Alexa, Google Home and Siri
Venzent
Domoticz version: 3.8153
Post by Venzent »
heggink wrote: Thursday 18 October 2018 12:01 I can confirm that Dutch is still not ideal. Whilst rooms seem to work, many individual devices are hit/miss. Some work, some assistant just does not recognise... She still needs a little work I guess but it's semi workable for me atm.
Hi Heggink,
I've set my GH to Dutch, but I cannot figure out how to switch the scenes with controlicz. In English "turn keukenverlichting on" is working fine (English/Dutch mix), but "schakel keukenverlichting aan" and any variation is giving the respons "ik begrijp het niet" of "keukenverlichting is niet beschikbaar" .
What is the correct command to start a scene with controlicz in Dutch?
heggink
Domoticz version: 12451
Post by heggink »
That sounds familiar unfortunately. I ended up renaming them because it looks like assistant struggles with names with verlichting in it. I had dressoirlampen as a group and I could not get it to work. It worked once I remember to dressoir. So now I have to say doe dressoir aan which is somewhat weird but it works...
P1 meter & solar panel
wardc
Post by wardc »
Turn [scene] on (Schakel [scene] aan) doesn't work for me either in dutch. 'Do' however seem to work for me. So when I have a scene that has the name 'normal' (normaal), I can turn it on by saying ' Do normal on' in dutch (doe normaal aan). I have not tried turning them off, as I have no off commands for my scenes. I use them to define states of multiple devices.
Madgeni
Post by Madgeni »
Can you try the Dutch for 'activate'? Does that do anything?
wardc
Post by wardc »
That didn't work before. But I just tried it and it works now.
djac
Post by djac »
I have now figured out that in Swedish it works with "Activate", in Swedish "Aktivera", for scenes. What is a bit strange is that I can use my two main scenes, that also contains Swedish characters, "Tändning" and "Släckning", but the scene "Morgon" constantly returs "I don't understand"
I have not been able to use the same command for individual devices though.
Domoticz on Rpi, Z-wave, Hue with Philips and Ikea bulbs
djac
Post by djac »
djac wrote: Saturday 27 October 2018 10:27 I have now figured out that in Swedish it works with "Activate", in Swedish "Aktivera", for scenes. What is a bit strange is that I can use my two main scenes, that also contains Swedish characters, "Tändning" and "Släckning", but the scene "Morgon" constantly returs "I don't understand"
OK, an edit. I now have found out that GH seems to ignore the names i set in the GH app, but use the native names from Domoticz, hence I couldn't activate "Morgon", chamhed name in Domoticz, synched and now that works.
Individual devices no change, still doesn't work for me.
Justintime
Post by Justintime »
I have had my first experiences with Controlicz and they are cool. Working great and fast.
But i have a a question I have Google Home in the Dutch language. When i want to open or close my curtains the only command what is working is "Gordijnen AAN of Gordijnen UIT" translation: curtains on, Curtains off.
Its not regonizing Open Or Close or Open en Dicht in Dutch.
Madgeni
Post by Madgeni »
Open/Close still not implemented by Google. i'm guessing it's because they want to tie it to door locks, and that will require additional work - any open will throw out to 2FA to ensure it's you asking :)
Unrelated - made an update to your profiles, so devices will show whether they are in a Room Plan or not. Thats should help with ensuring you're sending all the devices you want to send, and no more :)
RapTile
Post by RapTile »
i try to add controlicz but for some reason i can't get it to work.
The app tells me that the accounts are now linked but i do not see it in the list of my devices.
So i tried to send it to the device in this link:
https://assistant.google.com/services/a ... 8ba2?hl=nl
But my home mine replies: "sorry, i could not find that"
Yes, i subscribed to controlicz so i don't understand why it won't work.
Screen Shot 2018-10-30 at 19.43.16.png (63.1 KiB) Viewed 2673 times
Madgeni
Post by Madgeni »
hi - just make sure you put the devices you want to control into a Room Plan in Domoticz, then it should work.
RapTile
Post by RapTile »
Madgeni wrote: Tuesday 30 October 2018 19:48 hi - just make sure you put the devices you want to control into a Room Plan in Domoticz, then it should work.
