[REQUEST] Plugin for Tuya
Re: [REQUEST] Plugin for Tuya
Number 7 si the "USB yes. And Yes True is On, False Off
A timer... I can set timers in the app, even for USB.
Something strange is that if I set timers, I can set the USB on alone , but I have no USB switch in the app, only a general and 3 for the plugs.
I just create a new branch on github named multiplug.
For now it is for experimentation only and specific testing.
frenchyyii, can you try this branch?
The goal is to test separately the different plug by changing manually the __DPS_ID in the file plugin.py.
I set it to '1' can you try with value '2' '3' and '7' ?
each time you will need to restart domoticz
I guess that '2' and '3' will control plug 2 and 3
I hope that '7' will control the usb...
I will test but Yes i did verify, 7 is USB.
Eric
Eric
Tested it's ok and 7 is the USB only. It's better than with the app to be able to swith USB On/Off separately.
Ready for your other tests
good news! For the other test, I am coding now... I will let you know.
new version ready for testing with your plug dps hard coded
Not too bad but It seems number 2 3 and 7 also activate/disactivate the number 1. I think it s just a minor bug.
This bug should be usefull to create a All On/All Off device, doesn't it ?
Last edited by frenchyyii on Friday 19 October 2018 23:55, edited 1 time in total.
Can you show me some logs?
2018-10-19 23:49:42.968 Status: User: Admin initiated a switch command (3402/Prise multiple Tuya - Tuya SmartPlug #3/On)
2018-10-19 23:49:43.137 (Prise multiple Tuya) 62 33 33 62 5a 75 50 2f 55 6f 72 45 66 4f 71 68 38 30 47 37 b33bZuP/UorEfOqh80G7
2018-10-19 23:49:43.137 (Prise multiple Tuya) 39 50 37 37 6c 63 3d 28 64 95 ac 00 00 aa 55 .. .. .. .. .. 9P77lc=(d��..�U
2018-10-19 23:49:43.137 (Prise multiple Tuya) Pushing 'onMessageCallback' on to queue
2018-10-19 23:49:43.137 (Prise multiple Tuya) Processing 'ReadEvent' message
2018-10-19 23:49:43.137 (Prise multiple Tuya) Received 155 bytes of data
2018-10-19 23:49:43.137 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 08 00 00 00 8b 00 00 00 00 ..U�...........�....
2018-10-19 23:49:43.137 (Prise multiple Tuya) 33 2e 31 38 61 39 39 38 38 34 37 36 35 35 35 66 65 33 36 48 3.18a9988476555fe36H
2018-10-19 23:49:43.137 (Prise multiple Tuya) 6b 54 45 44 50 77 54 59 2f 5a 41 41 78 44 6b 57 37 62 77 75 kTEDPwTY/ZAAxDkW7bwu
2018-10-19 23:49:43.137 (Prise multiple Tuya) 59 42 56 4f 32 43 56 39 62 61 46 79 6c 52 58 72 43 6b 32 77 YBVO2CV9baFylRXrCk2w
2018-10-19 23:49:43.137 (Prise multiple Tuya) 71 51 43 75 77 4d 47 7a 6a 43 63 37 2f 34 6e 33 4e 77 46 53 qQCuwMGzjCc7/4n3NwFS
2018-10-19 23:49:43.137 (Prise multiple Tuya) 68 4d 49 6f 35 6a 31 4f 5a 55 66 61 6a 63 6f 54 6d 52 70 54 hMIo5j1OZUfajcoTmRpT
2018-10-19 23:49:43.138 (Prise multiple Tuya) 62 33 33 62 54 37 39 77 6d 68 61 42 4b 4e 32 65 66 65 47 52 b33bT79wmhaBKN2efeGR
2018-10-19 23:49:43.138 (Prise multiple Tuya) 33 6a 42 32 72 49 3d a9 98 c6 ba 00 00 aa 55 .. .. .. .. .. 3jB2rI=��ƺ..�U
2018-10-19 23:49:43.138 (Prise multiple Tuya) Pushing 'onMessageCallback' on to queue
2018-10-19 23:49:43.138 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-19 23:49:43.138 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-19 23:49:43.138 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x07\x00\x00\x00\x0c\x00\x00\x00\x00x\x93p\x91\x00\x00\xaaU'
2018-10-19 23:49:43.139 (Prise multiple Tuya) Pushing 'WriteDirective' on to queue
2018-10-19 23:49:43.139 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-19 23:49:43.139 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-19 23:49:43.139 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00Z\x00\x00\x00\x00{"devId":"85502354807d3a50b8ee","dps":{"1":true,"2":false,"3":true,"7":false}}v\x84/\xb1\x00\x00\xaaU'
2018-10-19 23:49:43.140 (Prise multiple Tuya - Tuya SmartPlug #1) Updating device from 0:'Off' to have values 1:'On'.
2018-10-19 23:49:43.154 (Prise multiple Tuya) Update Prise multiple Tuya - Tuya SmartPlug #1: 1 - 'On'
2018-10-19 23:49:43.154 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-19 23:49:43.154 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-19 23:49:43.154 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x07\x00\x00\x00\x0c\x00\x00\x00\x00x\x93p\x91\x00\x00\xaaU'
2018-10-19 23:49:43.154 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00Z\x00\x00\x00\x00{"devId":"85502354807d3a50b8ee","dps":{"1":true,"2":false,"3":true,"7":false}}v\x84/\xb1\x00\x00\xaaU'
2018-10-19 23:49:43.154 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x8b\x00\x00\x00\x003.105e1a854e1061b9eHkTEDPwTY/ZAAxDkW7bwuYBVO2CV9baFylRXrCk2wqQCuwMGzjCc7/4n3NwFShMIo5j1OZUfajcoTmRpTb33bdp5QqELwhQE+bVbfe+4Xt8=T\xcao\x19\x00\x00\xaaU'
2018-10-19 23:49:43.154 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x8b\x00\x00\x00\x003.18691b7cd083db668HkTEDPwTY/ZAAxDkW7bwuYBVO2CV9baFylRXrCk2wqQCuwMGzjCc7/4n3NwFShMIo5j1OZUfajcoTmRpTb33bZuP/UorEfOqh80G79P77lc=(d\x95\xac\x00\x00\xaaU'
2018-10-19 23:49:43.155 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-19 23:49:43.155 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-19 23:49:43.155 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x8b\x00\x00\x00\x003.18a9988476555fe36HkTEDPwTY/ZAAxDkW7bwuYBVO2CV9baFylRXrCk2wqQCuwMGzjCc7/4n3NwFShMIo5j1OZUfajcoTmRpTb33bT79wmhaBKN2efeGR3jB2rI=\xa9\x98\xc6\xba\x00\x00\xaaU'
2018-10-19 23:49:43.155 (Prise multiple Tuya) Processing 'WriteDirective' message
2018-10-19 23:49:43.155 (Prise multiple Tuya) Sending 171 bytes of data
2018-10-19 23:49:43.155 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 07 00 00 00 9b 33 2e 31 34 ..U�...........�3.14
