Mi-Light / LimitlessLED / Applamp
assenzuid
Re: Mi-Light / LimitlessLED / Applamp
I have an MI-Light WiFi box.
Today I was investigate my router / firewall logs and notice that the WiFi box sends information to 61.164.36.105 & 83.140.21.68
Current Firmware:V1.0.04a-JCY-1
See also: http://24-7-home-security...ds-network-packets-china/
My logs:
XXXXX@mainrouter:~$ sudo conntrack -L | grep "61.164.36.105"
udp 17 24 src=My WiFi IP box dst=61.164.36.105 sport=123 dport=123 [UNREPLIED] src=61.164.36.105 dst="MY WAN IP": sport=123 dport=123 mark=0 use=1
My logs:
poudenes
- Domoticz version: 3.8993
What i know only with V6 Box2
- elythomaslumber
- Domoticz version: 2023.1
...my old box ( V3 or V4) did that also because you can control it from outside your LAN via the mi-light APP. However I have blocked the ports.
DomoRies
Are there any problems with Milight and Domoticz?
I have a new installed Domoticz and i like to use Milight with it just like before. In hardware i put in the credentials but the devices are not created and added to Domoticz.
Domoticz Beta V3.9580
In hardware i have:
Enabled: yes
Type: Limitless/AppLamp/Mi Light with LAN/WiFi interface
Data Timeout: Disabled
Remote address: IP of the iBOX Controller (V6)
Port: 5987
Set Mode
Bridge Type: V6
Type: RGBWW
In the log there's only:
Status: AppLamp: Worker Started...
Status: AppLamp: Bridge found!...
Any ideas?
In hardware i have:
Enabled: yes
Port: 5987
Set Mode
Bridge Type: V6
Type: RGBWW
Any ideas?
DomoRies
DomoRies wrote: Thursday 07 June 2018 16:49 Are there any problems with Milight and Domoticz?
In hardware i have:
Enabled: yes
Port: 5987
Set Mode
Bridge Type: V6
Type: RGBWW
Any ideas?
Okay I've been busy for 3 hours but I can not get the lights to talk with Domoticz. I can control the lights via the app (milight 3.0). Hopefully someone has a clue.
I have no experience with Domoticz at all. The spent 3 hours are the first 3 hours that I spent on Domoticz. So I might overlook a basic option? ...
Hardware setup:
- 5W GUI10 RGBWW lamps
- Wifi iBox2
Domoticz
- Domoticz on Windows 10 notebook
- V4.9700
Domoticz hardware
- Accept new hardware devices = on
- Bridge type: v6 (v4/v5 tried too)
- Poort: 8899 & 5987 tried
- IPadress same as I use to configure the bridge
Domoticz devices:
- RGB & RGBWW tried
- Type: color switch
Domoticz switches
- Color switch, dimmer
Bridge setup
- Port: 8899 & 5987 tried
- Mode: STA
- Protocol: TCP-server
- Obtain an IP adress automatically: disabled
- Bridge connected with Smartlink.
LOG (part of)
2018-07-19 20:28:39.041 Status: EventSystem: reset all device statuses...
2018-07-19 20:28:41.489 Status: User: Admin initiated a switch command (1/AppLamp All/Set Level)
2018-07-19 20:28:47.749 (Milight) Color Switch (AppLamp All)
2018-07-19 20:28:50.141 Status: User: Admin initiated a switch command (1/AppLamp All/Set Level)
2018-07-19 20:28:56.379 (Milight) Color Switch (AppLamp All)
2018-07-19 20:29:08.728 Status: User: Admin initiated a switch command (7/AppLamp Group1/Set Level)
2018-07-19 20:29:11.868 (Milight) Color Switch (AppLamp Group1)
2018-07-19 20:29:12.407 Status: User: Admin initiated a switch command (1/AppLamp All/Set Level)
2018-07-19 20:29:15.539 (Milight) Color Switch (AppLamp All)
2018-07-19 20:29:17.442 Status: User: Admin initiated a switch command (7/AppLamp Group1/Set Level)
2018-07-19 20:29:20.578 (Milight) Color Switch (AppLamp Group1)
2018-07-19 20:29:21.114 Status: User: Admin initiated a switch command (2/AppLamp Group1/Set Level)
2018-07-19 20:29:24.244 (Milight) Color Switch (AppLamp Group1)
2018-07-19 20:29:30.983 Status: User: Admin initiated a switch command (11/AppLamp Bridge/Off)
2018-07-19 20:29:34.117 (Milight) Color Switch (AppLamp Bridge)
2018-07-19 20:29:36.693 Status: User: Admin initiated a switch command (6/AppLamp All/Off)
2018-07-19 20:29:39.820 (Milight) Color Switch (AppLamp All)
Hardware setup:
- Wifi iBox2
Domoticz
- V4.9700
Domoticz hardware
Domoticz devices:
- RGB & RGBWW tried
Domoticz switches
Bridge setup
- Mode: STA
LOG (part of)
hayman
- Domoticz version: 3.8153
hello ,
just want to know what the best setting for Milight V6 with GU10 (cctrgb)
know i have it like (RGBWW) and it's work fine,,,
but i see olso White with adjustable color !!!!! shall i switch to this one ... ?will it works better
i'm using Domoticz (nas) 49700
thanks
thanks
Melotron
- Domoticz version: 2020.2
Hiya.
The iBox2 works with my phone and I can turn off and on the light with out any problems.
The box are also added in the Domoticz without any problem.
But I cant turn on and off lights with it.
Here are the logs.
The configuration of the iBox2 are leaft alone.
The mode are set to V6 and White in hardware.
What am I missing here??
Regards Magnus Svensson
Here are the logs.