I just did.
But i still don't see my devices under Home Control and when i say "hey google versterker status aan" it still wont work.
On the controlicz website i see that my devices are on a room plan
And when i try to send ti to the device with:
the home mini still tells me "sorry, i couldn't find that"
Screen Shot 2018-10-30 at 20.04.40.png (73.75 KiB) Viewed 2666 times
Madgeni
Post by Madgeni »
i see you've got two accounts (with a slightly different spelling) - can you mail me from your Controlicz profile, and i'll take a look for you?
RapTile
Post by RapTile »
Madgeni wrote: Tuesday 30 October 2018 20:17 i see you've got two accounts (with a slightly different spelling) - can you mail me from your Controlicz profile, and i'll take a look for you?
When i mail you from my profile, my email client opens. I just send u an email.
Tia!
RapTile
Post by RapTile »
Ok,
The devices are finally added.
Now i’ve got several issues.
1. The names in dutch like “Versterker - status” is not recognized by GH.
2. I can change the source from my devices in domoticz but because it’s a switch, GH only recognize it as a power on/of switch so i can not change the source.
3. When i rename a device in domoticz (remove dashes, rename them to an english word so GH knows how to work with them, they are synced with controlicz but the new name does not appear in the GH app.
4. When i say “hey google... sync devices. I get an error
As you can see in the attachment.
5. Is a question... if i add another device to controlicz... do i realy have to unlink controlic and re add all the devices? That is a lot of work to do this over and over again.. especially if you rename devices and you have to re add all the devices iver and over again. You can not simply push the + sign to add a new controlic device...
Madgeni
Post by Madgeni »
RapTile wrote: Tuesday 30 October 2018 23:43 1. The names in dutch like “Versterker - status” is not recognized by GH.
1 + 3 - in Domoticz, under the device description, you can put Controlicz:insertfriendlynamehere and then Google can use that.
2: Currently Selector Switches aren't available - as soon as the ability to control them is available in Google, it will be available in Controlicz
4: you need to put "Sync my devices" (or Dutch equivalent) - you've put "Google sync devices"
5: see 4
Hope that helps
RapTile
Post by RapTile »
Madgeni wrote: Tuesday 30 October 2018 23:50
5: see 4
Hope that helps
I do not understand 1 + 3.
What command should u give GH in that case? “Enable Controlicz tv” or something?
3. Ok. Sweet
4ok, it works now.
But what if you add another device to domoticz? Are you sure you can sync that aswell? Because you have to add a device and add that to a location.
RapTile
Post by RapTile »
RapTile wrote: Wednesday 31 October 2018 0:09
Madgeni wrote: Tuesday 30 October 2018 23:50 <..>
5: see 4
Hope that helps
3. Ok. Sweet
4ok, it works now.
Madgeni
Post by Madgeni »
Google & Alexa will inevitably have some protected words, i'm guessing Status is one of them. Rather than change your device names in Domoticz, i have provided the capability to add a 'friendly' name for Google/Alexa.
In Domoticz, in the device description you can add Controlicz: then the name you want to add:
I have a device called Front Room TV, but I know Google doesn't like that, and neither does my wife, so in the device description field i put:
Controlicz: Front Room telly
I then "sync my devices" in google, and I can control it with Front Room telly ("ok google, turn on the front room telly"). I could just add it to a Room in Google Home called Front Room, then use "ok google, turn on the telly in the front room"..
To add new devices to Controlicz, you will always need to:
Add it to a Room Plan
Make sure your Domoticz user has access to it (Edit Users>Set Devices)
Hope that clears up the confusion
Milenko
Post by Milenko »
I received my Lenovo smart display today. It updated to the latest firmware right away, so it has the same functions as the home app. When I try to select a temperature sensor or try to set the heat on my radiator valve on the Lenovo smart display through controlicz, the app on the Lenovo just crashes and restarts. Other functions work fine and I can read the sensors and set the heat from the home app on my phone.
I realize this is all new stuff and I don't know if the problem is with Google or controlicz. Just letting you know there is an issue
I just tested, lights (milight) do work on the Lenovo through controlicz. So it seems it's just the heating valve and temperature sensors that have the issue.