2018-10-19 23:49:43.155 (Prise multiple Tuya) 61 65 36 34 32 33 34 37 62 39 31 63 32 32 63 48 6b 54 45 44 ae642347b91c22cHkTED
2018-10-19 23:49:43.155 (Prise multiple Tuya) 50 77 54 59 2f 5a 41 41 78 44 6b 57 37 62 77 75 59 42 56 4f PwTY/ZAAxDkW7bwuYBVO
2018-10-19 23:49:43.155 (Prise multiple Tuya) 32 43 56 39 62 61 46 79 6c 52 58 72 43 6b 32 77 71 52 6f 75 2CV9baFylRXrCk2wqRou
2018-10-19 23:49:43.155 (Prise multiple Tuya) 43 61 57 42 6e 6b 6f 43 66 69 56 67 73 56 56 45 52 56 50 32 CaWBnkoCfiVgsVVERVP2
2018-10-19 23:49:43.155 (Prise multiple Tuya) 30 38 78 2f 58 70 6d 52 6d 71 4f 59 49 65 71 36 76 35 4c 6b 08x/XpmRmqOYIeq6v5Lk
2018-10-19 23:49:43.155 (Prise multiple Tuya) 6f 53 58 52 30 4b 72 38 4e 48 66 42 34 36 68 6d 2b 4a 46 2b oSXR0Kr8NHfB46hm+JF+
2018-10-19 23:49:43.155 (Prise multiple Tuya) 41 76 4d 55 75 6c 75 50 69 37 78 69 79 33 71 6d 72 32 4e 34 AvMUuluPi7xiy3qmr2N4
2018-10-19 23:49:43.155 (Prise multiple Tuya) 52 73 33 00 00 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. Rs3......�U
2018-10-19 23:49:43.155 (Prise multiple Tuya) Sending 86 bytes of data
2018-10-19 23:49:43.155 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 64 65 ..U�...........F{"de
2018-10-19 23:49:43.155 (Prise multiple Tuya) 76 49 64 22 3a 22 38 35 35 30 32 33 35 34 38 30 37 64 33 61 vId":"85502354807d3a
2018-10-19 23:49:43.155 (Prise multiple Tuya) 35 30 62 38 65 65 22 2c 22 67 77 49 64 22 3a 22 38 35 35 30 50b8ee","gwId":"8550
2018-10-19 23:49:43.155 (Prise multiple Tuya) 32 33 35 34 38 30 37 64 33 61 35 30 62 38 65 65 22 7d 00 00 2354807d3a50b8ee"}..
2018-10-19 23:49:43.155 (Prise multiple Tuya) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2018-10-19 23:49:43.163 (Prise multiple Tuya) Pushing 'ReadEvent' on to queue
2018-10-19 23:49:43.167 (Prise multiple Tuya) Pushing 'ReadEvent' on to queue
2018-10-19 23:49:43.206 (Prise multiple Tuya) Processing 'ReadEvent' message
2018-10-19 23:49:43.206 (Prise multiple Tuya) Received 28 bytes of data
2018-10-19 23:49:43.206 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 07 00 00 00 0c 00 00 00 00 ..U�................
2018-10-19 23:49:43.206 (Prise multiple Tuya) 78 93 70 91 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. x�p�..�U
2018-10-19 23:49:43.206 (Prise multiple Tuya) Pushing 'onMessageCallback' on to queue
2018-10-19 23:49:43.206 (Prise multiple Tuya) Received 155 bytes of data
2018-10-19 23:49:43.206 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 08 00 00 00 8b 00 00 00 00 ..U�...........�....
2018-10-19 23:49:43.206 (Prise multiple Tuya) 33 2e 31 39 30 63 63 61 63 36 39 39 37 37 66 65 36 36 35 48 3.190ccac69977fe665H
2018-10-19 23:49:43.206 (Prise multiple Tuya) 6b 54 45 44 50 77 54 59 2f 5a 41 41 78 44 6b 57 37 62 77 75 kTEDPwTY/ZAAxDkW7bwu
2018-10-19 23:49:43.206 (Prise multiple Tuya) 59 42 56 4f 32 43 56 39 62 61 46 79 6c 52 58 72 43 6b 32 77 YBVO2CV9baFylRXrCk2w
2018-10-19 23:49:43.206 (Prise multiple Tuya) 71 51 43 75 77 4d 47 7a 6a 43 63 37 2f 34 6e 33 4e 77 46 53 qQCuwMGzjCc7/4n3NwFS
2018-10-19 23:49:43.206 (Prise multiple Tuya) 68 4d 49 6f 35 6a 31 4f 5a 55 66 61 6a 63 6f 54 6d 52 70 54 hMIo5j1OZUfajcoTmRpT
2018-10-19 23:49:43.206 (Prise multiple Tuya) 62 33 33 62 52 31 4f 69 76 51 44 37 54 68 62 4f 50 69 6a 77 b33bR1OivQD7ThbOPijw
2018-10-19 23:49:43.207 (Prise multiple Tuya) 4b 39 4c 55 64 34 3d ee c3 8a bd 00 00 aa 55 .. .. .. .. .. K9LUd4=��..�U
2018-10-19 23:49:43.207 (Prise multiple Tuya) Pushing 'onMessageCallback' on to queue
2018-10-19 23:49:43.207 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-19 23:49:43.207 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-19 23:49:43.207 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x07\x00\x00\x00\x0c\x00\x00\x00\x00x\x93p\x91\x00\x00\xaaU'
2018-10-19 23:49:43.207 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x8b\x00\x00\x00\x003.190ccac69977fe665HkTEDPwTY/ZAAxDkW7bwuYBVO2CV9baFylRXrCk2wqQCuwMGzjCc7/4n3NwFShMIo5j1OZUfajcoTmRpTb33bR1OivQD7ThbOPijwK9LUd4=\xee\xc3\x8a\xbd\x00\x00\xaaU'
2018-10-19 23:49:43.215 (Prise multiple Tuya) Pushing 'ReadEvent' on to queue
2018-10-19 23:49:43.257 (Prise multiple Tuya) Processing 'ReadEvent' message
2018-10-19 23:49:43.257 (Prise multiple Tuya) Received 106 bytes of data
2018-10-19 23:49:43.257 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 5a 00 00 00 00 ..U�...........Z....
2018-10-19 23:49:43.257 (Prise multiple Tuya) 7b 22 64 65 76 49 64 22 3a 22 38 35 35 30 32 33 35 34 38 30 {"devId":"8550235480
2018-10-19 23:49:43.258 (Prise multiple Tuya) 37 64 33 61 35 30 62 38 65 65 22 2c 22 64 70 73 22 3a 7b 22 7d3a50b8ee","dps":{"
2018-10-19 23:49:43.258 (Prise multiple Tuya) 31 22 3a 74 72 75 65 2c 22 32 22 3a 66 61 6c 73 65 2c 22 33 1":true,"2":false,"3
2018-10-19 23:49:43.258 (Prise multiple Tuya) 22 3a 74 72 75 65 2c 22 37 22 3a 66 61 6c 73 65 7d 7d 76 84 ":true,"7":false}}v�
2018-10-19 23:49:43.258 (Prise multiple Tuya) 2f b1 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. /�..�U
2018-10-19 23:49:43.258 (Prise multiple Tuya) Pushing 'onMessageCallback' on to queue
2018-10-19 23:49:43.258 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-19 23:49:43.258 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-19 23:49:43.258 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00Z\x00\x00\x00\x00{"devId":"85502354807d3a50b8ee","dps":{"1":true,"2":false,"3":true,"7":false}}v\x84/\xb1\x00\x00\xaaU'
2018-10-19 23:49:48.668 (Prise multiple Tuya) Pushing 'onHeartbeatCallback' on to queue
2018-10-19 23:49:48.717 (Prise multiple Tuya) Processing 'onHeartbeatCallback' message
2018-10-19 23:49:48.717 (Prise multiple Tuya) Calling message handler 'onHeartbeat'.
