Will do but still traveling so please don't expect anything until late next weekHuntback wrote: Friday 14 September 2018 12:36.. So would you please, if you have time for it, take a to look at the script so that this can also work for https://afvalkalender.circulus-berkel.nl?waaren wrote: Tuesday 11 September 2018 21:24Good to read. Can you please share your solution for the benefit of other forum users ?Superpjeter wrote: Tuesday 11 September 2018 19:42 Thanks for your offer but I already figured it out
Thx
dzVents get garbage collection dates (various) [SOLVED]
- waaren
Re: dzVents get garbage collection dates from inzamelkalender.hvcgroep.nl
- waaren
Some adjustments were needed to the original script because circulus-berkel return a JSON that must be reformatted before it can be used as a Lua table with consecutive record numbers.Huntback wrote: Friday 14 September 2018 12:36 So would you please, if you have time for it, take a to look at the script so that this can also work for https://afvalkalender.circulus-berkel.nl?
Also introduced an extra initial step to get the bagId automatically based on zipCode / houseNumber
Could you please test this and report your findings ?
--[[ getGarbageDates.lua for [ dzVents >= 2.4 ]
this script is only useful in those areas of the Netherlands where circulus-berkel is the garbage collector
Enter your zipcode and housenumber and your virtual text and or virtual alert device in the
appropriate place between the lines starting with --++++
the text device will contain the most nearby collectdates for the four types of household garbage
the alert device will contain the date and type for the garbagecollection that will arrive first
local prefix = "getGarbageDates"
local httpresponse = prefix .. "Response"
local triggerDevice = prefix .. "Trigger"
local logMarker = prefix .. "Marker"
return
on = { devices = { triggerDevice }, -- Just for development and test ; ignored when live
timer = { "at 00:05","at 08:00" }, -- daily run twice
httpResponses = { httpresponse } -- Trigger the handle Json part
-- logging = { level = domoticz.LOG_DEBUG, -- Remove the "-- at the beginning of this and next line for debugging the script
-- marker = logMarker },
data = { garbage = { initial = {} }, -- Keep a copy of last json just in case
bagID = { initial = "Not set yet" },
ZipCode = { initial = "not set yet" },
HouseNumber = { initial = "not set yet" },
execute = function(dz, triggerObject)
--++++--------------------- Mandatory: Set your values and device names below this Line --------------------------------------
local myZipCode = "7328CK"
local myHouseNumber = 46
local myTextDevice = "GarbageText" -- Name with quotes or idx without when created as virtual text device
local myAlertDevice = "GarbageAlert" -- Name with quotes or idx without when created as virtual alert device
--++++---------------------------- Set your values and device names above this Line --------------------------------------------
local myProvider = "https://afvalkalender.circulus-berkel.nl"
local myYear = os.date("%Y")
garbageTypes = {13,7,8,10} -- Valid for circulus-berkelfor but these numbers vary per garbageCollector; Why ??
-- ("13"," Boeken, Elektrische apparaten, Speelgoed en Textiel ")
-- ("7"," Groente-, fruit- en tuin afval ")
-- ("10"," Papier en kartonnen verpakkingen ")
-- ("8"," Restafval ")
-- get BagId based on Zipcode / Housenumber
local function collectBagId(secondsFromNow)
local getBagId_url = myProvider .. "/rest/adressen/" .. myZipCode .."-" .. myHouseNumber
dz.openURL ({ url = getBagId_url ,
method = "GET",
callback = httpresponse}).afterSec(secondsFromNow)
-- get garbage collect Year calendar
local function collectGarbageDates(secondsFromNow)
local getGarbage_url = myProvider .. "/rest/adressen/" .. dz.data.bagID .. "/kalender/" .. myYear
dz.openURL ({ url = getGarbage_url ,
method = "GET",
-- Add entry to log and notify to all subsystems
local function errorMessage(message)
dz.log(message,dz.LOG_ERROR)
dz.notify(message)
local function string2Epoch(dateString) -- seconds from epoch based on stringdate (used by string2Date)
-- Assuming a date pattern like: yyyy-mm-dd
local pattern = "(%d+)-(%d+)-(%d+)"
local runyear, runmonth, runday= dateString:match(pattern)
