/FAILURE
Nov 15 20:41:25 Domoticz.labots.nl systemd[1]: ikea-tradfri.service: Unit entered failed state.
Nov 15 20:41:25 Domoticz.labots.nl systemd[1]: ikea-tradfri.service: Failed with result 'exit-code'.
Nov 15 20:41:26 Domoticz.labots.nl systemd[1]: ikea-tradfri.service: Service hold-off time over, scheduling restart.
Nov 15 20:41:26 Domoticz.labots.nl systemd[1]: Stopped IKEA Tradfri COAP-adapter.
Nov 15 20:41:26 Domoticz.labots.nl systemd[1]: ikea-tradfri.service: Start request repeated too quickly.
Nov 15 20:41:26 Domoticz.labots.nl systemd[1]: Failed to start IKEA Tradfri COAP-adapter.
Nov 15 20:41:26 Domoticz.labots.nl systemd[1]: ikea-tradfri.service: Unit entered failed state.
Nov 15 20:41:26 Domoticz.labots.nl systemd[1]: ikea-tradfri.service: Failed with result 'exit-code'.
At this point i had a look in devices.ini..., and the [] was there again.
Removed this line, and started the service again:
Nov 15 20:43:08 Domoticz.labots.nl systemd[1]: Started IKEA Tradfri COAP-adapter.
Nov 15 20:43:10 Domoticz.labots.nl twistd[1012]: 2018-11-15T20:43:09+0100 [-] Loading /home/pi/domoticz/plugins/IKEA-Tradfri/tradfri.tac...
Nov 15 20:43:10 Domoticz.labots.nl twistd[1012]: 2018-11-15T20:43:10+0100 [-] Loaded.
Nov 15 20:43:10 Domoticz.labots.nl twistd[1012]: 2018-11-15T20:43:10+0100 [twisted.scripts._twistd_unix.UnixAppLogger#info] twistd 18.9.0 (/usr/bin/python3 3.5.3) starting up.
Nov 15 20:43:10 Domoticz.labots.nl twistd[1012]: 2018-11-15T20:43:10+0100 [twisted.scripts._twistd_unix.UnixAppLogger#info] reactor class: twisted.internet.epollreactor.EPollReactor.
Nov 15 20:43:10 Domoticz.labots.nl twistd[1012]: 2018-11-15T20:43:10+0100 [-] AdaptorFactory starting on 1234
Nov 15 20:43:10 Domoticz.labots.nl twistd[1012]: 2018-11-15T20:43:10+0100 [builtins.AdaptorFactory#info] Starting factory <AdaptorFactory object at 0x75fd72f0>
Nov 15 20:43:21 Domoticz.labots.nl twistd[1012]: 2018-11-15T20:43:21+0100 [stdout#info] Connected from IPv4Address(type='TCP', host='127.0.0.1', port=45478)
Nov 15 20:44:36 Domoticz.labots.nl twistd[1012]: 2018-11-15T20:44:36+0100 [stdout#info] Error in announce: Request timed out
Nov 15 20:44:36 Domoticz.labots.nl twistd[1012]: 2018-11-15T20:44:36+0100 [stdout#info] Disconnected
Nov 15 20:44:51 Domoticz.labots.nl twistd[1012]: 2018-11-15T20:44:51+0100 [stdout#info] Connected from IPv4Address(type='TCP', host='127.0.0.1', port=45480)
Nov 15 20:45:26 Domoticz.labots.nl twistd[1012]: 2018-11-15T20:45:26+0100 [stdout#info] Error in announce: Request timed out
Nov 15 20:45:26 Domoticz.labots.nl twistd[1012]: 2018-11-15T20:45:26+0100 [stdout#info] Disconnected
Nov 15 20:45:41 Domoticz.labots.nl twistd[1012]: 2018-11-15T20:45:41+0100 [stdout#info] Connected from IPv4Address(type='TCP', host='127.0.0.1', port=45482)
Now it al seems to work..., but after a reboot the [] is again in the devices.ini
Did the trick of removing the [] again, and it works agian:
Nov 15 20:51:04 Domoticz.labots.nl systemd[1]: Started IKEA Tradfri COAP-adapter.
Nov 15 20:51:06 Domoticz.labots.nl twistd[932]: 2018-11-15T20:51:05+0100 [-] Loading /home/pi/domoticz/plugins/IKEA-Tradfri/tradfri.tac...