2018-10-19 23:49:58.670 (Prise multiple Tuya) Pushing 'onHeartbeatCallback' on to queue
2018-10-19 23:49:58.685 (Prise multiple Tuya) Processing 'onHeartbeatCallback' message
2018-10-19 23:49:58.685 (Prise multiple Tuya) Calling message handler 'onHeartbeat'.
2018-10-19 23:49:58.686 (Prise multiple Tuya) Pushing 'WriteDirective' on to queue
2018-10-19 23:49:58.687 (Prise multiple Tuya) Processing 'WriteDirective' message
2018-10-19 23:49:58.687 (Prise multiple Tuya) Sending 86 bytes of data
2018-10-19 23:49:58.687 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 64 65 ..U�...........F{"de
2018-10-19 23:49:58.687 (Prise multiple Tuya) 76 49 64 22 3a 22 38 35 35 30 32 33 35 34 38 30 37 64 33 61 vId":"85502354807d3a
2018-10-19 23:49:58.687 (Prise multiple Tuya) 35 30 62 38 65 65 22 2c 22 67 77 49 64 22 3a 22 38 35 35 30 50b8ee","gwId":"8550
2018-10-19 23:49:58.687 (Prise multiple Tuya) 32 33 35 34 38 30 37 64 33 61 35 30 62 38 65 65 22 7d 00 00 2354807d3a50b8ee"}..
2018-10-19 23:49:58.687 (Prise multiple Tuya) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2018-10-19 23:49:58.906 (Prise multiple Tuya) Pushing 'ReadEvent' on to queue
2018-10-19 23:49:58.938 (Prise multiple Tuya) Processing 'ReadEvent' message
2018-10-19 23:49:58.938 (Prise multiple Tuya) Received 106 bytes of data
2018-10-19 23:49:58.938 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 5a 00 00 00 00 ..U�...........Z....
2018-10-19 23:49:58.938 (Prise multiple Tuya) 7b 22 64 65 76 49 64 22 3a 22 38 35 35 30 32 33 35 34 38 30 {"devId":"8550235480
2018-10-19 23:49:58.938 (Prise multiple Tuya) 37 64 33 61 35 30 62 38 65 65 22 2c 22 64 70 73 22 3a 7b 22 7d3a50b8ee","dps":{"
2018-10-19 23:49:58.938 (Prise multiple Tuya) 31 22 3a 74 72 75 65 2c 22 32 22 3a 66 61 6c 73 65 2c 22 33 1":true,"2":false,"3
2018-10-19 23:49:58.938 (Prise multiple Tuya) 22 3a 74 72 75 65 2c 22 37 22 3a 66 61 6c 73 65 7d 7d 76 84 ":true,"7":false}}v�
2018-10-19 23:49:58.938 (Prise multiple Tuya) 2f b1 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. /�..�U
2018-10-19 23:49:58.938 (Prise multiple Tuya) Pushing 'onMessageCallback' on to queue
2018-10-19 23:49:58.938 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-19 23:49:58.938 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-19 23:49:58.939 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00Z\x00\x00\x00\x00{"devId":"85502354807d3a50b8ee","dps":{"1":true,"2":false,"3":true,"7":false}}v\x84/\xb1\x00\x00\xaaU'
I was logging when you asked for it
This log starts from everything off to 3 only On
Not sure to understand the bug.
Can you do in order:
turn on 1
turn off 1
turn on 2
turn off 2
and provide the logs of that case
turn on 1
turn off 1
turn on 2
turn off 2
Just 1/2/3 On/Off should be more usefull... or we could control it with DZ directly using master/slave devices.frenchyyii wrote: ↑Friday 19 October 2018 23:45 This bug should be usefull to create a All On/All Off device, doesn't it ?
from everything off, 1 On then Off
2018-10-20 00:01:08.111 Status: User: Admin initiated a switch command (3400/Prise multiple Tuya - Tuya SmartPlug #1/On)
2018-10-20 00:01:10.483 (Prise multiple Tuya) 57 30 51 65 4b 57 78 54 67 63 48 61 58 42 4f 56 72 59 44 32 W0QeKWxTgcHaXBOVrYD2
2018-10-20 00:01:10.483 (Prise multiple Tuya) 30 38 78 2f 58 70 6d 52 6d 71 4f 59 49 65 71 36 76 35 4c 6b 08x/XpmRmqOYIeq6v5Lk
2018-10-20 00:01:10.483 (Prise multiple Tuya) 6f 53 58 52 30 4b 72 38 4e 48 66 42 34 36 68 6d 2b 4a 46 2b oSXR0Kr8NHfB46hm+JF+
2018-10-20 00:01:10.483 (Prise multiple Tuya) 41 73 78 76 6f 51 50 4c 61 6d 46 55 73 64 6c 6a 31 34 79 70 AsxvoQPLamFUsdlj14yp
2018-10-20 00:01:10.484 (Prise multiple Tuya) 53 30 62 59 6a 66 74 6b 59 38 77 58 36 4a 38 4b 61 6a 39 78 S0bYjftkY8wX6J8Kaj9x
2018-10-20 00:01:10.484 (Prise multiple Tuya) 79 63 6a 5a 51 3d 3d 00 00 00 00 00 00 aa 55 .. .. .. .. .. ycjZQ==......�U
2018-10-20 00:01:10.484 (Prise multiple Tuya) Processing 'WriteDirective' message
2018-10-20 00:01:10.484 (Prise multiple Tuya) Sending 86 bytes of data
2018-10-20 00:01:10.484 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 64 65 ..U�...........F{"de
2018-10-20 00:01:10.484 (Prise multiple Tuya) 76 49 64 22 3a 22 38 35 35 30 32 33 35 34 38 30 37 64 33 61 vId":"85502354807d3a
2018-10-20 00:01:10.484 (Prise multiple Tuya) 35 30 62 38 65 65 22 2c 22 67 77 49 64 22 3a 22 38 35 35 30 50b8ee","gwId":"8550
2018-10-20 00:01:10.484 (Prise multiple Tuya) 32 33 35 34 38 30 37 64 33 61 35 30 62 38 65 65 22 7d 00 00 2354807d3a50b8ee"}..
2018-10-20 00:01:10.484 (Prise multiple Tuya) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2018-10-20 00:01:10.484 (Prise multiple Tuya) Pushing 'ReadEvent' on to queue
2018-10-20 00:01:10.495 (Prise multiple Tuya) Pushing 'ReadEvent' on to queue
2018-10-20 00:01:10.499 (Prise multiple Tuya) Pushing 'ReadEvent' on to queue
2018-10-20 00:01:10.534 (Prise multiple Tuya) Processing 'ReadEvent' message
2018-10-20 00:01:10.534 (Prise multiple Tuya) Received 108 bytes of data
2018-10-20 00:01:10.534 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 5c 00 00 00 00 ..U�...........\....