local convertedTimestamp = os.time({year = runyear, month = runmonth, day = runday})
return convertedTimestamp
local function string2Date(str,fmt) -- convert string from json into datevalue
if fmt then return os.date(fmt,string2Epoch(str)) end
return os.date(" %A %d %B, %Y",string2Epoch(str))
local function alertLevel(delta)
if delta < 2 then return dz.ALERTLEVEL_RED end
if delta < 3 then return dz.ALERTLEVEL_YELLOW end
if delta < 4 then return dz.ALERTLEVEL_ORANGE end
return dz.ALERTLEVEL_GREEN
local function setGarbageAlertDevice(alertDevice,alertText,alertDate)
local delta = tonumber(string2Date(alertDate,"%d")) - tonumber(os.date("%d")) -- delta in days between today and first garbage collection date
dz.devices(alertDevice).updateAlertSensor(alertLevel(delta),alertText)
return (delta == 0)
local function longGarbageName(str) -- Use descriptive strings
str = tostring(str)
str = str:gsub("13"," Boeken, Elektrische apparaten, Speelgoed en Textiel ")
str = str:gsub("7"," Groente-, fruit- en tuin afval ")
str = str:gsub("10"," Papier en kartonnen verpakkingen ")
str = str:gsub("8"," Restafval ")
return str
-- extract bafId from json and store in persistent data
local function getBagID()
rt = dz.utils.fromJSON(triggerObject.data)
dz.data.bagID = rt[1].bagId
collectGarbageDates(1)
local function handleResponse()
dz.log(dz.data.bagID,dz.LOG_DEBUG)
if dz.data.bagID == "Not set yet" then
getBagID()
return
rt , rtRaw = {}
rtRaw = dz.utils.fromJSON(triggerObject.data) -- dzVents does nor recognize the response as pure JSON so conversion is required
if rtRaw["1"] ~= nil then
for k, v in pairs(rtRaw) do -- Extra step is necessary because json is not standard and some records are missing
table.insert( rt, { ophaaldatum = v.ophaaldatum , afvalstroom_id = v.afvalstroom_id })
dz.data.garbage = rt
errorMessage("Problem with response from (no data) using data from earlier run")
rt = dz.data.garbage -- json empty. Get last valid from dz.data
if #rt < 1 then -- No valid data in dz.data either
errorMessage("No previous data. are zipcode and housenumber ok and in circulus-berkel area?")
return false
local garbageLines = ""
local typeEarliestDate
local typeEarliestKind
local overallEarliestDate = "2999-12-31" -- Hopefully we will have a different garbage collection system by then
local garbageToday = false
local today = os.date("%Y-%m-%d")
for i = 1,#garbageTypes do --walk the the type Table
dz.log("Checking " .. garbageTypes[i],dz.LOG_DEBUG)
typeEarliestDate = "2999-12-31"
for j = 1, #rt do -- walk the result Table
-- walk the response table
if rt[j].ophaaldatum >= today and rt[j].ophaaldatum < typeEarliestDate and
rt[j].afvalstroom_id == garbageTypes[i] then -- Keep date closest to today per type
typeEarliestDate = rt[j].ophaaldatum
typeEarliestKind = rt[j].afvalstroom_id
if typeEarliestDate < overallEarliestDate then -- date closest to today overall ?
overallEarliestDate = typeEarliestDate -- keep date
overallEarliestType = garbageTypes[i] -- keep type
garbageLines = garbageLines .. string2Date(typeEarliestDate,"%a %e %b" ) .. longGarbageName(typeEarliestKind) .. " " .. "\n"
if myAlertDevice then -- Update AlertDevice with nearby date / type
garbageToday = setGarbageAlertDevice( myAlertDevice,
longGarbageName(overallEarliestType) .. "\n" ..
string2Date(overallEarliestDate),
if myTextDevice then -- Update defined virtual text device with dates / types
dz.devices(myTextDevice).updateText(garbageLines)
if dz.time.matchesRule("at 08:00-17:00") and garbageToday then
dz.notify(longGarbageName(overallEarliestType) .. "will be collected today")
-- Main
if triggerObject.isHTTPResponse then
if triggerObject.ok then
handleResponse()
errorMessage("Problem with response from " .. myProvider .. " (not ok)")
collectGarbageDates(600) -- response not OK, try again after 10 minutes
if dz.data.bagID == "Not set yet" or dz.data.ZipCode ~= myZipCode or dz.data.HouseNumber ~= myHouseNumber then
-- Initial or something changed in zipCode / HouseNumebr
dz.data.ZipCode = myZipCode
dz.data.HouseNumber = myHouseNumber
dz.data.bagID = "Not set yet"
collectBagId(1)
}Debian buster, bullseye on RPI-4, Intel NUC.
Huntback
- Domoticz version: 2024.2
Re: dzVents get garbage collection dates (various)
hello waaren,
The script is now working
'myTextDevice' and 'myAlertDevice' were updated immediately.
