Ronker
Domoticz version: 4.9700
Re: machinon theme
Post by Ronker »
vamp wrote: Saturday 06 October 2018 13:26 Hi there,
I installed the latest beta but i can not found the new icons...
And the left top Domoticz icon is a bit ugly... :) your screenshots the theme is look mutch better! How to do the same result?
OK the browser flush cache is helped :)
But found a another bug:
the "last seen" line is missing.
Ehh i found it in theme settings... :D No more problem...
I have cleared the cache but still get the domoticz icon instead. Had to replace the image folder
EdddieN
Re: machinon theme
Post by EdddieN »
updated to zeplin a darker blue bar plus also added a notification icon. The icon only appears when something (yet to be decided) needs to be decided by the system, like an unplanned reboot, etc..
11101101 - www.machinon.com
EdddieN
Re: machinon theme
Post by EdddieN »
Here is a thought, I just saw this post: http://www.domoticz.com/forum/viewtopic ... 68#p193764 which notifes via dzVents about a reboot or similar. Would be nice if these could be tied up on a 'Domoticz notification center' where things like reboots, warning about file systems (or even temperature), basically anything that is related to the operation of Domoticz and the RPI (or whatever hardware).
I have something similar in my NAS and I found it quite useful.
EdwinK
Re: machinon theme
Post by EdwinK »
Looking a bit strange, but with a refresh it's fixed.
EdddieN
Re: machinon theme
Post by EdddieN »
EdwinK wrote:Looking a bit strange, but with a refresh it's fixed.
That sounds like cache and app cache. Are you still seeing the screen like that?
EdwinK
Re: machinon theme
Post by EdwinK »
Only when I return to it after some time, refreshing fixes it. I;m going to clear the appcache when I'm ready for today
remb0
Re: machinon theme
Post by remb0 »
when does the beta pushed to the master?
I see some nice commits ;)
EdddieN
Re: machinon theme
Post by EdddieN »
I use beta and it is pretty stable (for now), however there're a couple of issues with some browsers regarding tiles flex, @landaisbenj working hard to recode that part.
@landaisbenj and @DewGew had forked beta into further two branches (alphas?). I hope we could reach a stable milestone release soon as there're many new features planned, but best to close property stage 1.
I also like to say that without @landaisbenj and @DewGew involvement on this theme, this would not be possible - BIG thank you!
To check beta:
cd domoticz/www/styles
git clone https://github.com/EdddieN/machinon-domoticz_theme.git machinon-beta
cd machinon-beta
git checkout beta
heggink
Domoticz version: 12451
Re: machinon theme
Post by heggink »
I use the beta and an very happy with it. Wish I had the time to contribute...
P1 meter & solar panel
landaisbenj
Domoticz version: stable
Re: machinon theme
Post by landaisbenj »
heggink wrote: Friday 12 October 2018 17:35 I use the beta and an very happy with it. Wish I had the time to contribute...
Wish i had More Time to contribute too :(
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
EastXIII
Re: machinon theme
Post by EastXIII »
Very, very nice theme! Thank you for that!
Because i'm busy building my custom Dashticz V2 dash I found that I'm searching for the IDX numbers quite often. They can be found in "Devices" obviously, but the Aurora theme has the great advantage, at least for me, that the IDX is visible in the block itself.
Not within the favorits section of Domoticz, but in the specific tabs it is.
Is this something that could be implemented in this beauty? Off course only when I'm not the only one seeing this advantage.
landaisbenj
Re: machinon theme
EastXIII wrote: Friday 12 October 2018 21:07 Very, very nice theme! Thank you for that!
Yes i had think about this.. We must to open an issue to add this on our todo.
Platforme: Rpbi3b
poudenes
Domoticz version: 3.8993
Re: machinon theme
Post by poudenes »
That is a good idea. I'll like it!
EdwinK
Re: machinon theme
Post by EdwinK »
EdwinK wrote: Tuesday 09 October 2018 20:18 Only when I return to it after some time, refreshing fixes it. I;m going to clear the appcache when I'm ready for today
And nw, suddenly it works like it should.
heggink
Re: machinon theme
Post by heggink »
It's a shame that so much in domoticz is dependent on the idx. One reason I really like dzvents. Replacing a device is a no maintenance event. Idx' really should be an internal thing.
poudenes
Re: machinon theme
Post by poudenes »
heggink wrote: Saturday 13 October 2018 9:17 It's a shame that so much in domoticz is dependent on the idx. One reason I really like dzvents. Replacing a device is a no maintenance event. Idx' really should be an internal thing.
I have a global_data and give any IDX a name. When a device change and also IDX i only have to change it on the global_data and all my dzvents script are working normal without changing anything
heggink
Re: machinon theme
Post by heggink »
I know but that doesn't work for things like dashticz and you still need to maintain global data. My point was more generic in a sense that the idx should have been an internal thing. Even blockly works with idx so if you swap a device, you need to update it...
EdddieN
Re: machinon theme
Post by EdddieN »
Anyone that could help us make this happen?
https://github.com/EdddieN/machinon-dom ... issues/138
vamp
Re: machinon theme
Post by vamp »
I use the latest beta, i think the font size is too big (or box sizes is too small)
EdddieN
Re: machinon theme
Post by EdddieN »
Layout still been worked on, a lot of changes in the last few days. Hopefully we'll get to the visuals soon
