I have a Qnap nas with two Hikvision camera's connected to surveillance station.
In surveillance station I created an event when motion is detected on the camera's
The camera's are also available in Domoticz. I don't want to use motion in my raspberry.
Because I am planning to use more than two camera's.
My goal is to use a user defined action from Qnap surveillance station to activate a light switch in Domoticz.
Surveillance station is able to sent an http URL.
Does anybody knows what URL or script must be send to Domoticz.
Any help appriciated.
Regards, Albert
Switching lightbulbs with camera motion detection
- bewo
- Domoticz version: 2021.1
Re: Switching lightbulbs with camera motion detection
Individual projects:
Domoticz on a Intel Xeon Server | AeonLabs Z-Wave Gen.5 | RFXCOM RFXtrx433E USB | ESP-Wifi-Modules | Shellys
Wall-mounted 22" Touch Control Display (self construct) | LUA wind monitor| LUA heating control | and many many more :)
amizee
Search the wiki.
Found the Solutions.
Cheers.
Cheers.
amizee
Solved,
This is the solution for my Hikvision camera on my Qnap with QVRPro
Place this string in your security camera event action
http://admin:[email protected] ... itchcmd=On
If the switch is secured no password is needed
http://192.168.178.32:8080/json.htm?typ ... itchcmd=On
Place you IDX number after idx=
Place this command in your switch in the "on action" field
ISAPI/Streaming/channels/101/picture?
Regards, Albert
Regards, Albert