Nov 15 20:51:06 Domoticz.labots.nl twistd[932]: 2018-11-15T20:51:06+0100 [-] Loaded.
Nov 15 20:51:06 Domoticz.labots.nl twistd[932]: 2018-11-15T20:51:06+0100 [twisted.scripts._twistd_unix.UnixAppLogger#info] twistd 18.9.0 (/usr/bin/python3 3.5.3) starting up.
Nov 15 20:51:06 Domoticz.labots.nl twistd[932]: 2018-11-15T20:51:06+0100 [twisted.scripts._twistd_unix.UnixAppLogger#info] reactor class: twisted.internet.epollreactor.EPollReactor.
Nov 15 20:51:06 Domoticz.labots.nl twistd[932]: 2018-11-15T20:51:06+0100 [-] AdaptorFactory starting on 1234
Nov 15 20:51:06 Domoticz.labots.nl twistd[932]: 2018-11-15T20:51:06+0100 [builtins.AdaptorFactory#info] Starting factory <AdaptorFactory object at 0x75f502f0>
Nov 15 20:51:12 Domoticz.labots.nl twistd[932]: 2018-11-15T20:51:12+0100 [stdout#info] Connected from IPv4Address(type='TCP', host='127.0.0.1', port=40822)
Nov 15 20:51:25 Domoticz.labots.nl twistd[932]: 2018-11-15T20:51:25+0100 [stdout#info] Failed to connect to gateway: Request timeout
Nov 15 20:51:25 Domoticz.labots.nl twistd[932]: 2018-11-15T20:51:25+0100 [stdout#info] Disconnected
ok, nice, so there is no use for a zigbee stick and deconz , can ikea gateway also communicate with phillips hue?
You can use a Hue Bridge to control IKEA Tradfri bulbs, and I've seen some reports that it's possible to control HUE bulbs from the IKEA Gateway, but I haven't tried it myself, and I have no idea if it would work with this plugin, even though it might... Perhaps I should by a HUE bulb sometime and try...
Regards,
M
The underlying problem is that connection to the gateway times out. If you could try to stop domoticz, pull the latest development branch, run configure.py with the IP and master key. Then try a dry-run of the adapter:jakkes72 wrote: ↑Thursday 15 November 2018 20:52 I did a new install...
$ python3 tradfri.tac --dryrun
Regards,
M
pi@Domoticz:~/domoticz/plugins/IKEA-Tradfri $ python3 tradfri.tac --dryrun
IKEA-tradfri COAP-adaptor version 0.8.6 started (command line)!
Initializing gateway
Adding light with ID: 65542
Adding light with ID: 65545
Adding socket with ID: 65538
Adding light with ID: 65546
Adding light with ID: 65544
Adding light with ID: 65539
Adding light with ID: 65543
Device settings not found for . Creating defaults!
File "tradfri.tac", line 572, in <module>
endpoints.serverFromString(reactor, "tcp:1234").listen(AdaptorFactory()).addErrback(error)
File "tradfri.tac", line 309, in __init__
self.sendDeviceList(None)
File "tradfri.tac", line 427, in sendDeviceList
devices.append({"DeviceID": aDevice.deviceID, "Name": aDevice.deviceName, "Type": "Light", "Dimmable": stringToBool(deviceConfig[aDevice.modelNumber]['dimmable']), "HasWB": stringToBool(deviceConfig[aDevice.modelNumber]['haswb']), "HasRGB": stringToBool(deviceConfig[aDevice.modelNumber]['hasrgb'])})
File "/usr/lib/python3.5/configparser.py", line 956, in __getitem__
raise KeyError(key)
KeyError: ''
Something else...: I have a plug that is not currently accepted in Homekit... Could this be the device that gives the [] ??