2018-10-20 00:01:10.535 (Prise multiple Tuya) 7b 22 64 65 76 49 64 22 3a 22 38 35 35 30 32 33 35 34 38 30 {"devId":"8550235480
2018-10-20 00:01:10.535 (Prise multiple Tuya) 37 64 33 61 35 30 62 38 65 65 22 2c 22 64 70 73 22 3a 7b 22 7d3a50b8ee","dps":{"
2018-10-20 00:01:10.535 (Prise multiple Tuya) 31 22 3a 66 61 6c 73 65 2c 22 32 22 3a 66 61 6c 73 65 2c 22 1":false,"2":false,"
2018-10-20 00:01:10.535 (Prise multiple Tuya) 33 22 3a 66 61 6c 73 65 2c 22 37 22 3a 66 61 6c 73 65 7d 7d 3":false,"7":false}}
2018-10-20 00:01:10.535 (Prise multiple Tuya) fc b2 c4 2f 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. ���/..�U
2018-10-20 00:01:10.535 (Prise multiple Tuya) Pushing 'onMessageCallback' on to queue
2018-10-20 00:01:10.535 (Prise multiple Tuya) Processing 'ReadEvent' message
2018-10-20 00:01:10.535 (Prise multiple Tuya) Received 28 bytes of data
2018-10-20 00:01:10.535 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 07 00 00 00 0c 00 00 00 00 ..U�................
2018-10-20 00:01:10.535 (Prise multiple Tuya) 78 93 70 91 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. x�p�..�U
2018-10-20 00:01:10.535 (Prise multiple Tuya) Received 108 bytes of data
2018-10-20 00:01:10.535 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 5c 00 00 00 00 ..U�...........\....
2018-10-20 00:01:10.536 (Prise multiple Tuya) 31 22 3a 66 61 6c 73 65 2c 22 32 22 3a 66 61 6c 73 65 2c 22 1":false,"2":false,"
2018-10-20 00:01:10.536 (Prise multiple Tuya) 33 22 3a 66 61 6c 73 65 2c 22 37 22 3a 66 61 6c 73 65 7d 7d 3":false,"7":false}}
2018-10-20 00:01:10.536 (Prise multiple Tuya) fc b2 c4 2f 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. ���/..�U
2018-10-20 00:01:10.536 (Prise multiple Tuya) Pushing 'onMessageCallback' on to queue
2018-10-20 00:01:10.536 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-20 00:01:10.536 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-20 00:01:10.536 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\\\x00\x00\x00\x00{"devId":"85502354807d3a50b8ee","dps":{"1":false,"2":false,"3":false,"7":false}}\xfc\xb2\xc4/\x00\x00\xaaU'
2018-10-20 00:01:10.536 (Prise multiple Tuya - Tuya SmartPlug #1) Updating device from 1:'On' to have values 0:'Off'.
2018-10-20 00:01:10.548 (Prise multiple Tuya) Update Prise multiple Tuya - Tuya SmartPlug #1: 0 - 'Off'
2018-10-20 00:01:10.548 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-20 00:01:10.548 (Prise multiple Tuya) Pushing 'ReadEvent' on to queue
2018-10-20 00:01:10.548 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-20 00:01:10.548 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x07\x00\x00\x00\x0c\x00\x00\x00\x00x\x93p\x91\x00\x00\xaaU'
2018-10-20 00:01:10.549 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-20 00:01:10.549 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-20 00:01:10.549 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\\\x00\x00\x00\x00{"devId":"85502354807d3a50b8ee","dps":{"1":false,"2":false,"3":false,"7":false}}\xfc\xb2\xc4/\x00\x00\xaaU'
2018-10-20 00:01:10.549 (Prise multiple Tuya) Processing 'ReadEvent' message
2018-10-20 00:01:10.549 (Prise multiple Tuya) Received 446 bytes of data
2018-10-20 00:01:10.549 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 07 00 00 00 0c 00 00 00 00 ..U�................
2018-10-20 00:01:10.549 (Prise multiple Tuya) 78 93 70 91 00 00 aa 55 00 00 55 aa 00 00 00 00 00 00 00 08 x�p�..�U..U�........
2018-10-20 00:01:10.549 (Prise multiple Tuya) 00 00 00 8b 00 00 00 00 33 2e 31 61 64 35 36 62 61 31 33 34 ...�....3.1ad56ba134
2018-10-20 00:01:10.549 (Prise multiple Tuya) 66 33 31 36 36 64 33 48 6b 54 45 44 50 77 54 59 2f 5a 41 41 f3166d3HkTEDPwTY/ZAA
2018-10-20 00:01:10.549 (Prise multiple Tuya) 78 44 6b 57 37 62 77 75 59 42 56 4f 32 43 56 39 62 61 46 79 xDkW7bwuYBVO2CV9baFy
2018-10-20 00:01:10.549 (Prise multiple Tuya) 6c 52 58 72 43 6b 32 77 71 54 2b 4f 32 6c 36 77 59 5a 51 39 lRXrCk2wqT+O2l6wYZQ9
2018-10-20 00:01:10.549 (Prise multiple Tuya) 77 6d 4e 48 75 6f 6d 63 62 77 78 68 78 7a 48 50 78 68 6a 73 wmNHuomcbwxhxzHPxhjs
2018-10-20 00:01:10.549 (Prise multiple Tuya) 48 31 2f 63 62 69 70 70 62 51 65 69 4d 37 59 37 37 4d 51 76 H1/cbippbQeiM7Y77MQv
2018-10-20 00:01:10.549 (Prise multiple Tuya) 38 76 6b 73 2b 66 44 30 74 38 53 4d 54 38 3d 75 9e f0 be 00 8vks+fD0t8SMT8=u��.
2018-10-20 00:01:10.550 (Prise multiple Tuya) 00 aa 55 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 5c 00 .�U..U�...........\.
2018-10-20 00:01:10.550 (Prise multiple Tuya) 00 00 00 7b 22 64 65 76 49 64 22 3a 22 38 35 35 30 32 33 35 ...{"devId":"8550235
2018-10-20 00:01:10.550 (Prise multiple Tuya) 34 38 30 37 64 33 61 35 30 62 38 65 65 22 2c 22 64 70 73 22 4807d3a50b8ee","dps"
2018-10-20 00:01:10.550 (Prise multiple Tuya) 3a 7b 22 31 22 3a 66 61 6c 73 65 2c 22 32 22 3a 66 61 6c 73 :{"1":false,"2":fals
2018-10-20 00:01:10.550 (Prise multiple Tuya) 65 2c 22 33 22 3a 66 61 6c 73 65 2c 22 37 22 3a 66 61 6c 73 e,"3":false,"7":fals
2018-10-20 00:01:10.550 (Prise multiple Tuya) 65 7d 7d fc b2 c4 2f 00 00 aa 55 00 00 55 aa 00 00 00 00 00 e}}���/..�U..U�.....
