Theme hack [custom search box & controling MPSYT]
devros
Post by devros »
if anyone is interested found way to add text box input to domoticz GUI....
its quite ugly way but works imho great
im using this script to search and play interpret for MPSYT youtube player (but could be used for other scripts also)
1/so add one empty selector switch (or normal swtich) without any command
2/create domoticz variable
3/then add this js to theme (modify with your idx and right selector div box path
- so script works append search box to selected swith box
- then run dummy switch to stop previos MPSYT (sh script)
- send search box value to domoticz variable
- then run dummy switch with python script (this script read domoticz variable and send it to mpsyt) (python script)
im not real coder, but it was fun to hack
I know this guide requires some knowledge of domotic and scripting, but maybe could be interesting for someone..
JS theme code
    $("#lSelector80Level7").click(function () {
    var mytext = $('#myText').val();
    $("<div id='dialog' title='MPSYT SETUP'>text: <input type='text' name='jmeno' id='comm' size='12' placeholder='input'/></div>").appendTo('body').hide();
    event.preventDefault();
        $("#dialog").dialog({
            width: 600,
            modal: true,
            buttons: [
                text: "Send",
                icon: "ui-icon-about",
                click: function( e ) {
                    var value = $("#comm").val(); //search input value
                    // stop MPSYT
                    var stop_url = "http://XXXX/json.htm?type=command&param=switchlight&idx=80&switchcmd=Set%20Level&level=50";
                    $.get(stop_url);
                    var durl = "http://XXXX/json.htm?type=command&param=updateuservariable&vname=command&vtype=2&vvalue=";
                    var domoticzurl = durl+value;
                    // console.log(domoticzurl);
                    $.get(domoticzurl);
                    //play MPSYT
                    var play_url = "http://XXXX/json.htm?type=command&param=switchlight&idx=699&switchcmd=On";
                    $.get(play_url);
                    //set player on yamaha
                    var yamaha_url = "http://XXXX/json.htm?type=command&param=switchlight&idx=66&switchcmd=Set%20Level&level=50";
                    $.get(yamaha_url);
                    $("#dialog").remove();
                   //function
            close: function(event, ui) {
    }); //close click
python script to read variable and play in MPSYT
#!/usr/bin/python3
import requests
import json
from requests.auth import HTTPBasicAuth
import os
from random import randint
debug = 0
domoticz = 1
random = (randint(1, 9))
custom_var ='http://XXXX/json.htm?type=command&param=getuservariable&idx=5'
custom_var_json = requests.get(url=custom_var, auth=HTTPBasicAuth('xxx', 'Xxx'), timeout=5)
hodnota = custom_var_json.json()['result'][-1]['Value']
print (hodnota)
cmd = 'mpsyt //' + hodnota + ', ' + str(random) + ', shuffle all > /dev/null < /dev/null &'
os.system(cmd)
print (cmd)
bash script to stop MPSYT
#! /bin/bash
sudo /usr/bin/pkill mpsyt  > /dev/null
sudo /usr/bin/pkill mpv  > /dev/null
sudo /usr/bin/pkill python  > /dev/null
exit 0