First garbage collection day is here next Thursday, on that day also the notification in the 'myAlertDevice' must be updated with "will be collected today".
I now assume that this also works.
If not or with other problems with the script then I report again.
For now thank you very much for the quick response and the modification of the script.
Synology - DS918+
RFXCOM - RFXtrx433XL (LAN)
Oregon - Weatherstation
Some KAKU, Impuls, TFA, etc.
delcara
- Domoticz version: 4.10171
Hello Waaren,
I'm trying to create a script to get garbage collection dates from ROVA. I've discovered how to get the dates through a curl command. But I've no idea how to translate this to a dzVents script. I've just started with DzVents and have now translated all my blockly to DzVents (relatively simple scripts to control lights etc.). Can you help to translate this curl command to a DzVents script?
Then the output lookes like this:
The ID can be everything doesn't matter if I change this, I still got the correct dates for my address.
curl -v --cookie "RovaLc_inwoners={\"Id\":160267,\"ZipCode\":\"8103JB\",\"HouseNumber\":\"15\",\"HouseAddition\":null,\"Municipality\":\"Raalte\",\"Province\":null,\"Firstname\":null,\"Lastname\":null,\"UserAgent\":\"\",\"School\":null,\"Street\":null,\"Country\":null,\"Portal\":null,\"AreaLevel\":5,\"City\":\"Raalte\",\"Ip\":null}" https://www.rova.nl/api/TrashCalendar/GetCalendarItems?portal=inwoners
* Trying 141.138.194.225...
* TCP_NODELAY set
* Connected to www.rova.nl (141.138.194.225) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
* CAfile: /etc/ssl/certs/ca-certificates.crt
CApath: /etc/ssl/certs
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES256-SHA384
* ALPN, server did not agree to a protocol
* Server certificate:
* subject: CN=www.rova.nl
* start date: Oct 30 06:51:49 2018 GMT
* expire date: Jan 28 06:51:49 2019 GMT
* subjectAltName: host "www.rova.nl" matched cert's "www.rova.nl"
* issuer: C=US; O=Let's Encrypt; CN=Let's Encrypt Authority X3
* SSL certificate verify ok.
> GET /api/TrashCalendar/GetCalendarItems?portal=inwoners HTTP/1.1
> Host: www.rova.nl
> User-Agent: curl/7.52.1
> Accept: */*
> Cookie: RovaLc_inwoners={"Id":160267,"ZipCode":"8103JB","HouseNumber":"15","HouseAddition":null,"Municipality":"Raalte","Province":null,"Firstname":null,"Lastname":null,"UserAgent":"","School":null,"Street":null,"Country":null,"Portal":null,"AreaLevel":5,"City":"Raalte","Ip":null}
< HTTP/1.1 200 OK
< Cache-Control: no-cache
< Pragma: no-cache
< Content-Type: application/json; charset=utf-8
< Expires: -1
< Server: Microsoft-IIS/8.5
< X-AspNet-Version: 4.0.30319
< X-Powered-By: ASP.NET
< Date: Wed, 07 Nov 2018 10:20:55 GMT
< Content-Length: 286
* Curl_http_done: called premature == 0
* Connection #0 to host www.rova.nl left intact
[{"GarbageTypeCode":"GFT","GarbageType":"GFT","Date":"2018-11-12T00:00:00","Regular":true},{"GarbageTypeCode":"REST","GarbageType":"Restafval","Date":"2018-11-16T00:00:00","Regular":true},{"GarbageTypeCode":"PLASTICPLUS","GarbageType":"PMD","Date":"2018-11-19T00:00:00","Regular":true}]Raspberry pi 3, Domoticz Beta, Nginx, dzVents 2.7.4, RFXtrx433e, P1 smart meter, Harmony, Hue, Zwave, Amazon echo, Sonos, Synology DS413, HomeBridge, HA Bridge, Ubiquiti.
- waaren
Just sent a PM
- waaren
Please have a look at the script below.delcara wrote: Wednesday 07 November 2018 11:24 I'm trying to create a script to get garbage collection dates from ROVA. I've discovered how to get the dates through a curl command. But I've no idea how to translate this to a dzVents script. I've just started with DzVents and have now translated all my blockly to DzVents (relatively simple scripts to control lights etc.). Can you help to translate this curl command to a DzVents script?
I tried to translate the curl command into a domoticz.openUrl but I failed in finding the working syntax (the cookie table seems to mess up the openUrl internally). If someone else has found a solution for this I would be much obliged if that solution could be shared here.