2018-10-20 00:01:10.550 (Prise multiple Tuya) 00 00 08 00 00 00 8b 00 00 00 00 33 2e 31 63 33 38 64 61 64 ......�....3.1c38dad
2018-10-20 00:01:10.550 (Prise multiple Tuya) 30 38 36 33 66 38 30 64 32 66 48 6b 54 45 44 50 77 54 59 2f 0863f80d2fHkTEDPwTY/
2018-10-20 00:01:10.550 (Prise multiple Tuya) 5a 41 41 78 44 6b 57 37 62 77 75 59 42 56 4f 32 43 56 39 62 ZAAxDkW7bwuYBVO2CV9b
2018-10-20 00:01:10.550 (Prise multiple Tuya) 61 46 79 6c 52 58 72 43 6b 32 77 71 54 2b 4f 32 6c 36 77 59 aFylRXrCk2wqT+O2l6wY
2018-10-20 00:01:10.550 (Prise multiple Tuya) 5a 51 39 77 6d 4e 48 75 6f 6d 63 62 77 78 68 78 7a 48 50 78 ZQ9wmNHuomcbwxhxzHPx
2018-10-20 00:01:10.550 (Prise multiple Tuya) 68 6a 73 48 31 2f 63 62 69 70 70 62 51 65 69 4f 6f 58 49 5a hjsH1/cbippbQeiOoXIZ
2018-10-20 00:01:10.550 (Prise multiple Tuya) 6a 4e 4a 33 76 4c 63 69 39 6c 42 6d 4d 65 72 70 6b 3d 3c 8a jNJ3vLci9lBmMerpk=<�
2018-10-20 00:01:10.551 (Prise multiple Tuya) 16 54 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .T..�U
2018-10-20 00:01:10.551 (Prise multiple Tuya) Pushing 'onMessageCallback' on to queue
2018-10-20 00:01:10.551 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-20 00:01:10.551 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-20 00:01:10.551 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x07\x00\x00\x00\x0c\x00\x00\x00\x00x\x93p\x91\x00\x00\xaaU\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x8b\x00\x00\x00\x003.1ad56ba134f3166d3HkTEDPwTY/ZAAxDkW7bwuYBVO2CV9baFylRXrCk2wqT+O2l6wYZQ9wmNHuomcbwxhxzHPxhjsH1/cbippbQeiM7Y77MQv8vks+fD0t8SMT8=u\x9e\xf0\xbe\x00\x00\xaaU\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\\\x00\x00\x00\x00{"devId":"85502354807d3a50b8ee","dps":{"1":false,"2":false,"3":false,"7":false}}\xfc\xb2\xc4/\x00\x00\xaaU\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x8b\x00\x00\x00\x003.1c38dad0863f80d2fHkTEDPwTY/ZAAxDkW7bwuYBVO2CV9baFylRXrCk2wqT+O2l6wYZQ9wmNHuomcbwxhxzHPxhjsH1/cbippbQeiOoXIZjNJ3vLci9lBmMerpk=<\x8a\x16T\x00\x00\xaaU'
2018-10-20 00:01:10.386 Status: User: Admin initiated a switch command (3400/Prise multiple Tuya - Tuya SmartPlug #1/Off)
2018-10-20 00:01:10.882 Status: LUA: (PING) ping fail Galaxy S7
2018-10-20 00:01:10.908 Status: LUA: script_time_vigilance_meteofrance.lua
2018-10-20 00:01:18.874 (Prise multiple Tuya) Pushing 'onHeartbeatCallback' on to queue
2018-10-20 00:01:18.916 (Prise multiple Tuya) Processing 'onHeartbeatCallback' message
2018-10-20 00:01:18.916 (Prise multiple Tuya) Calling message handler 'onHeartbeat'.
2018-10-20 00:01:18.917 (Prise multiple Tuya) Pushing 'WriteDirective' on to queue
2018-10-20 00:01:18.917 (Prise multiple Tuya) Processing 'WriteDirective' message
2018-10-20 00:01:18.917 (Prise multiple Tuya) Sending 86 bytes of data
2018-10-20 00:01:18.917 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 64 65 ..U�...........F{"de
2018-10-20 00:01:18.917 (Prise multiple Tuya) 76 49 64 22 3a 22 38 35 35 30 32 33 35 34 38 30 37 64 33 61 vId":"85502354807d3a
2018-10-20 00:01:18.917 (Prise multiple Tuya) 35 30 62 38 65 65 22 2c 22 67 77 49 64 22 3a 22 38 35 35 30 50b8ee","gwId":"8550
2018-10-20 00:01:18.917 (Prise multiple Tuya) 32 33 35 34 38 30 37 64 33 61 35 30 62 38 65 65 22 7d 00 00 2354807d3a50b8ee"}..
2018-10-20 00:01:18.917 (Prise multiple Tuya) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2018-10-20 00:01:18.939 (Prise multiple Tuya) Pushing 'ReadEvent' on to queue
2018-10-20 00:01:18.967 (Prise multiple Tuya) Processing 'ReadEvent' message
2018-10-20 00:01:18.968 (Prise multiple Tuya) Received 108 bytes of data
2018-10-20 00:01:18.968 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 5c 00 00 00 00 ..U�...........\....
2018-10-20 00:01:18.968 (Prise multiple Tuya) 7b 22 64 65 76 49 64 22 3a 22 38 35 35 30 32 33 35 34 38 30 {"devId":"8550235480
2018-10-20 00:01:18.968 (Prise multiple Tuya) 37 64 33 61 35 30 62 38 65 65 22 2c 22 64 70 73 22 3a 7b 22 7d3a50b8ee","dps":{"
2018-10-20 00:01:18.968 (Prise multiple Tuya) 31 22 3a 66 61 6c 73 65 2c 22 32 22 3a 66 61 6c 73 65 2c 22 1":false,"2":false,"
2018-10-20 00:01:18.968 (Prise multiple Tuya) 33 22 3a 66 61 6c 73 65 2c 22 37 22 3a 66 61 6c 73 65 7d 7d 3":false,"7":false}}
2018-10-20 00:01:18.968 (Prise multiple Tuya) fc b2 c4 2f 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. ���/..�U
2018-10-20 00:01:18.968 (Prise multiple Tuya) Pushing 'onMessageCallback' on to queue
2018-10-20 00:01:18.968 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-20 00:01:18.968 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-20 00:01:18.968 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\\\x00\x00\x00\x00{"devId":"85502354807d3a50b8ee","dps":{"1":false,"2":false,"3":false,"7":false}}\xfc\xb2\xc4/\x00\x00\xaaU'
Last edited by frenchyyii on Saturday 20 October 2018 0:11, edited 1 time in total.
from everythin Off, 2 ON then 2 OFF
[color=#BFBFBF][color=#FFBFBF]
Tout
Statut
Filtre:
tuya
X
2018-10-20 00:07:08.975 (Prise multiple Tuya) Pushing 'onHeartbeatCallback' on to queue
2018-10-20 00:07:08.994 (Prise multiple Tuya) Processing 'onHeartbeatCallback' message
2018-10-20 00:07:08.994 (Prise multiple Tuya) Calling message handler 'onHeartbeat'.
