DAVIZINHO
Post by DAVIZINHO »
anyone have news about vibration sensor?
salvacalatayud
Post by salvacalatayud »
Hi all!
I've found this:
https://www.domoticz.cn/forum/viewtopic.php?t=115
From what i've translated seems to make the air conditioning partner work.
Installed python-miio and created acpartner.py and the lua script, but I get this error:
Error: EventSystem: in AC_cocina: [string "commandArray = {}
..."]:5: bad argument #1 to 'pairs' (table expected, got nil)
Any idea of what can be happening?
CLEMENT99
Post by CLEMENT99 »
DAVIZINHO wrote: Thursday 01 November 2018 20:46 anyone have news about vibration sensor?
I'm also waiting for the integration of this xiaomi vibration device...
ak97
Domoticz version: latest
Post by ak97 »
done.
aqara vibration sensor in lastest beta
molnaratti
Post by molnaratti »
ak97 wrote: Thursday 08 November 2018 17:11 done.
Works fine, Thank you !
DAVIZINHO
Post by DAVIZINHO »
Vibration sensor works!!! great job and thanks!!!!
stewdyne
Post by stewdyne »
Ok, finaly I’ve found the culprit why my evensystem kept crashing on random intervals; the xiaomi gateway. When I disable that hardware my event system keep running. In the xiaomi mi home app I had several child devices under the xiaoim gateway; motion sensors, doorsensor. I resetted the gateway (5 sec press) without removing the child devices in the app. I saw no yellow light blinking but all my sensors in the app are gone.
When I try to pair the app again to my account/app It can’t find the device. The gateway is also still connected to my network (so no actual wifi reset?). When I long press the button I hear a Chinese sound but no yellow light. When I plug in the device to my energy socket a blue light is blinking. I can also activate and de-activate the alarm but pressing 2 times on the gateway. So I get the feeling the gateway is not resetted at all.
How can I reset the gateway so I can pair it again in the app and add my devices? (and hope domoticz will not crash again when I add the xiaomi gateway to my hardware)
Thank you.
CLEMENT99
Post by CLEMENT99 »
It works, thanks. :D
Camiel
Domoticz version: 4.10233
Post by Camiel »
Hello, just got everything working regarding the Xiaomi gateway but I would like to use the newly available commands for the Wireless Dual Wall Switch (https://www.gearbest.com/alarm-systems/ ... d=13027313 This is working in the Mi Home app and I enabled logging in Domoticz. The action is showing up, but.. How can I use these actions in Domoticz?
Domoticz Log:
2018-12-01 12:26:38.315 Status: {"cmd":"report","model":"remote.b286acn01","sid":"158d00027c0b47","short_id":17281,"data":"{\"channel_0\":\"double_click\"}"}
2018-12-01 12:26:39.448 Status: {"cmd":"report","model":"remote.b286acn01","sid":"158d00027c0b47","short_id":17281,"data":"{\"channel_1\":\"double_click\"}"}
2018-12-01 12:26:41.540 Status: {"cmd":"report","model":"remote.b286acn01","sid":"158d00027c0b47","short_id":17281,"data":"{\"channel_0\":\"long_click\"}"}
2018-12-01 12:26:43.716 Status: {"cmd":"report","model":"remote.b286acn01","sid":"158d00027c0b47","short_id":17281,"data":"{\"channel_1\":\"long_click\"}"}
pavelbor
Domoticz version: LastBeta
Post by pavelbor »
Hello, does somebody tried new Aqara Smart bulb ZNLDP12LM (ZigBee)? Does it supported by Domoticz?
jordipalet
Post by jordipalet »
Hi, new to Domoticz
I will like to use something similar to this, but in devices in only see my Xiaomi Smart Plug, not the power consumption (it shows correctly in the Xiaomi app). Also, what kind of script is this one, where I actually can use/try it? May be Domoticz is not displaying the power, but actually it is possible to read it ...
corbin wrote: Wednesday 30 August 2017 4:34
visser wrote: Tuesday 29 August 2017 10:00 Hi Domoticz users, I'm trying to trigger a notification when the power usage on a Xiaomi Smart Plug drops back to 0 (e.g. end of a washing machine cycle), I've found the current General > kWh device populates daily values well but not per-minute data. Help?
