Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Madgeni
Re: Controlicz - Easy Domoticz to Alexa Integration
Yes, it is an issue with the response, but I thought I'd fixed it, so was just checking
will take another look
Peer
Yes, now all is fixed!
You are the best!
You are the best!
Madgeni
Yay! Glad it's working
hayman
- Domoticz version: 3.8153
please Milight RGB CCT special with CW and WW...
thanks
thanks
Madgeni
Apologies, will plug the bulb in tomorrow and get debugging!
hayman
Still have a probleem with Milight (ibox 2) GU10 RGBCCT ....
changing color works good but changing from warmwhite to coolwhite not ..
PHIL63
since few days (don't know how many) the command of my blinds are inverted if I use "routines" in alexa parameters.
If I tell to Alexa to open my blinds then she close it and if I tell her to close it then she open it.
Before all works fine and I never have any problem with that.
Another thing, I can't create a routine with only a ON command, if I crate a ON command then in Domoticz it's a "Set level" command that is received and so my blind don't work.
Any idea ?
Any idea ?
johansson
Reverting back to Controlicz after a while, just to notice that donating 20 euros six months ago ended up into subscription based service! You gotta be kidding me.
The early volunteers donating have enabled you to develop the service, and now we should be subscribing as everybody else. Sounds fair - not.
Madgeni
Most donators were refunded or the donations were converted to subscriptions, as I've posted it wasn't/isn't my intention to con people. Mail me from your Controlicz profile, and I'll help
hayman
the milight still not working as befor ..?
can you look at it please
Madgeni
Apologies, bought the wrong bulb, bayonet version on it's way - will fix it this week
hayman
Okey thanks
It's gu10 RGBCCT with ibox2
Madgeni
Hi hayman - try now?
hayman
With Alexa not working with Google home it's works but some times get freezing at warm white???
hayman
any update onthe milight
johansson
Dropped you a PM.Madgeni wrote: Friday 14 September 2018 21:38 Most donators were refunded or the donations were converted to subscriptions, as I've posted it wasn't/isn't my intention to con people. Mail me from your Controlicz profile, and I'll help
johansson
Solved, refunded and subscribed. Great work Nick!
Madgeni
Hi all - made an update to your profiles, so devices will show whether they are in a Room Plan or not. Thats should help with ensuring you're sending all the devices you want to send, and no more
hayman
Thanks still the milight cctrgb not working:(
Madgeni
What? So you can't change to blue/green with milight? sorry, honestly thought i'd fixed it