2018-10-20 00:07:14.625 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00Z\x00\x00\x00\x00{"devId":"85502354807d3a50b8ee","dps":{"1":true,"2":true,"3":false,"7":false}}\xb9&sG\x00\x00\xaaU\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x07\x00\x00\x00\x0c\x00\x00\x00\x00x\x93p\x91\x00\x00\xaaU\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00Z\x00\x00\x00\x00{"devId":"85502354807d3a50b8ee","dps":{"1":true,"2":true,"3":false,"7":false}}\xb9&sG\x00\x00\xaaU\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x8b\x00\x00\x00\x003.1247fc65ab0976da4HkTEDPwTY/ZAAxDkW7bwuYBVO2CV9baFylRXrCk2wqQCuwMGzjCc7/4n3NwFShMISqyxlsySLKrngmzoL88qfJPXvQE3svoapSn/b92Trho=\xcfue\xda\x00\x00\xaaU\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x8b\x00\x00\x00\x003.17fbbe908121e03faHkTEDPwTY/ZAAxDkW7bwuYBVO2CV9baFylRXrCk2wqQCuwMGzjCc7/4n3NwFShMISqyxlsySLKrngmzoL88qfIyw+CzD66QQOZalGW5Va/Y=\xe0\x9f<\x82\x00\x00\xaaU'
2018-10-20 00:07:14.625 (Prise multiple Tuya - Tuya SmartPlug #1) Updating device from 0:'Off' to have values 1:'On'.
2018-10-20 00:07:14.631 (Prise multiple Tuya) Update Prise multiple Tuya - Tuya SmartPlug #1: 1 - 'On'
2018-10-20 00:07:14.632 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-20 00:07:14.632 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-20 00:07:14.632 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x07\x00\x00\x00\x0c\x00\x00\x00\x00x\x93p\x91\x00\x00\xaaU'
2018-10-20 00:07:14.635 (Prise multiple Tuya) Pushing 'ReadEvent' on to queue
2018-10-20 00:07:14.682 (Prise multiple Tuya) Processing 'ReadEvent' message
2018-10-20 00:07:14.682 (Prise multiple Tuya) Received 550 bytes of data
2018-10-20 00:07:14.682 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 5a 00 00 00 00 ..U�...........Z....
2018-10-20 00:07:14.682 (Prise multiple Tuya) 7b 22 64 65 76 49 64 22 3a 22 38 35 35 30 32 33 35 34 38 30 {"devId":"8550235480
2018-10-20 00:07:14.682 (Prise multiple Tuya) 37 64 33 61 35 30 62 38 65 65 22 2c 22 64 70 73 22 3a 7b 22 7d3a50b8ee","dps":{"
2018-10-20 00:07:14.682 (Prise multiple Tuya) 31 22 3a 74 72 75 65 2c 22 32 22 3a 74 72 75 65 2c 22 33 22 1":true,"2":true,"3"
2018-10-20 00:07:14.682 (Prise multiple Tuya) 3a 66 61 6c 73 65 2c 22 37 22 3a 66 61 6c 73 65 7d 7d b9 26 :false,"7":false}}�&
2018-10-20 00:07:14.682 (Prise multiple Tuya) 73 47 00 00 aa 55 00 00 55 aa 00 00 00 00 00 00 00 07 00 00 sG..�U..U�..........
2018-10-20 00:07:14.682 (Prise multiple Tuya) 00 0c 00 00 00 00 78 93 70 91 00 00 aa 55 00 00 55 aa 00 00 ......x�p�..�U..U�..
2018-10-20 00:07:14.682 (Prise multiple Tuya) 00 00 00 00 00 0a 00 00 00 5a 00 00 00 00 7b 22 64 65 76 49 .........Z....{"devI
2018-10-20 00:07:14.682 (Prise multiple Tuya) 64 22 3a 22 38 35 35 30 32 33 35 34 38 30 37 64 33 61 35 30 d":"85502354807d3a50
2018-10-20 00:07:14.682 (Prise multiple Tuya) 62 38 65 65 22 2c 22 64 70 73 22 3a 7b 22 31 22 3a 74 72 75 b8ee","dps":{"1":tru
2018-10-20 00:07:14.682 (Prise multiple Tuya) 65 2c 22 32 22 3a 74 72 75 65 2c 22 33 22 3a 66 61 6c 73 65 e,"2":true,"3":false
2018-10-20 00:07:14.682 (Prise multiple Tuya) 2c 22 37 22 3a 66 61 6c 73 65 7d 7d b9 26 73 47 00 00 aa 55 ,"7":false}}�&sG..�U
2018-10-20 00:07:14.682 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 08 00 00 00 8b 00 00 00 00 ..U�...........�....
2018-10-20 00:07:14.682 (Prise multiple Tuya) 33 2e 31 31 36 36 63 30 62 30 63 64 39 38 35 32 30 38 61 48 3.1166c0b0cd985208aH
2018-10-20 00:07:14.682 (Prise multiple Tuya) 6b 54 45 44 50 77 54 59 2f 5a 41 41 78 44 6b 57 37 62 77 75 kTEDPwTY/ZAAxDkW7bwu
2018-10-20 00:07:14.682 (Prise multiple Tuya) 59 42 56 4f 32 43 56 39 62 61 46 79 6c 52 58 72 43 6b 32 77 YBVO2CV9baFylRXrCk2w
2018-10-20 00:07:14.682 (Prise multiple Tuya) 71 51 43 75 77 4d 47 7a 6a 43 63 37 2f 34 6e 33 4e 77 46 53 qQCuwMGzjCc7/4n3NwFS
2018-10-20 00:07:14.683 (Prise multiple Tuya) 68 4d 49 53 71 79 78 6c 73 79 53 4c 4b 72 6e 67 6d 7a 6f 4c hMISqyxlsySLKrngmzoL
2018-10-20 00:07:14.683 (Prise multiple Tuya) 38 38 71 66 4e 72 67 59 4e 6c 6d 31 73 71 65 37 52 59 6f 56 88qfNrgYNlm1sqe7RYoV
2018-10-20 00:07:14.683 (Prise multiple Tuya) 77 54 39 71 61 6b 3d 4d 84 c2 c9 00 00 aa 55 00 00 55 aa 00 wT9qak=M���..�U..U�.
