rgroothuis
Two questions on the Dashboard I'm working on, see screenshot:
1) How can I decrease the height of each button? (So that I get more rows on my small screen)
2) How can I get the text on the button to the right of the icon?
Lokonli
What is your screen size?
Can you show how you defined your 'buttons' in your CONFIG.js?
Which version of Dashticz are you using? If you are using master, then I recommend to switch to the latest beta.
rgroothuis
The buttons config is:Lokonli wrote: Sunday 04 November 2018 18:16 What is your screen size?
var buttons = {}
buttons.nunl = {key: 'nunl', width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos', width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
buttons.webcam1 = { key: 'cam1', width:6, isimage:true, refresh:2000, image: 'http://192.168.0.175:88/cgi-bin/CGIProx ... pwd=yyyyyy', url: 'http://ip_url_to_webcam'}
buttons.webcam2 = { key: 'cam2', width:6, isimage:true, refresh:2000, image: 'http://192.168.0.173:88/cgi-bin/CGIProx ... wd=yyyyyyy'}
buttons.buienradar = { key: 'buienradar', width:12, isimage:true, refresh:6000, image: 'http://api.buienradar.nl/image/1.0/Rada ... =256&h=256', url:'https://gadgets.buienradar.nl/gadget/zo ... e=3&voor=1'}
I'm on the master branch indeed but not on the latest version. Going to do an update soon.
Lokonli
Add the following to custom/custom.css:
and with a smaller font as well:
.buttons-nunl, .buttons-nos, .imgblock {
padding-top: 1px !important;
padding-bottom: 1px !important;
border-top: 1px !important;
border-bottom: 1px !important;
font-size: 6px !important;
.buttons-nunl .title, .buttons-nos .title {
rgroothuis
That doesn't make a change to my dashboard, strange!Lokonli wrote: Sunday 04 November 2018 21:12 Add the following to custom/custom.css:and with a smaller font as well:Code: Select all
.buttons-nunl, .buttons-nos, .imgblock { padding-top: 1px !important; padding-bottom: 1px !important; border-top: 1px !important; border-bottom: 1px !important; }Code: Select all
.buttons-nunl, .buttons-nos, .imgblock { padding-top: 1px !important; padding-bottom: 1px !important; border-top: 1px !important; border-bottom: 1px !important; font-size: 6px !important; } .buttons-nunl .title, .buttons-nos .title { font-size: 6px !important; }
if I use:
/* Background blocks */
.transbg.col-xs-1,
.transbg.col-xs-2,
.transbg.col-xs-3,
.transbg.col-xs-4,
.transbg.col-xs-5,
.transbg.col-xs-6,
.transbg.col-xs-7,
.transbg.col-xs-8,
.transbg.col-xs-9,
.transbg.col-xs-10,
.transbg.col-xs-11,
.transbg.col-xs-12 {
padding-top:12px;
padding-bottom:12px;
border: 1px solid rgba(255,255,255,0); /* border: 7px -> 3px - Smaller space between blocks */
background-clip: padding-box;
height: 76px; <<<<<<<<<===========
}I added height to this setting I can influence the height of a number of boxes, but it also messes up the size of other boxes.
Lokonli
Which Dashticz version are you using?
Can you post your custom.css that you used for the screen shot in the previous post?
rgroothuis
Sure, here it is, thanks for trying to help.Lokonli wrote: Wednesday 07 November 2018 13:18 Which Dashticz version are you using?
.fa.fa-lightbulb-o.on {color: yellow}
.fa.fa-home.on {color: green}
.fa.fa-home.off {color: red}
.fa.fa-bell.on {color: green}
.fa.fa-bell.off {color: red}
.sunrise { font-size: 25px; font-size: 1vw; color: yellow;}
.wi-sunrise:before { color: yellow; font-size: 25px; font-size: 1vw;}
.sunset { font-size: 25px; font-size: 1vw; color: orange;}
.wi-sunset:before { color: orange; font-size: 25px; font-size: 1vw;}
.transbg.col-xs-1,
.transbg.col-xs-2,
.transbg.col-xs-3,
.transbg.col-xs-4,
.transbg.col-xs-5,
.transbg.col-xs-6,
.transbg.col-xs-7,
.transbg.col-xs-8,
.transbg.col-xs-9,
.transbg.col-xs-10,
.transbg.col-xs-11,
padding-top:12px;
div.mh.titlegroups {
height: 42px !important; /* default height=75px */
padding-top: 1px; /* center text for new height */
.title {
font-size:13px;
Lokonli
And your dashticz version?