Removed the plug, and a lamp that was disconnected voor a while... result:
Connected from IPv4Address(type='TCP', host='127.0.0.1', port=60300)
Data received: b'{"action": "initGateway", "pollinterval": "5", "groups": "False", "observe": "True"}'
Data received: b'{"action": "getLights"}'
Unhandled Error
File "/home/pi/.local/lib/python3.5/site-packages/twisted/python/log.py", line 103, in callWithLogger
return callWithContext({"system": lp}, func, *args, **kw)
File "/home/pi/.local/lib/python3.5/site-packages/twisted/python/log.py", line 86, in callWithContext
return context.call({ILogContext: newCtx}, func, *args, **kw)
File "/home/pi/.local/lib/python3.5/site-packages/twisted/python/context.py", line 122, in callWithContext
return self.currentContext().callWithContext(ctx, func, *args, **kw)
File "/home/pi/.local/lib/python3.5/site-packages/twisted/python/context.py", line 85, in callWithContext
return func(*args,**kw)
File "/home/pi/.local/lib/python3.5/site-packages/twisted/internet/posixbase.py", line 614, in _doReadOrWrite
why = selectable.doRead()
File "/home/pi/.local/lib/python3.5/site-packages/twisted/internet/tcp.py", line 243, in doRead
return self._dataReceived(data)
File "/home/pi/.local/lib/python3.5/site-packages/twisted/internet/tcp.py", line 249, in _dataReceived
rval = self.protocol.dataReceived(data)
File "tradfri.tac", line 97, in dataReceived
self.factory.sendDeviceList(self)
raise KeyError(key)
builtins.KeyError: ''
raise KeyError(key)
KeyError: ''
Unhandled Error
raise KeyError(key)
It looks like you have a device with a blank modelNumber, that's the reason for the [] in the device.ini file... I would guess it also is the reason the adapter fails, I've never seen a blank modelNumber before, and thus haven't implemented handling such a case...
Regards,
M
At this moment i have:
2 switches (round ones) (removed them now)
3 lamps
1 dimmer
No i have this output:
Connected from IPv4Address(type='TCP', host='127.0.0.1', port=60648)
Device settings not found for TRADFRI transformer 10W. Creating defaults!
{"action": "getLights", "result": [{"Type": "Light", "HasWB": false, "HasRGB": false, "Dimmable": true, "DeviceID": 65544, "Name": "TRADFRI bulb E14 W op/ch 400lm"}, {"Type": "Light", "HasWB": false, "HasRGB": false, "Dimmable": true, "DeviceID": 65545, "Name": "TRADFRI bulb E14 W op/ch 400lm 2"}, {"Type": "Light", "HasWB": true, "HasRGB": false, "Dimmable": true, "DeviceID": 65546, "Name": "Gordijnen"}, {"Type": "Light", "HasWB": true, "HasRGB": false, "Dimmable": true, "DeviceID": 65543, "Name": "Lamp Hal Douche"}], "status": "Ok"}
Announcing changed devices!
Disconnected
Connected from IPv4Address(type='TCP', host='127.0.0.1', port=60650)
{'action': 'deviceUpdate', 'result': [{'DeviceID': 65545, 'Name': 'TRADFRI bulb E14 W op/ch 400lm 2', 'Hex': None, 'State': True, 'Level': 199}], 'status': 'Ok'}
{'action': 'deviceUpdate', 'result': [{'DeviceID': 65546, 'Name': 'Gordijnen', 'Hex': None, 'State': True, 'Level': 216}], 'status': 'Ok'}
{'action': 'deviceUpdate', 'result': [{'DeviceID': 65544, 'Name': 'TRADFRI bulb E14 W op/ch 400lm', 'Hex': None, 'State': True, 'Level': 198}], 'status': 'Ok'}
{'action': 'deviceUpdate', 'result': [{'DeviceID': 65543, 'Name': 'Lamp Hal Douche', 'Hex': 'f1e0b5', 'State': False, 'Level': 254}], 'status': 'Ok'}
Data received: b'{"action": "announceChanged"}'
It seems it works! have to find out if the error is in one of the switches or in the lamps that are not connected now
Keep you informed!!!
3 lamps
1 dimmer
Disconnected
Hopefully somebody can help me here
For serveral days im struggeling with making tradfri working on my pi with domoticz. I followed the steps on https://github.com/moroen/IKEA-Tradfri-plugin. Nowhere i got an error
In the logging of the web GUI in domoticz i see nothing related to the plugin but the tradfri adapter is not showing in the hardware list.
On thing i doubt about is the user in the ikea-tradfri.service file. what should this be?
hopefully somebody can help me, thanks a lot!
pi@Domoticz:~/domoticz/plugins/IKEA-Tradfri $ ./configure.py 192.168.1.108 xxx --debug
Config created!
[Unit]
Description=IKEA Tradfri COAP-adapter
[Service]
Type=simple
ExecStart=/usr/local/bin/twistd --nodaemon \
--rundir=/home/pi/domoticz/plugins/IKEA-Tradfri \
--pidfile=/home/pi/domoticz/plugins/IKEA-Tradfri/twistd.pid \
--python=/home/pi/domoticz/plugins/IKEA-Tradfri/tradfri.tac
User=domoticz
Group=domoticz
Restart=always
[Install]
WantedBy=multi-user.target
After strugling around to get things working...