2018-10-20 00:07:14.683 (Prise multiple Tuya) 00 00 00 00 00 00 08 00 00 00 8b 00 00 00 00 33 2e 31 32 61 ..........�....3.12a
2018-10-20 00:07:14.683 (Prise multiple Tuya) 34 39 66 32 30 36 62 64 61 38 65 38 31 61 48 6b 54 45 44 50 49f206bda8e81aHkTEDP
2018-10-20 00:07:14.683 (Prise multiple Tuya) 77 54 59 2f 5a 41 41 78 44 6b 57 37 62 77 75 59 42 56 4f 32 wTY/ZAAxDkW7bwuYBVO2
2018-10-20 00:07:14.683 (Prise multiple Tuya) 43 56 39 62 61 46 79 6c 52 58 72 43 6b 32 77 71 51 43 75 77 CV9baFylRXrCk2wqQCuw
2018-10-20 00:07:14.683 (Prise multiple Tuya) 4d 47 7a 6a 43 63 37 2f 34 6e 33 4e 77 46 53 68 4d 49 53 71 MGzjCc7/4n3NwFShMISq
2018-10-20 00:07:14.683 (Prise multiple Tuya) 79 78 6c 73 79 53 4c 4b 72 6e 67 6d 7a 6f 4c 38 38 71 66 41 yxlsySLKrngmzoL88qfA
2018-10-20 00:07:14.683 (Prise multiple Tuya) 33 53 69 2f 74 44 4b 33 32 77 68 36 62 54 67 41 47 73 4a 6c 3Si/tDK32wh6bTgAGsJl
2018-10-20 00:07:14.683 (Prise multiple Tuya) 67 3d 4c 81 df 9c 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. g=L�ߜ..�U
2018-10-20 00:07:14.683 (Prise multiple Tuya) Pushing 'onMessageCallback' on to queue
2018-10-20 00:07:14.683 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-20 00:07:14.683 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-20 00:07:14.683 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00Z\x00\x00\x00\x00{"devId":"85502354807d3a50b8ee","dps":{"1":true,"2":true,"3":false,"7":false}}\xb9&sG\x00\x00\xaaU\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x07\x00\x00\x00\x0c\x00\x00\x00\x00x\x93p\x91\x00\x00\xaaU\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00Z\x00\x00\x00\x00{"devId":"85502354807d3a50b8ee","dps":{"1":true,"2":true,"3":false,"7":false}}\xb9&sG\x00\x00\xaaU\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x8b\x00\x00\x00\x003.1166c0b0cd985208aHkTEDPwTY/ZAAxDkW7bwuYBVO2CV9baFylRXrCk2wqQCuwMGzjCc7/4n3NwFShMISqyxlsySLKrngmzoL88qfNrgYNlm1sqe7RYoVwT9qak=M\x84\xc2\xc9\x00\x00\xaaU\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x8b\x00\x00\x00\x003.12a49f206bda8e81aHkTEDPwTY/ZAAxDkW7bwuYBVO2CV9baFylRXrCk2wqQCuwMGzjCc7/4n3NwFShMISqyxlsySLKrngmzoL88qfA3Si/tDK32wh6bTgAGsJlg=L\x81\xdf\x9c\x00\x00\xaaU'[/color][/color]
2018-10-20 00:07:14.421 Status: User: Admin initiated a switch command (3401/Prise multiple Tuya - Tuya SmartPlug #2/On)
2018-10-20 00:07:18.415 (Prise multiple Tuya) Pushing 'onCommandCallback' on to queue
2018-10-20 00:07:18.442 (Prise multiple Tuya) Processing 'onCommandCallback' message
2018-10-20 00:07:18.442 (Prise multiple Tuya) Calling message handler 'onCommand'.
2018-10-20 00:07:18.442 (Prise multiple Tuya) onCommand called for Unit 2: Parameter 'Off
2018-10-20 00:07:18.443 (Prise multiple Tuya) Pushing 'WriteDirective' on to queue
2018-10-20 00:07:18.443 (Prise multiple Tuya) Processing 'WriteDirective' message
2018-10-20 00:07:18.443 (Prise multiple Tuya) Sending 195 bytes of data
2018-10-20 00:07:18.444 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 07 00 00 00 b3 33 2e 31 65 ..U�...........�3.1e
2018-10-20 00:07:18.444 (Prise multiple Tuya) 36 36 30 35 63 65 61 35 33 37 63 63 35 62 37 48 6b 54 45 44 6605cea537cc5b7HkTED
2018-10-20 00:07:18.444 (Prise multiple Tuya) 50 77 54 59 2f 5a 41 41 78 44 6b 57 37 62 77 75 59 42 56 4f PwTY/ZAAxDkW7bwuYBVO
2018-10-20 00:07:18.444 (Prise multiple Tuya) 32 43 56 39 62 61 46 79 6c 52 58 72 43 6b 32 77 71 54 67 6d 2CV9baFylRXrCk2wqTgm
2018-10-20 00:07:18.444 (Prise multiple Tuya) 71 32 54 33 2f 51 56 4d 47 39 4a 64 7a 53 57 4c 43 35 69 32 q2T3/QVMG9JdzSWLC5i2
2018-10-20 00:07:18.444 (Prise multiple Tuya) 30 38 78 2f 58 70 6d 52 6d 71 4f 59 49 65 71 36 76 35 4c 6b 08x/XpmRmqOYIeq6v5Lk
2018-10-20 00:07:18.444 (Prise multiple Tuya) 6f 53 58 52 30 4b 72 38 4e 48 66 42 34 36 68 6d 2b 4a 46 2b oSXR0Kr8NHfB46hm+JF+
2018-10-20 00:07:18.444 (Prise multiple Tuya) 41 76 63 38 76 61 4a 45 58 4b 59 54 69 70 79 42 4d 48 56 58 Avc8vaJEXKYTipyBMHVX
2018-10-20 00:07:18.444 (Prise multiple Tuya) 42 4c 45 59 6a 66 74 6b 59 38 77 58 36 4a 38 4b 61 6a 39 78 BLEYjftkY8wX6J8Kaj9x
2018-10-20 00:07:18.444 (Prise multiple Tuya) 79 63 6a 5a 51 3d 3d 00 00 00 00 00 00 aa 55 .. .. .. .. .. ycjZQ==......�U
2018-10-20 00:07:18.444 (Prise multiple Tuya) Processing 'WriteDirective' message
2018-10-20 00:07:18.444 (Prise multiple Tuya) Sending 86 bytes of data
2018-10-20 00:07:18.444 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 64 65 ..U�...........F{"de
2018-10-20 00:07:18.444 (Prise multiple Tuya) 76 49 64 22 3a 22 38 35 35 30 32 33 35 34 38 30 37 64 33 61 vId":"85502354807d3a
2018-10-20 00:07:18.444 (Prise multiple Tuya) 35 30 62 38 65 65 22 2c 22 67 77 49 64 22 3a 22 38 35 35 30 50b8ee","gwId":"8550
2018-10-20 00:07:18.444 (Prise multiple Tuya) 32 33 35 34 38 30 37 64 33 61 35 30 62 38 65 65 22 7d 00 00 2354807d3a50b8ee"}..
2018-10-20 00:07:18.444 (Prise multiple Tuya) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2018-10-20 00:07:18.581 (Prise multiple Tuya) Pushing 'ReadEvent' on to queue
2018-10-20 00:07:18.594 (Prise multiple Tuya) Processing 'ReadEvent' message
2018-10-20 00:07:18.594 (Prise multiple Tuya) Received 28 bytes of data
2018-10-20 00:07:18.595 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 07 00 00 00 0c 00 00 00 00 ..U�................
