Read digital inputs / write digital outputs of a nano via ethernet
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
A cable is present. I want to use PoE (nano + W5100 ethernet shield), which means that I only need one UPS for the whole installation.
For reading the status of contacts I use the following code (thanks to fabalci see viewtopic.php?f=56&t=19870&p=192478#p192428 ) This code works very well.
// Schuur DOMOTICZ Connection
// fabalci zie Domoticz forum
// SPI and Ethernet is needed for Ethernet shield
#include <SPI.h>
#include <Ethernet.h>
//DEBUG 1 Sends output to SerialPort
#define DEBUG                   1
#define OPEN                    1     // HIGH
#define CLOSED                  0     // LOW
#define UNKNOWN                 2     // --- reset / force update
//INPUT PIN Numbers on Arduino
#define PIN_deurcontact_schuur        2
#define PIN_PIR_schuur                     3
#define PIN_PIR_tuin                         4
// Last Status of the Sensors
int deurcontact_schuurStatus  =     UNKNOWN;
int PIR_schuurStatus =              UNKNOWN;
int PIR_tuinStatus =                UNKNOWN;
// IDX numbers of PIR and Magnetc Contacts on Domoticz-Devices Page
int IDX_deurcontact_schuur =   7;
int IDX_PIR_schuur =                8;
int IDX_PIR_tuin =                    9;
// Arduino MAC and IP addresses
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0x34, 0x39, 0x01
};//Random address
IPAddress ip(192, 168, 0, 118); //IP Address of Arduino
IPAddress domoticz(192, 168, 0, 12); // Domoticz IP Address
int port = 8080; // Domoticz Port No
EthernetClient client;
//httprequest functions, sends status info to Domoticz
// /json.htm?type=command&param=switchlight&idx=XX&switchcmd=On
void httpRequestswitch(int IDX, String status) {
  // When the connection is successful:
  if (client.connect(domoticz, port)) {
#if DEBUG
    Serial.print("GET /json.htm?type=command&param=switchlight&idx=");
    Serial.print(IDX);
    Serial.print("&switchcmd=");
    Serial.println(status);
#endif
    client.print( "GET /json.htm?type=command&param=switchlight&idx=");
    client.print(IDX);
    client.print("&switchcmd=");
    client.print(status);
    client.println( " HTTP/1.1");
    client.print( "Host: ");
    client.println(ip);
    client.println( "Connection: close");
    client.println();
    client.println();
    client.stop();
    delay(150);
  else {
    client.stop();
void httpRequestvalue(int IDX, float value) {
#if DEBUG
    Serial.print("GET /json.htm?type=command&param=udevice&idx=");
    Serial.print(IDX);
    Serial.print("&nvalue=0&svalue=");
    Serial.println(value, 1);
#endif
    client.print( "GET /json.htm?type=command&param=udevice&idx=");
    client.print(IDX);
    client.print("&nvalue=0&svalue=");
    client.print(value, 1);
    client.println(ip);
    client.println();
    client.println();
    client.stop();
    delay(150);
  else {
    client.stop();
int contactState(int pin)
  // LOW  -> CLOSED
  // HIGH -> OPEN
  return (digitalRead(pin) == HIGH) ? OPEN : CLOSED;
void updateContactStatus()
  int currentStatus;
  const char* msg = NULL;
  currentStatus = contactState(PIN_deurcontact_schuur);
  if (deurcontact_schuurStatus != currentStatus)
    deurcontact_schuurStatus = currentStatus;
    if (deurcontact_schuurStatus == CLOSED) msg = "Off";
    else                     msg = "On";
    httpRequestswitch(IDX_deurcontact_schuur, msg);
    return; // only one message per loop
  currentStatus = contactState(PIN_PIR_schuur);
  if (PIR_schuurStatus != currentStatus)
    PIR_schuurStatus = currentStatus;
    if (PIR_schuurStatus == CLOSED) msg = "Off";
    else                     msg = "On";
    httpRequestswitch(IDX_PIR_schuur, msg);
  currentStatus = contactState(PIN_PIR_tuin);
  if (PIR_tuinStatus != currentStatus)
    PIR_tuinStatus = currentStatus;
    if (PIR_tuinStatus == CLOSED) msg = "Off";
    else                     msg = "On";
    httpRequestswitch(IDX_PIR_tuin, msg);
void setup() {
  pinMode(PIN_deurcontact_schuur , INPUT);
  pinMode(PIN_PIR_schuur , INPUT);
  pinMode(PIN_PIR_tuin , INPUT);
#if DEBUG
  Serial.begin(9600);
  Serial.println("Arduino Schuur - Domoticz Connection");
#endif
  Ethernet.begin(mac, ip);
#if DEBUG
  Serial.print("Arduino IP addresss: ");
  delay(1000);
  Serial.println(ip);
#endif
void loop()
  updateContactStatus();
I would like to operate 3 relays with the same Nano. I hope someone is willing to help me with an appropriate code.
Thanks in advance
freijn
Re: Read digital inputs / write digital outputs of a nano via ethernet
Post by freijn »
Jan Jansen
@freijn, thanks for your answer.
Espeasy is easy indeed. However, I prefer wired solutions where possible. In addition, I want to gain more knowledge about communication between an arduino, its sensors and actuators and Domoticz. For me that is a lot of searching, reading, cutting, pasting and trial and error.
As said in my first post, I can read the digital inputs (high speed, that’s nice when a door sensor is involved).
Domoticz offers the possibility to switch relays via a http request. In Domoticz each switch has a field for on or off action.
On the web I find examples by which you can control relays (via ethernet) that are connected to an arduino. After connecting to the arduino via a browser, buttons are displayed. With this buttons you can then switch relays on or off. I get stuck when merging the sketch for reading the inputs and the sketch for writing the outputs. I need some help.
Thanks in advance.
febalci
Post by febalci »
Reading sensors with arduino is easy. Setting output is also easy, but setting the relays according to the last status of the relay (If it is off then set it on, if it is on then set it off) you need to read the switch status from domoticz. This needs json parsing and you need arduino json library. HAven't worked on it yet but as i see setting the relays from arduino is much more easier with using mysensors.