So had to use the curl command itself. To ensure that a wait time for the JSON return would not stall the event thread, the command is processed in the background and the script will come back every couple of seconds to check if it is already there.
(In practice I have not seen that the return have taken more then 2 seconds, but just to be sure)
--[[ getGarbage.lua for [ dzVents >= 2.4 ]
this script is only useful in those areas of the Netherlands where the household garbage collector is rova
Tested on debian stretch but probably also working on other Linux variants.
needs curl command
needs to be able to process commands in the background ( by using leading &)
Enter your zipcode, housenumber and garbageID in the appropriate places between the lines starting with -- ***
Next is to set your virtual text and or virtual alert device.
the text device will contain the most nearby collectdates for the types of household garbage
notification system will be called when collect will be today
on = { timer = { "at 00:05","at 08:00" }, -- daily run twice
devices = { "getGarbage" }, -- Ignore just for test
httpResponses = { "delay_Response" }, -- (re)triggers the script
logging = { level = domoticz.LOG_DEBUG , -- Change to ERROR when script is behaving as expected
marker = ""}, -- Will be set in execute = function block
data = { delay = { initial = 0 },
execute = function(dz, item, info)
-- ************************* Mandatory: Set your values and device names below this Line
local myZipcode = "0000AA" -- Your zipcode like "3085RA"
local myHousenumber = "99" -- Your housenumber like 38
local myGarbageID = "9999999" -- Your GarbageID
-- **************************************************************** No changes required below this
local initialDelay = 2
local repeatDelay = 10
local maxDelay = 60
local outFile = "/tmp/garbageCollectionDates.json"
local catCommand = "cat"
_G.logMarker = info.scriptName -- sets the logmarker for dz.log
local function logWrite(str,level)
dz.log(str,level or dz.LOG_DEBUG)
local function setGarbageAlertDevice(alertDevice,alertText, delta)
return (delta == 0)
str = tostring(str)
str = str:gsub("PMD"," Plastic verpakkingen, blik en drinkpakken ")
str = str:gsub("GFT"," Groente-, fruit- en tuin afval ")
str = str:gsub("Restafval" ," Restafval ")
return str
local function retriggerAfterSec(seconds)
dz.openURL({
url = dz.settings['Domoticz url'] .. "/json.htm?type=command¶m=getversion",
method = "GET",
callback = "delay_Response" }).afterSec(seconds)
local function osCommand(cmd)
local fileHandle = assert(io.popen(cmd, 'r'))
local commandOutput = assert(fileHandle:read('*a'))
local returnTable = {fileHandle:close()}
return commandOutput,returnTable[3] -- rc[3] contains returnCode
function makeTimeStamp(dateString)
local pattern = "(%d+)%-(%d+)%-(%d+)T(%d+):(%d+):(%d+)"
local xyear, xmonth, xday, xhour, xminute, xseconds = dateString:match(pattern)
local convertedTimestamp = os.time({year = xyear, month = xmonth, day = xday, hour = xhour, min = xminute, sec = xseconds})
local function procesJSON(resultJSON)
keep = {}
rt = dz.utils.fromJSON(resultJSON)
local earliestDate = "2999-12-31" -- Hopefully we will have a different garbage collection system by then
for i = 1,#rt do
local fmtDate = os.date(" %A %d %B, %Y", makeTimeStamp(rt[i].Date))
if rt[i].Date >= today and rt[i].Date < earliestDate then
keep.Date = rt[i].Date
keep.fmtDate = fmtDate
keep.GarbageType = longGarbageName(rt[i].GarbageType)
earliestDate = rt[i].Date
garbageLines = garbageLines .. fmtDate .. longGarbageName(rt[i].GarbageType) .. " " .. "\n"
local delta = os.date("%d",tonumber(makeTimeStamp(keep.Date))) - os.date("%d")
garbageToday = setGarbageAlertDevice( myAlertDevice, keep.GarbageType .. "\n" .. keep.fmtDate, delta )
dz.notify(keep.GarbageType .. "will be collected today")
local function triggerCurlInBackGround()
local curlCommand = "curl -v --cookie"
local curlCookie = 'RovaLc_inwoners={' ..
'\\"Id\\":' .. myGarbageID .. ',' ..
'\\"ZipCode\\":\\"' .. myZipcode .. '\\",' ..