Domoticz V4.9700 (c)2012-2018 GizMoCuz
Build Hash: a3a45906, Date: 2018-06-23 16:24:51
System: Raspberry Pi
iBox 2 IP: 192.168.1.158
iBox 2 Port: 5987
Current version: V1.0.08
Work Mode: STA
2018-08-11 09:21:58.556 Status: New sensors allowed for 5 minutes...
2018-08-11 09:22:33.522 Status: AppLamp: Worker Started...
2018-08-11 09:22:40.525 Status: AppLamp: Worker stopped...
2018-08-11 09:22:40.556 Status: AppLamp: Worker Started...
2018-08-11 09:22:41.704 Status: AppLamp: Bridge found!...
2018-08-11 09:23:04.033 Status: User: Melotron initiated a switch command (633/AppLamp Group1/On)
2018-08-11 09:23:07.226 Status: User: Melotron initiated a switch command (633/AppLamp Group1/Off)The mode are set to V6 and White in hardware.
poudenes
Did you change the hardware mode to V6 instead if v4/5?
Verzonden vanaf mijn iPhone met Tapatalk Pro
Melotron
Yes its V6 and White.poudenes wrote: Saturday 11 August 2018 9:48 Did you change the hardware mode to V6 instead if v4/5?
Its a Single Color FUT036
Melotron
Its partly solved.
I need to pair the led with the first RGBWW controller in the box.
Then set it as RGBWW and then I can control it from Domoticz.
The big problem are that its a single color led stripe ww FUT036.
It will be really annoying to control it manually.
I don't want to make 3 scenes for it.
Anyway to get it t work as Type: White in the mode set?
What remote should I pair it with? I've tested all the white remotes in the app.
Is it already possible to control saturation in some sort of way? (GUI/Json API calls)
lukbe
Hello, work together milight Ls2 with Fut038 and fut092?
Thank you
Odesláno z mého MIX 2S pomocí Tapatalk
Thank you
tontze
- Domoticz version: Beta Ch
Hi !
Has anyone succeeded to turn milight RGBWW bulb 100% brightness with json command ? For me, it does light up something like 50% brightness :/
Trying to set up selectro switch. This is what i use as json command :
http://xxx.xxx.xxx.xxx:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=130&color={"m":1}&brightness=100-----------------------------------------
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- ledfreak3d
- Domoticz version: 3.8025
you can also just make a milight bridge your self
works perfectly fine and its very small and more options then the original one .
https://github.com/sidoh/esp8266_milight_hub
Unleashe the magic smoke ;)
poudenes
This selfmade bridge is so good!!! Use it for couple of months now. Have 36 bulbs add in the gui. Every bulb in its own group because you can create unlimited remotes. Now I have FULL control of every bulb. Or create some groups with multiple bulbs. Example all off to turn off the whole house in 1 action.ledfreak3d wrote:you can also just make a milight bridge your self
You will love this project and then you probably be Domoticz even more and see what you can do!!
Sky is the limit and keep up the good work!
- ledfreak3d
yep it sure is great and the firmware gets updated regularly
way beter then the original bridge
MpanosX
I have a Remote Controller FUT089 ( 8-Zone RGB+CCT )
I have made a milight bridge myself (https://github.com/sidoh/esp8266_milight_hub )
The esp8266_milight_hub has these options:
RGBW
CCT
RGB+CCT
RGB
FUT089 / B8
FUT091 /B2
I believe that domoticz only supports the first 4 options and also allow 4 zones.
The other two that support 8 zones are not working for me.
Can someone help me setup a working domoticz + esp8266_milight_hub like a FUT089 with 8 zones ?
RGBW
CCT
RGB+CCT
RGB
FUT089 / B8
FUT091 /B2
poudenes
Only the first 4 is usable in Domoticz. Create a second remote to get again 4 groups.. Etc
You can create as many remotes so easy. Give every remote his own port and add them sepereate in domitcz
Here have 8 hardware devices with 8 different ports to same ip number
MpanosX
Thank you for the answer but it is not working for me. It just solves the 4 to 8 zones problem
My problem to power on or power off my led controller ( LS2 ) not working.
I gave you a debug sniffing example of the commands power on and off of both sides
* power on from milight hub emulator web interface
fut089 packet received (9 bytes):
Raw packet: 64 74 AD 73 BA 25 6B BA A0
Decoded:
Key : 64
b1 : 25
Command : 01
Argument : 01
Sequence : 6D
Group : 01
Checksum : 35
* power off from milight hub emulator web interface
Raw packet: 7C 5C E5 AB E2 52 60 E2 B6
Decoded:
Key : 7C
b1 : 25
Command : 01
Argument : 0A
Sequence : 6E
Group : 01
Checksum : 67
* power On domoticz
rgb_cct packet received (9 bytes):
Raw packet: 00 DB 69 27 66 D1 B8 66 28
Decoded:
Key : 00
b1 : 20
Command : 01
Argument : 01
Sequence : 02
Group : 01
Checksum : 71
* power Off from domoticz
Raw packet: 00 DB 69 27 66 CA B9 66 22
Decoded:
Key : 00
b1 : 20
Command : 01
Argument : 06
Sequence : 03
Group : 01
Checksum : 77
Decoded:
Key : 64
b1 : 25
Command : 01
Argument : 01
Sequence : 6D
Group : 01
Checksum : 35
Decoded:
Key : 7C
b1 : 25
Command : 01
Argument : 0A
Sequence : 6E
Group : 01
Checksum : 67
* power On domoticz
Decoded:
Key : 00
b1 : 20
Command : 01
Argument : 01
Sequence : 02
Group : 01
Checksum : 71
Decoded:
Key : 00
b1 : 20
Command : 01
Argument : 06
Sequence : 03
Group : 01
Checksum : 77