Looking at the .fa. statement in your custom.css I assume you are using Master or and old beta. In that case I would recommend to switch to the latest beta.
rgroothuis
I'm using the Master but not yet the latest version. Dashticz is indicating that there is a new version. I didn't upgrade yet as I understood you need to install it on a different machine with a browser because of PHP support. I don't want that, I want to keep it on my Domoticz Raspberry.Lokonli wrote: Wednesday 07 November 2018 19:18 And your dashticz version?
Lokonli
That's no problem.rgroothuis wrote: Thursday 08 November 2018 10:16I'm using the Master but not yet the latest version. Dashticz is indicating that there is a new version. I didn't upgrade yet as I understood you need to install it on a different machine with a browser because of PHP support. I don't want that, I want to keep it on my Domoticz Raspberry.Lokonli wrote: Wednesday 07 November 2018 19:18 And your dashticz version?
Dashticz used 'dashticz.nl' for some functionality (some garbage companies, calendar, tvguide, traffic info). The server 'dashticz.nl' is down. This functionality now is integrated within Dashticz beta, but then indeed you need a PHP enabled webserver. If you don't use the functionality previously provided by 'dashticz.nl' then there is no need for PHP. So there should be no problem running dashticz beta on the domoticz webserver.
If you would like to have the new PHP features then it's pretty easy to install Apache on the same Raspberry as well. See the wiki for instructions.
rgroothuis
Thanks for the feedback. I'm still learning on Dashticz, I was not even aware of the dashticz.nl server. Which functionality requires the PHP functionality? Is there an overview? Based on this I can consider if I want to setup a separate PHP web server.Lokonli wrote: Thursday 08 November 2018 11:42That's no problem.rgroothuis wrote: Thursday 08 November 2018 10:16I'm using the Master but not yet the latest version. Dashticz is indicating that there is a new version. I didn't upgrade yet as I understood you need to install it on a different machine with a browser because of PHP support. I don't want that, I want to keep it on my Domoticz Raspberry.Lokonli wrote: Wednesday 07 November 2018 19:18 And your dashticz version?
Lokonli
It's needed for Calendar and for some (not all) garbage collection companies. (and hopefully in the next beta: integrated CORS proxy)rgroothuis wrote: Thursday 08 November 2018 11:49Thanks for the feedback. I'm still learning on Dashticz, I was not even aware of the dashticz.nl server. Which functionality requires the PHP functionality? Is there an overview? Based on this I can consider if I want to setup a separate PHP web server.Lokonli wrote: Thursday 08 November 2018 11:42That's no problem.rgroothuis wrote: Thursday 08 November 2018 10:16 I'm using the Master but not yet the latest version. Dashticz is indicating that there is a new version. I didn't upgrade yet as I understood you need to install it on a different machine with a browser because of PHP support. I don't want that, I want to keep it on my Domoticz Raspberry.
- mvveelen
I'm having problems with both the garbage as the calendar after upgrading to the latest Beta on my RPi3. I have PHP running on the RPi, but do I have to change something in the settings to get it working again?
