I have a DarkSky "Temperature" device of subtype "LaCrosse TX3" which reads -17.8C.
Can someone please tell me: what/where is this?
TIA
DarkSky "LaCrosse TX3"
Raspberry Pi 3; Domoticz 2022.2
Philips Hue, Logitech Harmony Elite, LMS, Drayton Wiser
Rfxtrx433e and Owl CM11x
Aeon Z-Stick Gen 5
Dark Skies
Aeon Z-Stick Gen 5
Dark Skies
- Domoticz version: Latest β
Re: DarkSky "LaCrosse TX3"
Somewhere cold?
But seriously, all the dummy temperature sensors (including Dark Sky) that I have are shown as LaCrosse.
Have you enabled Dark Sky in the hardware section and if so is the location (on the planet) correct?
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
Yes, it's enabled (and all the other DarkSky 'sensors', and the forecast, work correctly), and the location is correct.
Aeon Z-Stick Gen 5
Dark Skies
Aeon Z-Stick Gen 5
Dark Skies
Oh...
Is that the only Dark Sky temperature sensor and has it been updated recently. Also has any adjustment been applied to it under edit?
No, there's also the Temp / Humidity / Barometer sensor, with subtypes "THB1 - BTHR918, BTHGN129".
Domoticz has been updated many times recently, but I believe this sensor has been there for a long time.
Applied to what? How/why would adjustment/edit be done?alanlsmith wrote: ↑Tuesday 30 October 2018 14:13Also has any adjustment been applied to it under edit?
Aeon Z-Stick Gen 5
Dark Skies
Aeon Z-Stick Gen 5
Dark Skies
Does the temperature on that read the same as the device you mentioned in your original post.
I meant when was the last update of the temperature device itself.
On the device itself in the web ui, click edit and you can enter a plus or minus figure to correct any inaccuracies (normally to correct the output of an actual physical device) I don’t know why this would be changed in your case but it’s worth checking to eliminate it.
