hi,
Does someone has experience with a clean re-install of Domoticz on Raspberry Pi?
The reason I want to re-install is because my HDD is at 97%.
Is it possible te restore all domoticz settings including devices?
Steef
re-install Domoticz on Raspberry Pi
- emme
- Domoticz version: latest
Re: re-install Domoticz on Raspberry Pi
you can backup and restore the Domoticz folder
at least save the domoticz.db file and the domoticz/script folder.
ciao
M
ciao
M
"We always done this way"
steef27
are my blockly scripts also in de domoticz.db file?
- emme
yes, they are
but save also the domoticz/script folder
- Solderbro
- Domoticz version: 2020.1
As raspi is linux you should be able to do this after domoticz is shut down.
ash-4.3# tar czvf domoticz/* target-path/domoticz4980.tgz
After all work simply go to the target folder and do
ash-4.3# tar xzvf source-path/domoticz4980.tgz
This is the 100% full backup solution and it's horrible fast
Solderbro
Solderbro
Raspi 3B+RTC, SSD 128GB, Aeotec Gen5, Eurotronic SpiritZ, Fibaro FRGBW, Zipato PIR, Everspring AN180, Neo Coolcam Plug, Fibaro FGMS, Neo Coolcam Doorsensor, Popp Z-Weather