'\\"HouseNumber\\":\\"' .. myHousenumber .. '\\"}'
local curlHTTP = "https://www.rova.nl/api/TrashCalendar/GetCalendarItems?portal=inwoners"
local backGround = " & " -- We don't want the script to wait for the result so process curl in background
getGarbageCollectionDatesCommand = curlCommand .. " " .. curlCookie .. " " .. curlHTTP .. " > " .. outFile .. backGround
osCommand(getGarbageCollectionDatesCommand)
local function waitForAndProcessResult()
local result, returnCode = osCommand(catCommand .. " " .. outFile) -- is the output there ?
if returnCode == 0 then -- Yes
-- logWrite(result)
osCommand("rm " .. outFile)
procesJSON(result)
else -- Not yet. Come back in repeatDelay seconds
logWrite("No result yet")
dz.data.delay = dz.data.delay + repeatDelay -- Keep track of the delays
if dz.data.delay > maxDelay then
logWrite("We are waiting > maxDelay seconds for the result. Giving up now",dz.LOG_ERROR)
retriggerAfterSec(repeatDelay)
-- main
if item.isDevice or item.isTimer then
retriggerAfterSec(initialDelay) -- We will come back in initialDelay seconds to check if output has already arrived
dz.data.delay = initialDelay
delcara
Thnx! Just read your PM and you're answer is already here. I'm going to try the script when i'm home tonight. Nice thinking and a creative solution!
akamming
Hi,delcara wrote: Wednesday 07 November 2018 11:24 Hello Waaren,
i was working on the same thing. a few weeks ago i created my own dzvents script for the ROVA afvalkalender. This one hopefully works for you!
timer = {
'at 20:00', -- The notification will be sent at this time on the day before ROVA arrives
'every 8 hours' , -- Update frequency of the virtual device
logging = {
level = domoticz.LOG_DEBUG, -- adjust to your needs
marker = "Rova"
-- The name of your virtual text device which will contain the Afvalkalender
local DeviceName="Rova Afvalkalender"
-- Adress vars
local ZipCode="8103JB"
local HouseNumber="15"
local HouseAddition="null"
local Municipality="Raalte"
-- Notification params
local NotifyTitle="Rova"
local NotifyLine1="Zet container bij de weg, "
local NotifyLine2=" wordt opgehaald op "
-- Get ROVA kalender by accessing the API using curl
local command = 'curl --cookie "RovaLc_inwoners={\\"Id\\":160266,\\"ZipCode\\":\\"'..ZipCode..'\\",\\"HouseNumber\\":\\"'..HouseNumber..'\\",\\"HouseAddition\\":'..HouseAddition..',\\"Municipality\\":\\"'..Municipality..'\\",\\"Province\\":null,\\"Firstname\\":null,\\"Lastname\\":null,\\"UserAgent\\":\\"\\",\\"School\\":null,\\"Street\\":null,\\"Country\\":null,\\"Portal\\":null,\\"AreaLevel\\":5,\\"City\\":\\"Zwolle\\",\\"Ip\\":null}" https://www.rova.nl/api/TrashCalendar/GetCalendarItems?portal=inwoners'
domoticz.log("Command is ["..command.."]",domoticz.LOG_DEBUG)
local handle=io.popen(command..' || echo error')
local result = handle:read("*a")
handle:close()
-- For debugging purposes: Log result
domoticz.log ("JSON output Rova is "..result, domoticz.LOG_DEBUG)
if(result ~= 'error\n') then
-- convert JSON object to readable format
local json = domoticz.utils.fromJSON(result)
-- convert dates
local RovaDate=string.sub(json[1].Date,1,-10)
local RovaDate2=string.sub(json[2].Date,1,-10)
local RovaDate3=string.sub(json[3].Date,1,-10)
-- log result
domoticz.log("Next Garbage Collection: ["..json[1].GarbageTypeCode..' at '..RovaDate..']',domoticz.LOG_FORCE)
-- update device
domoticz.devices(DeviceName).updateText(json[1].GarbageTypeCode.." "..RovaDate..", "..json[2].GarbageTypeCode.." "..RovaDate2..", "..json[3].GarbageTypeCode.." "..RovaDate3)
-- check if we have to send notification
if (item.isTimer) then
local twoletters = string.sub(item.trigger,1,2)
domoticz.log("1st to trigger letters are ["..twoletters.."]",domoticz.LOG_DEBUG)
domoticz.log("Item is timer ("..item.trigger..")",domoticz.LOG_DEBUG)
if (twoletters=="at") then -- we are at the notification timestamp
-- prepare time comparison
local Time = require('Time')
local t = Time(RovaDate..' 00:00:00')
domoticz.log("Secondsago = "..t.secondsAgo..", minutesAgo="..t.minutesAgo..", hoursago="..t.hoursAgo..", daysago="..t.daysAgo,domoticz.LOG_DEBUG)
-- check if we have to notify
if (t.daysAgo==0 and t.secondsAgo<0) then -- timestamp is within 1 day
-- Yes we do: notify
domoticz.log("Rova will be there within 1 day, sending notification", domoticz.LOG_DEBUG)
domoticz.notify(NotifyTitle,NotifyLine1..json[1].GarbageTypeCode..NotifyLine2..RovaDate,domoticz.PRIORITY_NORMAL)
-- no we don't
domoticz.log("no need to notify",domoticz.LOG_DEBUG)
domoticz.log("some kind of error accessing the Rova data API",domoticz.LOG_ERROR)
I am still testing this script. It seems to work fine for me now, so i would be happy to hear your findings ...