This is how I do a similar thing for my projector:
local projectoron = false
watts = otherdevices["Xiaomi Usage Projector"]
watts = string.sub(watts, 0, string.find(watts, ";")-1)
numericWatts = tonumber(watts)
if (numericWatts > 100) then
    projectoron = true
    --print('projector is on')
hansmac
Post by hansmac »
@Jordipalet,
I'm usuing the Xiaomi Aqara homekit gateway (ZHWG11LM) with fw 1.4.7. May I ask which version you are using and which firmware? I have troubles connecting my gateway to domoticz
Thx Hans
superkris
Post by superkris »
I'm trying to connect a double wall switch into Domoticz. It seems to work fine in the Xiaomi app, but i cant see it in Domoticz.
Other products like the door sensors work fine.
vuurtjih
Domoticz version: 4.97
Post by vuurtjih »
Somehow my door sensor has stopped working correctly, it does only on instead of on/off. Now my Blockly's aren't working, does anyone have a solution for this? Restarting domoticz doesn't work either.
acaonweb
Post by acaonweb »
Hi guys maybe someone can tell me if Domoticz 4.9700 has problem with Xiaomi Gateway with fw 1.4.1_161.0143
Thanx in advance
DAVIZINHO
Post by DAVIZINHO »
some gateways have problems and its imposible to add to domoticz because not detect trafic on por 9898. I dont know how, but its real :-(
landaisbenj
Domoticz version: stable
Post by landaisbenj »
dvangeld wrote: Wednesday 17 October 2018 13:15
dvangeld wrote: Tuesday 16 October 2018 14:34
DAVIZINHO wrote: Tuesday 16 October 2018 10:07
You must go to gateway and add it. Not apears in devices in principal menu but apears in add devices in gateway menu. I dont understand....
Huh! You are absolutely right! I thought it was under Add Device....
Am @ work now. Will try tonite
Thx ! :D
Working!
Pitty it only shows unlock actions and only with a key. I would like to know if the door is locked!
Is the lock supported by Domoticz?
I've it. It's not unlock action i think, it's just if your key is unlock to use... No stat return about door's locked or not... I don't know if it's supported by domoticz, but i think not.
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
galadril
Post by galadril »
Have somebody already looked into this device?
viewtopic.php?f=68&t=26259
Vomera
Post by Vomera »
DAVIZINHO wrote: Saturday 22 December 2018 15:41 some gateways have problems and its imposible to add to domoticz because not detect trafic on por 9898. I dont know how, but its real :-(
I have this issue. I have 3 gateways. I could only one gateway on domoticz.
Yesterday i managed to run 3 domoticz servers on 1 linux server.
They run seperate.
- The main gateway runs very good on Domoticz server A
- The second gateway i added it on domoticz server B. I get only messages like
2019-01-01 16:09:39.428 Error: XiaomiGateway: received data from unregisted gateway!
But the devices showed up in domoticz and added them. Could turn on the light on the gateway.
- The thirth gatway i added on domoticz server C.
Get the same messages but the problem is i cannot see any devices.
Changed the gateway from server C to server B and server B to server C. And same problem on changed servers appears too.
One gateway doesn't send the devices.
Btw, all devices are made on a sepparate MI account. So i didnt add them in 1 account. Test it also on one account, but same issue.
ak97
Post by ak97 »
Vomera wrote: Tuesday 01 January 2019 16:16
They run seperate.
domoticz beta now supports multiple gateways simultaneously. Error message: XiaomiGateway: received data from unregisted gateway! means that you have improperly configured gateways on servers B and C.