Finally managed to reproduce a working coppy
It seems that installing several programs (twisted, pytradfri etc.) are sensitive to the sudo command.
some do require it, while others don't seem to like it.
Have used a blank SD card with a fresh installation of Raspbian Lite, installation doen on a RPI2B and a RPI3B+
Please find the steps I have followed below:
Kind regards,
Thijs
This forum thread has been of great use, during trouble shootingRaspian Lite (Nov. 2018)
SD Card preparation:
1. Flash SD with Raspbian Lite
2. create a file ssh.txt (no contents needed) to enable ssh
Startup RPI - Putty for SSH connection:
1. sudo apt-get update
2. sudo apt-get upgrade
3. sudo apt-get install python3-pip autoconf libtool
4. curl –L install.domoticz.com | sudo bash
5. cd /home/pi/domoticz/plugins
6. git clone https://github.com/moroen/IKEA-Tradfri-plugin.git IKEA-Tradfri
7. cd IKEA-Tradfri
8. bash ./install-coap-client.sh
9. pip3 install pytradfri
10. sudo pip3 install twisted
11. pip3 install service-identity
12. ./configure.py IP KEY
13. python3 tradfri.tac
14. ./configure.py –skip-config –create-service
15. sudo cp ikea-tradfri.service /etc/systemd/system
16. sudo systemctl daemon-reload
17. sudo systemctl start ikea-tradfri.service
18. sudo systemctl enable ikea-tradfri.service
19. Reboot or Restart domoticz
NOTE: Wheb SD card is placed in another RPI, you will have to run step 12 again.
Kind regards,
Thijs
If the plugin is located in the correct folder (../domoticz/plugins/IKEA-Tradfri) but doesn't show up in the hardware list, the most common reason is that the python plugin framework is disabled. When starting domoticz, one of the first lines in the log should be:kteeven wrote: ↑Saturday 24 November 2018 22:35 Hopefully somebody can help me here
In the logging of the web GUI in domoticz i see nothing related to the plugin but the tradfri adapter is not showing in the hardware list.Code: Select all
pi@Domoticz:~/domoticz/plugins/IKEA-Tradfri $ ./configure.py 192.168.1.108 xxx --debug Config created!
2018-11-25 22:12:53.695 Status: PluginSystem: Started, Python version '3.x.x'.
That service file looks mostly fine, but are you running domoticz as a user called domoticz? It looks like you have domoticz installed as the pi user. The User and Group must match the user running domoticz.kteeven wrote: ↑Saturday 24 November 2018 22:35 On thing i doubt about is the user in the ikea-tradfri.service file. what should this be?
hopefully somebody can help me, thanks a lot!Code: Select all
[Unit] Description=IKEA Tradfri COAP-adapter [Service] Type=simple ExecStart=/usr/local/bin/twistd --nodaemon \ --rundir=/home/pi/domoticz/plugins/IKEA-Tradfri \ --pidfile=/home/pi/domoticz/plugins/IKEA-Tradfri/twistd.pid \ --python=/home/pi/domoticz/plugins/IKEA-Tradfri/tradfri.tac User=domoticz Group=domoticz Restart=always [Install] WantedBy=multi-user.target
Regards,
M
- Domoticz version: 4.10603
How did you managed to get it running on your Synology?MichaelvK wrote: ↑Sunday 09 September 2018 19:54 Thanks!
Got it working indeed , missed an update of Domoticz, but as this is handled as a package, had to pick a beta from Jadahl.
Great!
All I now have to figure out is to have the "python3 tradfri.tac" as a daemon / service on Synology.
Not as easy as it sounds..
Great stuff this plugin!!
Are you using Docker?
My NAS is unable to run Docker so i need to compile it on the NAS itself but that doesn't seem to be that straight forward as described in plugin readme.
- Domoticz version: 4.9992
I have installed the bunch which is needed, coap client, twisted and all. Then make sure you are on the later beta versions and follow the updated read.me from the beta release of the tradfri addin from moroen. At first I also was not running the python enabled version of Domoticz from jadahl.com.