- waaren
@akamming, we took more or less the same approach. The main difference is that in your script the event thread (which is single threaded) must wait until the curl command has finished. Potentially this could stall the event system.akamming wrote: Thursday 08 November 2018 16:13 i was working on the same thing. a few weeks ago i created my own dzvents script for the ROVA afvalkalender. This one hopefully works for you!
I worked around this risk by executing curl in the background and retrigger the script to check every couple of seconds if the result has arrived. Another approach could be to use the option --connect-timeout <seconds> or -m, --max-time <seconds> in the curl command.
In my opinion the best way would be to use domoticz.openURL but I have not found a way to use this with the required cookie table/JSON.
akamming
Totally agree. This is why i tried to make a suggestion in the suggestion thread: viewtopic.php?f=31&t=25454&p=195745#p195745. So far no response.waaren wrote: Thursday 08 November 2018 16:59 In my opinion the best way would be to use domoticz.openURL but I have not found a way to use this with the required cookie table/JSON.
Since this script is run only every 8 hours, i think it is a small risk. I have the same risk for another script where i run an os.execute statement. I like your workaround. maybe i'll implemented if this becomes a problem.
KR Arnold
- waaren
Maybe we need to look at the optional "headers =" in domoticz.openURLakamming wrote: Friday 09 November 2018 9:16 Totally agree. This is why i tried to make a suggestion in the suggestion thread:
So far I found that when you have the cookie generated by www.rova.nl already in chrome, the url
https://www.rova.nl/api/TrashCalendar/G ... %2215%22} , does return the requested JSON. So if there is a way to get this cookie on the domoticz system we might be a step further in the right direction
delcara
Already usesd the script from Waaren. So far it's working nice, adjusted the run times and notifications a little bit. I now receive a notification the evening before collection day and some nice notifications through google TTS on my Sonos speakers
Strange thing is that i can't save the script when copy/paste in the domoticz web editor, checked it for weird characters or empty spaces. No problem with other scripts. And it runs fine when i copy it to the scripts folder. Didn't bother to look further for the cause of this issue. Running domoticz beta 4.10171.
delcara
Discovered why saving in the webeditor didn't work! I've got a reverse proxy (nginx) on the PI and it was a limitations in the HTTP GET request in my proxy config.
martijn333
- Target OS: OS X
I tried the Circulus-Berkel script but what am i doing wrong.
The zipcode and housenumber are set correctly.
I activated debug to get more information.
Can someone help me?
2018-12-18 22:13:00.253 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: url = https://afvalkalender.circulus-berkel.n ... ender/2018
2018-12-18 22:13:00.253 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: method = GET
2018-12-18 22:13:00.253 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: post data = nil
2018-12-18 22:13:00.253 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: headers = nil
2018-12-18 22:13:00.253 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: callback = getGarbageDatesResponse
2018-12-18 22:13:00.254 Status: dzVents: Info: getGarbageDatesMarker: ------ Finished Script #1
2018-12-18 22:13:00.414 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-12-18 22:13:02.603 Status: dzVents: Info: Handling httpResponse-events for: "getGarbageDatesResponse
2018-12-18 22:13:02.603 Status: dzVents: Info: getGarbageDatesMarker: ------ Start internal script: Script #1: HTTPResponse: "getGarbageDatesResponse"
2018-12-18 22:13:02.614 Status: dzVents: Debug: getGarbageDatesMarker: 0200200000011954
2018-12-18 22:13:02.618 Status: dzVents: Error (2.4.9): getGarbageDatesMarker: Problem with response from (no data) using data from earlier run
2018-12-18 22:13:02.618 Status: dzVents: Error (2.4.9): getGarbageDatesMarker: No previous data. are zipcode and housenumber ok and in circulus-berkel area?