PHP 7.0.30-0+deb9u1 (cli) (built: Jun 14 2018 13:50:25) ( NTS )
Copyright (c) 1997-2017 The PHP Group
Zend Engine v3.0.0, Copyright (c) 1998-2017 Zend Technologies
with Zend OPcache v7.0.30-0+deb9u1, Copyright (c) 1999-2017, by Zend Technologies
config['garbage_company'] = 'hvc';
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = 'my ZIP code';
config['garbage_street'] = 'My street name;
config['garbage_housenumber'] = 'my house number';
config['garbage_maxitems'] = '4';
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
config['garbage_icon_use_colors'] = true;
config['garbage_use_cors_prefix'] = true;
config['garbage'] = {
gft: {kliko: 'green', code: '#FFFFFF', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
pmd: {kliko: 'orange', code: '#FFFFFF', name: 'Plastic', icon: 'img/garbage/kliko_orange.png'},
rest: {kliko: 'grey', code: '#FFFFFF', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
papier: {kliko: 'blue', code: '#FFFFFF', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
milieu: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
Lokonli
I can help, but dId you already try the installation instructions in the wiki?mvveelen wrote: Saturday 10 November 2018 17:25 I'm having problems with both the garbage as the calendar after upgrading to the latest Beta on my RPi3. I have PHP running on the RPi, but do I have to change something in the settings to get it working again?
config['garbage_company'] = 'hvc'; config['garbage_icalurl'] = 0; config['garbage_zipcode'] = 'my ZIP code'; config['garbage_street'] = 'My street name; config['garbage_housenumber'] = 'my house number'; config['garbage_maxitems'] = '4'; config['garbage_width'] = '12'; config['garbage_hideicon'] = 0; config['garbage_use_names'] = true; config['garbage_use_colors'] = true; config['garbage_icon_use_colors'] = true; config['garbage_use_cors_prefix'] = true; config['garbage'] = { gft: {kliko: 'green', code: '#FFFFFF', name: 'GFT', icon: 'img/garbage/kliko_green.png'}, pmd: {kliko: 'orange', code: '#FFFFFF', name: 'Plastic', icon: 'img/garbage/kliko_orange.png'}, rest: {kliko: 'grey', code: '#FFFFFF', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'}, papier: {kliko: 'blue', code: '#FFFFFF', name: 'Papier', icon: 'img/garbage/kliko_blue.png'}, kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'}, brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'}, black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'}, milieu: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'}, kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'}, };
https://www.domoticz.com/wiki/Dashticz_ ... stallation
If you still encounter issues, please let me know so I can improve the wiki.
- mvveelen
Ehhhhh, yes? It worked until the latest update. I read something about running your own server or something?
Lokonli
If you want to use calendar and/or garbage functionality then you have to install a web server with php support enabled.mvveelen wrote: Saturday 10 November 2018 19:29 Ehhhhh, yes? It worked until the latest update. I read something about running your own server or something?
You can install this on the same raspberry pi that currently is running Domoticz (or Dashticz) already.
You already have installed php I read.
Did you already install Apache on the raspberry? and php7.0-curl?
if not, execute the following:
sudo apt-get install php7.0-curl
sudo apt-get install apache2
You should see the Apache demo page.
After that you can follow the instruction described under ' Installation of Dashticz v2' at the wiki:
If things won't work let me know.
- mvveelen
Well, as I said, it worked without any problems, but something must have changed for the calendar and garbage to work. It keeps "loading".
So I did the above and did NOT run the installation again. What is the missing piece of the puzzle ?
Lokonli
When did it work for the last time?mvveelen wrote: Saturday 10 November 2018 22:57 Well, as I said, it worked without any problems, but something must have changed for the calendar and garbage to work. It keeps "loading".
The server 'dashticz.nl', which was used for calendar and garbage functionality, is down permanently.
See: viewtopic.php?f=67&t=24907
For that reason the functionality now is integrated within Dashticz itself, but you have to install php on a web server like Apache.
- mvveelen
It had been working for several weeks in a row. A few days ago I decided to do the update and then it stopped working. I think it has something to do with dashticz.nl so I have to find out how to fix it.
Edit: did a fresh install in /var/www/html/dashboard and used my old config and then it worked right away. So I'm going to use it now from this location.
Poesknol
Hey i have a question,
I want to change my Thermostat temperature with Dashticz.
The problem is that i am using an eq-3 max and it is not working well with the arrow up and down option.
Is it possible to change it back to an drop down menu?
Thanks guys!
Thanks guys!