Synology DS216+ & Domoticz as a Package (Jadahl)
connected:
Denon AVR2200W
Panasonic TX-L47ET60B
Doorbell Action
Several KAKU Action Flamingo's
Ali-Express WiFi cam
Ali-Express WiFi PTZ cam (soon)
Ali-Express PIR's
IKEA Trådfri
connected:
Denon AVR2200W
Doorbell Action
Ali-Express PIR's
IKEA Trådfri
After last message i start focussing on python part.
When i run
But when I try to install the tradfri
I tried to uninstall 3.4.2 version. but then Pip is not working anymore. and by installing this one again i got 3.4.2 for free
What do i do wrong???
When i run
pi@Domoticz:/ $ python3 -V
Python 3.5.2
sudo pip3 install pytradfri
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting pytradfri
Using cached https://www.piwheels.org/simple/pytradfri/pytradfri-6.0.1-py3-none-any.whl
pytradfri requires Python '>=3.5' but the running Python is 3.4.2
Today i started with a fresh install of domoticz and OS. I wish i did this before. it is now working.
Thanks anyhow!
Thanks anyhow!
Ahh, I was thinking of explaining my workaround, but thanks for your quick update.
I had experimented with docker, bootstrapping synology and all kind of other things, but at the end all got fixed in the current release.
(Otherwise you have symbolic linking to everywhere in order to get the correct version of python working, missing GCC compilers and all that crap..)
Good to know you succeeded as well!
connected:
Denon AVR2200W
Doorbell Action
Ali-Express PIR's
IKEA Trådfri
connected:
Denon AVR2200W
Doorbell Action
Ali-Express PIR's
IKEA Trådfri
- Domoticz version: 4.10266
I'm a newbe here on Domoticz. I had some experience with Pimatic before, but more and more interested in Domoticz for my new setup. I managed, after some trial and error, to install the Python script and the Tradfri lights are now up and running in my Domoticz. Works pretty well! (Thanks Moroen! )
There is one thing I don't like in the result: all my lights show up in the Domoticz devices list as two devices. All the lights have 1 dimmer switch and 1 selector switch for the color temperature. Even the type spot without color temperature has a selector for it. There is no combined switch for each light.
For instance: I have 12 spotlights (GU10) connected in the ceiling. They show up as 24 devices in my list. If i want to use a dimmer and set the color temperature, i end up with 24 switches in the interface .
Is there anyway two 'connect' these two switches (and devices) to one? I mean something like how the Philips Hue bulbs show up in the interface: 1 device with multiple settings.
Thanks for the advice!
Pieter
Pieter
Hardware RPi 3B+ / RFX433trxXL
Domoticz: 4.10266
Python: 3.5.3
RFX433trxXL
Domoticz: 4.10266
Python: 3.5.3
RFX433trxXL
I quite agree, the solution with two devices per light is far from ideal. The reason is that the plugin-framework doesn't provide a combined dimmer AND selector device-type, at least as far as I can tell. I haven't gotten around to dig into the code for defining device-types in order to implement a combined device.PieterKruithof wrote: ↑Sunday 09 December 2018 22:18 There is one thing I don't like in the result: all my lights show up in the Domoticz devices list as two devices. All the lights have 1 dimmer switch and 1 selector switch for the color temperature. Even the type spot without color temperature has a selector for it. There is no combined switch for each light.
As for the 12 spotlights, you could combine them into one or more groups using the Ikea Tradfri app, and enable "Add groups as devices". You'll still end up with all the devices in the device-list, but you would also get ONE device that controls all the lights as if they were one. Then you'll able to add this single device to your switches-page..
Regards,
M
- Involver
- Domoticz version: 3.4834
Hello All,
First a big thanks to all contributers to make the Tradfri plugin possible! I have been running the plugin for a few months now without too much issues (occasionally my gateway seems unresponsive to some of the dimmers). I've noticed that the plugin has been updated and I would like to update mine as well, but before I break anything; can someone please give a quick explanation on how to update from github? Can i just copy the new files (mainly the tradfri.tac and plugin.py).. much appreciated!
regards,
David
regards,
David
Domoticz - RPi - RFXCom - KaKu - Synology - HikVision - Oregon Scientific - YouLess - Anna
If you've installed the plugin using git, updating is quite simple. Stop domoticz, pull the changes and restart domotitcz:Involver wrote: ↑Monday 10 December 2018 15:50 Hello All,
regards,
David
$ sudo systemctl stop domoticz.service
$ cd domoticz/plugins/IKEA-Tradfri
$ git checkout master
$ git pull
$ sudo systemctl start domoticz.service
$ pip3 install --upgrade pytradfri
M
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