2018-12-18 22:13:02.619 Status: dzVents: Info: getGarbageDatesMarker: ------ Finished Script #1
2018-12-18 22:13:02.619 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-12-18 22:13:02.644 Status: Notification: Problem with response from (no data) using data from earlier run
2018-12-18 22:13:02.645 Status: Notification: No previous data. are zipcode and housenumber ok and in circulus-berkel area?
- waaren
For some reason the script does not like the data that came back from circulus-berkelmartijn333 wrote: Tuesday 18 December 2018 22:23 I tried the Circulus-Berkel script but what am i doing wrong.
Can you try to enter https://afvalkalender.circulus-berkel.n ... ender/2018 in your browser and show the results. If that look more or less OK please add the line
dz.log(triggerObject.data,dz.LOG_FORCE)Code: Select all
and show the relevant loglines
martijn333
- Target OS: OS X
I added the line this are the results:
Thank you for helping!
2018-12-19 11:58:00.423 Status: dzVents: Info: getGarbageDatesMarker: ------ Start internal script: Script #1:, trigger: at 11:58
2018-12-19 11:58:00.455 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: url = https://afvalkalender.circulus-berkel.nl/rest/adressen/0200200000011954/kalender/2018
2018-12-19 11:58:00.455 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: method = GET
2018-12-19 11:58:00.455 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: post data = nil
2018-12-19 11:58:00.455 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: headers = nil
2018-12-19 11:58:00.455 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: callback = getGarbageDatesResponse
2018-12-19 11:58:00.456 Status: dzVents: Info: getGarbageDatesMarker: ------ Finished Script #1
2018-12-19 11:58:00.598 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-12-19 11:58:02.869 Status: dzVents: Info: Handling httpResponse-events for: "getGarbageDatesResponse
2018-12-19 11:58:02.869 Status: dzVents: Info: getGarbageDatesMarker: ------ Start internal script: Script #1: HTTPResponse: "getGarbageDatesResponse"
2018-12-19 11:58:02.879 Status: dzVents: Debug: getGarbageDatesMarker: 0200200000011954
2018-12-19 11:58:02.883 Status: dzVents: !Info: getGarbageDatesMarker: [{"afvalstroom_id":4,"ophaaldatum":"2018-01-04"},{"afvalstroom_id":55,"ophaaldatum":"2018-01-06"},{"afvalstroom_id":55,"ophaaldatum":"2018-01-15"},{"afvalstroom_id":55,"ophaaldatum":"2018-01-29"},{"afvalstroom_id":4,"ophaaldatum":"2018-02-01"},{"afvalstroom_id":55,"ophaaldatum":"2018-02-12"},{"afvalstroom_id":55,"ophaaldatum":"2018-02-26"},{"afvalstroom_id":4,"ophaaldatum":"2018-03-01"},{"afvalstroom_id":55,"ophaaldatum":"2018-03-12"},{"afvalstroom_id":55,"ophaaldatum":"2018-03-26"},{"afvalstroom_id":12,"ophaaldatum":"2018-04-04"},{"afvalstroom_id":4,"ophaaldatum":"2018-04-05"},{"afvalstroom_id":55,"ophaaldatum":"2018-04-09"},{"afvalstroom_id":55,"ophaaldatum":"2018-04-23"},{"afvalstroom_id":4,"ophaaldatum":"2018-05-03"},{"afvalstroom_id":55,"ophaaldatum":"2018-05-07"},{"afvalstroom_id":55,"ophaaldatum":"2018-05-19"},{"afvalstroom_id":55,"ophaaldatum":"2018-06-04"},{"afvalstroom_id":4,"ophaaldatum":"2018-06-07"},{"afvalstroom_id":55,"ophaaldatum":"2018-06-18"},{"afvalstroom_id":55,"ophaaldatum":"2018-07-02"},{"afvalstroom_id":4,"ophaaldatum":"2018-07-05"},{"afvalstroom_id":55,"ophaaldatum":"2018-07-16"},{"afvalstroom_id":55,"ophaaldatum":"2018-07-30"},{"afvalstroom_id":12,"ophaaldatum":"2018-08-01"},{"afvalstroom_id":4,"ophaaldatum":"2018-08-02"},{"afvalstroom_id":55,"ophaaldatum":"2018-08-13"},{"afvalstroom_id":55,"ophaaldatum":"2018-08-27"},{"afvalstroom_id":4,"ophaaldatum":"2018-09-06"},{"afvalstroom_id":55,"ophaaldatum":"2018-09-10"},{"afvalstroom_id":55,"ophaaldatum":"2018-09-24"},{"afvalstroom