2018-10-20 00:07:18.595 (Prise multiple Tuya) 78 93 70 91 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. x�p�..�U
2018-10-20 00:07:18.595 (Prise multiple Tuya) Pushing 'onMessageCallback' on to queue
2018-10-20 00:07:18.595 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-20 00:07:18.595 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-20 00:07:18.595 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x07\x00\x00\x00\x0c\x00\x00\x00\x00x\x93p\x91\x00\x00\xaaU'
2018-10-20 00:07:18.596 (Prise multiple Tuya) Pushing 'WriteDirective' on to queue
2018-10-20 00:07:18.596 (Prise multiple Tuya) Processing 'WriteDirective' message
2018-10-20 00:07:18.596 (Prise multiple Tuya) Sending 195 bytes of data
2018-10-20 00:07:18.596 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 07 00 00 00 b3 33 2e 31 64 ..U�...........�3.1d
2018-10-20 00:07:18.597 (Prise multiple Tuya) 39 35 36 31 61 63 38 39 63 35 61 31 62 32 66 48 6b 54 45 44 9561ac89c5a1b2fHkTED
2018-10-20 00:07:18.597 (Prise multiple Tuya) 50 77 54 59 2f 5a 41 41 78 44 6b 57 37 62 77 75 59 42 56 4f PwTY/ZAAxDkW7bwuYBVO
2018-10-20 00:07:18.597 (Prise multiple Tuya) 32 43 56 39 62 61 46 79 6c 52 58 72 43 6b 32 77 71 54 67 6d 2CV9baFylRXrCk2wqTgm
2018-10-20 00:07:18.597 (Prise multiple Tuya) 71 32 54 33 2f 51 56 4d 47 39 4a 64 7a 53 57 4c 43 35 69 32 q2T3/QVMG9JdzSWLC5i2
2018-10-20 00:07:18.597 (Prise multiple Tuya) 30 38 78 2f 58 70 6d 52 6d 71 4f 59 49 65 71 36 76 35 4c 6b 08x/XpmRmqOYIeq6v5Lk
2018-10-20 00:07:18.597 (Prise multiple Tuya) 6f 53 58 52 30 4b 72 38 4e 48 66 42 34 36 68 6d 2b 4a 46 2b oSXR0Kr8NHfB46hm+JF+
2018-10-20 00:07:18.597 (Prise multiple Tuya) 41 73 78 76 6f 51 50 4c 61 6d 46 55 73 64 6c 6a 31 34 79 70 AsxvoQPLamFUsdlj14yp
2018-10-20 00:07:18.597 (Prise multiple Tuya) 53 30 62 59 6a 66 74 6b 59 38 77 58 36 4a 38 4b 61 6a 39 78 S0bYjftkY8wX6J8Kaj9x
2018-10-20 00:07:18.597 (Prise multiple Tuya) 79 63 6a 5a 51 3d 3d 00 00 00 00 00 00 aa 55 .. .. .. .. .. ycjZQ==......�U
2018-10-20 00:07:18.597 (Prise multiple Tuya) Processing 'WriteDirective' message
2018-10-20 00:07:18.597 (Prise multiple Tuya) Sending 86 bytes of data
2018-10-20 00:07:18.597 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 64 65 ..U�...........F{"de
2018-10-20 00:07:18.597 (Prise multiple Tuya) 76 49 64 22 3a 22 38 35 35 30 32 33 35 34 38 30 37 64 33 61 vId":"85502354807d3a
2018-10-20 00:07:18.597 (Prise multiple Tuya) 35 30 62 38 65 65 22 2c 22 67 77 49 64 22 3a 22 38 35 35 30 50b8ee","gwId":"8550
2018-10-20 00:07:18.597 (Prise multiple Tuya) 32 33 35 34 38 30 37 64 33 61 35 30 62 38 65 65 22 7d 00 00 2354807d3a50b8ee"}..
2018-10-20 00:07:18.597 (Prise multiple Tuya) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2018-10-20 00:07:18.603 (Prise multiple Tuya) Pushing 'ReadEvent' on to queue
2018-10-20 00:07:18.605 (Prise multiple Tuya) Pushing 'ReadEvent' on to queue
2018-10-20 00:07:18.414 Status: User: Admin initiated a switch command (3401/Prise multiple Tuya - Tuya SmartPlug #2/Off)
2018-10-20 00:07:19.020 (Prise multiple Tuya) Processing 'onHeartbeatCallback' message
2018-10-20 00:07:19.020 (Prise multiple Tuya) Calling message handler 'onHeartbeat'.
2018-10-20 00:07:19.021 (Prise multiple Tuya) Pushing 'WriteDirective' on to queue
2018-10-20 00:07:19.021 (Prise multiple Tuya) Processing 'WriteDirective' message
2018-10-20 00:07:19.021 (Prise multiple Tuya) Sending 86 bytes of data
2018-10-20 00:07:19.021 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 64 65 ..U�...........F{"de
2018-10-20 00:07:19.021 (Prise multiple Tuya) 76 49 64 22 3a 22 38 35 35 30 32 33 35 34 38 30 37 64 33 61 vId":"85502354807d3a
2018-10-20 00:07:19.021 (Prise multiple Tuya) 35 30 62 38 65 65 22 2c 22 67 77 49 64 22 3a 22 38 35 35 30 50b8ee","gwId":"8550
2018-10-20 00:07:19.021 (Prise multiple Tuya) 32 33 35 34 38 30 37 64 33 61 35 30 62 38 65 65 22 7d 00 00 2354807d3a50b8ee"}..
2018-10-20 00:07:19.021 (Prise multiple Tuya) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2018-10-20 00:07:19.165 (Prise multiple Tuya) Pushing 'ReadEvent' on to queue
2018-10-20 00:07:19.172 (Prise multiple Tuya) Processing 'ReadEvent' message
2018-10-20 00:07:19.172 (Prise multiple Tuya) Received 108 bytes of data
2018-10-20 00:07:19.172 (Prise multiple Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 5c 00 00 00 00 ..U�...........\....
2018-10-20 00:07:19.172 (Prise multiple Tuya) 7b 22 64 65 76 49 64 22 3a 22 38 35 35 30 32 33 35 34 38 30 {"devId":"8550235480
2018-10-20 00:07:19.172 (Prise multiple Tuya) 37 64 33 61 35 30 62 38 65 65 22 2c 22 64 70 73 22 3a 7b 22 7d3a50b8ee","dps":{"
2018-10-20 00:07:19.172 (Prise multiple Tuya) 31 22 3a 66 61 6c 73 65 2c 22 32 22 3a 66 61 6c 73 65 2c 22 1":false,"2":false,"
2018-10-20 00:07:19.172 (Prise multiple Tuya) 33 22 3a 66 61 6c 73 65 2c 22 37 22 3a 66 61 6c 73 65 7d 7d 3":false,"7":false}}
2018-10-20 00:07:19.172 (Prise multiple Tuya) fc b2 c4 2f 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. ���/..�U
2018-10-20 00:07:19.172 (Prise multiple Tuya) Pushing 'onMessageCallback' on to queue
2018-10-20 00:07:19.172 (Prise multiple Tuya) Processing 'onMessageCallback' message
2018-10-20 00:07:19.172 (Prise multiple Tuya) Calling message handler 'onMessage'.
2018-10-20 00:07:19.173 (Prise multiple Tuya) onMessage called: 192.168.2.215:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\\\x00\x00\x00\x00{"devId":"85502354807d3a50b8ee","dps":{"1":false,"2":false,"3":false,"7":false}}\xfc\xb2\xc4/\x00\x00\xaaU'
For this case:
Do you observe physically that plug 1 was on and then off because the information received from the plug indicates that plug 1 was always off.
Just in case, can you delete the hardware, the plugin and perform a fresh install again to be sure that the bug is still there.
It may come from the update between the first test and the current version
I may got it, give me few minutes for a new version
fresh install made, no change.
I do no understand your first question (my english is not good enough...)
mechanically I can observ that there is a very quick sequence beginning by the order asked and THEN the socket 1 follows the status of the other socket.
I put a new version on github. I hope it will fix it without introducing bugs...
You are a Master !!
It's ok now , thanks a lot and how quick you did made it !!!
Thanks but it is just a quick version that needs to be clean and hard coded part have to be removed.
You may also find some other bugs, with more intensive test.
I will let you know when a cleaner version will be available but not now i need some rest.
I hope you will be available to test it.
Do you think a turn all on/off is needed? I am not convince because I suspect a lot of different cases depending on the plugs...
