dashticz: Important Request
- EdwinK
- Domoticz version: BETA
Re: IMPORTANT REQUEST!!!
In the various .js-files I've changed https://dashticz.nl/ to http://192.168.0.10/scripts/ but I'm not seeing garbage or calendar working. Before doing this I issued a git pull, with a notice that everything was up to date (noticed my custom.css file to be empty after this)
Guess there is still something else to do.
- gielie
- Domoticz version: latest β
@rob are you still involved with the project or are you abandon it totally?
What i want to know is are there any new developments, is someone taking over?
basic question is this project dead and should we search for another dashitcz like module?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
- Domoticz version: 3.8993
Can someone post a full info about where we need change URLS to use the 4 scripts when you upload them to a webserver?
- Thuis
First Rob, thank you for sharing your hobby with us. It is a great hobby and thank you we may also get the joy of using the nice Dashticz with Domoticz.robgeerts wrote: ↑Thursday 18 October 2018 14:59 Ok, i had to remove the scripts from my server.
In the attachment a zip with the files.
You can just upload it to a server with PHP and change the url in Dashticz.
Look through the scripts, I NEVER SAVED ANY OF YOUR DATA.
I DONT CARE ABOUT YOUR DATA!
It was done because the parsing of some external webservices made the dashboard slower.
Also, some webservice for the garbage-calendars for example, have different arrays of data they return, I wanted it to be returned in one way so the script in Dashticz could be the same for every garbage-collector.
Anyway, use it if you want and dont use if you dont want.
I did this as a hobby project and indeed, charged nothing for it.
I like the features of the garbage and the ical calendar, so now it has not been working and i am afraid that, maybe in the future, it will have to be local so, I am trying to get the ical and garbage to work. I have apache24 with php5 up and running, and trying to change the curl to my host.
curUrl = 'http://127.0.0.1/dashticz/ical/?time=' + cache + '&url=' + curUrl;
curUrl = 'http://127.0.0.1:8090/dashticz/ical/?time=' + cache + '&url=' + curUrl;
curUrl = 'http://127.0.0.1:8090/myhome/dashticz/ical/?time=' + cache + '&url=' + curUrl;
unfortunately without success. I must add that I use windows 7 32 bit.
The only reason I am trying to do this is I would like to get it to work, but I did not mind the way it was before. So without any local stuff. It worked great ! And despite what people think, I think you did not use any information or gain anything from your hobby project. Google is probably a company to be more concerned about then Dashticz, if these people are so concerned about their privacy...
Keep up the good work, and I hope the project will stay alive for a long while !
( just downloaded the beta, with changes 18 hours ago, so there is still some development, and thanks for that ! )
I Love Domoticz ! And the community around it :-)
- EdwinK
@gielie, i thought Rob just did some updates on the beta (git pull gave me some changes), I hope Rob doesn't leave us, there is no better dashboard out there.
@poudenes I second, third and fourth that
I have TV, and Public transport working. only ical isn't working yet.
- EdwinK
Great.. How did you do that?
- Domoticz version: 3.7067
Im still involved and I am still proud on this project!
Its not that somebody is taking it over but there are some people adding new contributions to it, wich I love!
I started this as a hobby, put much time in it while earning nothing. That doesnt matter at all but, because of that, my regular work (running own business) was running behind.
- EdwinK
Second this also. (I seem to agree to a lot lately).Thuis wrote: ↑Monday 22 October 2018 11:52
What if you tyr localhost instead of 127.0.0.1? I know it should be the same thing in the end, but who knows.
- Thuis
Nope, also Localhost no success
- EdwinK
Damn...
But it seems you succeeded, looking at your previous post.
Thanks for the compliments.Thuis wrote: ↑Monday 22 October 2018 11:52First Rob, thank you for sharing your hobby with us. It is a great hobby and thank you we may also get the joy of using the nice Dashticz with Domoticz.robgeerts wrote: ↑Thursday 18 October 2018 14:59 Ok, i had to remove the scripts from my server.
What if you put a simple HTML-file in the root? Could you open that one?
If yes, try a PHP-file too with the following contents:
<?php
echo 'test';
If you see code in your browser, PHP is not working, if you only see 'test', installation is all good.
Do you get a warning ion your console window when opening Dashticz?
- Thuis
- Domoticz version: latest b
Crazy,
I have only installed lighttp, configured lighttp to run php and on port 8090 with the help of google. Created a link from /var/www to the dashticz folder und actiaved the local url in the settings. thats all. Used the latest beta. Now i have domoticz on 8080 with built in webserver and dashticz on 8090 with lighttp. That's all.
Don't forget to install the curl-Module within php!! That was my main fault.
I am wondering why this is so difficult.
MOses123
MOses123
Have you installed the curl module in php? That was my fault.Thuis wrote: ↑Monday 22 October 2018 13:05 http://127.0.0.1:8090/test.php
i get:
test
so that seems to be working.
- Thuis
In notepad++ i double click:
curUrl = 'http://127.0.0.1:8090/onshuis/dashticz/ical/?time='
Then my browser opens and i get: address bar: http://127.0.0.1:8090/onshuis/dashticz/ical/?time=
Fatal error: Call to undefined function curl_init() in C:\Apache24\www\onshuis\dashticz\ical\helpers\SG_iCal_Parser.php on line 44
So it must be accessible thru the server....
- Thuis
AHA ! curl module, oke, i can search the internet for a curl module, thank you !
- Thuis
when i do
<?php
phpinfo();
i can see i have curl installed in c:\curl\bin
and i also added it to the php.ini
<?php
phpinfo();
- Thuis
I took the c:\curl\bin from my omgevingsvariabelen, so i have to restart my pc .....