_id":4,"ophaaldatum":"2018-10-04"},{"afvalstroom_id":55,"ophaaldatum":"2018-10-08"},{"afvalstroom_id":55,"ophaaldatum":"2018-10-22"},{"afvalstroom_id":4,"ophaaldatum":"2018-11-01"},{"afvalstroom_id":55,"ophaaldatum":"2018-11-05"},{"afvalstroom_id":55,"ophaaldatum":"2018-11-19"},{"afvalstroom_id":55,"ophaaldatum":"2018-12-03"},{"afvalstroom_id":12,"ophaaldatum":"2018-12-05"},{"afvalstroom_id":4,"ophaaldatum":"2018-12-06"},{"afvalstroom_id":11,"ophaaldatum":"2018-12-11"},{"afvalstroom_id":55,"ophaaldatum":"2018-12-17"},{"afvalstroom_id":11,"ophaaldatum":"2018-12-22"},{"afvalstroom_id":55,"ophaaldatum":"2018-12-31"}]
2018-12-19 11:58:02.883 Status: dzVents: Error (2.4.9): getGarbageDatesMarker: Problem with response from (no data) using data from earlier run
2018-12-19 11:58:02.884 Status: dzVents: Error (2.4.9): getGarbageDatesMarker: No previous data. are zipcode and housenumber ok and in circulus-berkel area?
2018-12-19 11:58:02.884 Status: dzVents: Info: getGarbageDatesMarker: ------ Finished Script #1
2018-12-19 11:58:02.884 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-12-19 11:58:02.924 Status: Notification: Problem with response from (no data) using data from earlier run
2018-12-19 11:58:02.925 Status: Notification: No previous data. are zipcode and housenumber ok and in circulus-berkel area?
- waaren
Response from your provider again differs a bit from others.
script below should do it for you.
return
garbageTypes = {1,4,11,12,55} -- Valid for circulus-berkelfor but these numbers vary per garbageCollector; Why ??
-- ("55"," Groente-, fruit- en tuin afval ")
-- ("4", " Papier en kartonnen verpakkingen ")
-- ("11"," Plastic, blik drankpakken ")
-- ("12"," Boeken, speelgoed en textiel ")
-- ("1", " Restafval ")
method = "GET",
method = "GET",
dz.notify(message)
return (delta == 0)
str = tostring(str)
dz.log(str,dz.LOG_DEBUG)
str = str:gsub("12"," Boeken, Elektrische apparaten, Speelgoed en Textiel")
str = str:gsub("55"," Groente-, fruit- en tuin afval ")
str = str:gsub("4", " Papier en kartonnen verpakkingen ")
str = str:gsub("11"," Plastic, blik drankpakken ")
str = str:gsub("1", " Rest afval ")
return str
local function dumpTable(t, level)
for attr, value in pairs(t) do
if (type(value) ~= 'function') then
if (type(value) == 'table') then
io.write(level .. attr .. ':\n')
print(level .. attr )
dumpTable(value, level .. ' ')
io.write(level .. attr .. ': ' .. tostring(value) .. "\n")
print(level .. attr .. ': ' .. tostring(value) )
io.write(level .. attr .. '()\n')
print(level .. attr .. '()')
getBagID()
return
rt , rtRaw = {}, {}
if rtRaw[1] ~= nil then
return false
local foundFirst = false
local foundOne = false
foundOne = true
foundFirst = true
if foundOne then
if myAlertDevice and foundFirst then -- Update AlertDevice with nearby date / type
-- Main
handleResponse()
collectBagId(1)
martijn333
- Target OS: OS X
Thanks it is working!
imdos
- Domoticz version: 2023.2
Great work. I got the script working on rmn. However I don't understand the logics for the notification of the alert. Could someone help me with that. I would like to receive a modification on the day itself in the morning, around 8 or something.
Sent from my MI 6 using Tapatalk
Making use of: Raspbian(SSD), dz Beta, Woonveilig, Z-Wave(alarm+multi-sensor), RFLink(blinds), P1, Yeelight, Xiaomi temp sensors, Tasmota(SonoFF, Blitzwolf SHP2, Shelly1)
- waaren
If you can send me the script via PM as you use it now I will have a look.imdos wrote: Monday 04 February 2019 22:37 Great work. I got the script working on rmn. However I don't understand the logics for the notification of the alert. Could someone help me with that. I would like to receive a modification on the day itself in the morning, around 8 or something.
