Domotics touchscreen remote
- ledfreak3d
- Domoticz version: 3.8025
Re: Domotics touchscreen remote
I can help you with that send me an email and ill help you to get it working
Unleashe the magic smoke ;)
- ledfreak3d
basicly you can make the gui anything you like its not to hard to customize
but realy need some extra hands to get it the way i want.
might port it to the esp32 so it can go into very low power consumption mode
with a full charge i can keep it running for 14 hours but prety sure i cna get a lot more out of it
I have 3d Printed a case and its connected and working
I have renamed the buttons that i use and now i wanted to do some more changes in the Nextion Editor.
But i dont know to update on the Nextion.
After i made some changes like renaming a button, i click on compile and it says succesful with no errors.
Then i click upload(its com3) and there is: Connection Failed, Forced interrupt!
Dont know what im doing wrong....
Gesendet von iPhone mit Tapatalk
Found it
I must use the tft File not the hmi
- ledfreak3d
Hello!
I have a little problem .
It only works correctly when I load the firmware. As soon as I restart the D1 mini it seems as if it would not find a Wifi network (No SSID and No IP text will appear on the home screen). If I refill the firmware again, the correct SSID and IP address will appear as well as the switches react.
Please help!
Thanx
Best Regards
Csaba
Please help!
Thanx
Best Regards
Csaba
- ledfreak3d
That should not be to hard to fix ive not seen that issue before yet
