Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
- remb0
Magdimi: I have both alexa and google home.
but because the home is dutch now I want to use Dutch.
my devices have dutch names and in the description I use the command to give it an englisch name for Alexa.
would it be posible that alexa uses my englisch description and google uses the normal names?
Madgeni
Both alexa and google should respond to either the device name (whatever it's called in Domoticz) AND any 'friendlyname' - so whatever you use in the Domoticz Description field.
That way you can use either name in either alexa/google
competer
Hello, need some help connecting Domoticz an Controlicz
When doing a connection test on Controlicz i get a ceck port notification
When going to the ssl url from mydomoticz.com i get a Domoticz offline error
What can i do to reslove this
there are 10 types of people in this world, those who understand binary and those who dont
Madgeni
hi competer - mail me from your Controlicz profile, and i'll take a look.
- gijsje
- Domoticz version: Stable
I have now side loaded the new home app as it was not available on my phone yet
It looks rely nice and easy.
Now i can also see that all temp sensors are shown as a "thermostat", does google not support separate temp sensors?
And i can not yet control the thermostat from the new app it shows the ambient temp but this is actually the set point.
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
erlie
How can i arrange that?Madgeni wrote: Thursday 11 October 2018 15:34 hi erlie - in order to link to Google, you'll need to subscribe from your profile
Madgeni
From your Controlicz profile, there is a billing page
djac
I am unexperienced with Google Home and that may be the issue here, but..
Signed up for Controlicz, can see the devices, paid, linked service in my Google home app om phone, Accounts Linked, -success.
Now what?
I have tried to ask google to do something but only excuses
what's the syntax to do something?
Now what?
Domoticz on Rpi, Z-wave, Hue with Philips and Ikea bulbs
Madgeni
"Sync my devices" - discover devices
"Hey google, turn off <device>"
"Hey google, are the lights on in the <room>"
"Hey google, set the <thermostat> to x"
"Hey google, what's the temperature in the <room>/ of the <thermostat>"
"Hey google, dim the lights"
"Hey google, change the lights to <colour>"
Stuff like that. You can also use Google Assistant and type them
djac
Thanks, I think this is where it goes wrong, asking to sync the devices gives "An error occured while synching My test app", any ideas?Madgeni wrote: Friday 12 October 2018 13:47 "Sync my devices" - discover devices
djac
I get Accounts are linked, but at the same time I get a message in the Google app, at the bottom, that Something went wrong?djac wrote: Friday 12 October 2018 15:04Thanks, I think this is where it goes wrong, asking to sync the devices gives "An error occured while synching My test app", any ideas?Madgeni wrote: Friday 12 October 2018 13:47 "Sync my devices" - discover devices
Madgeni
Hi - do you have a subscription?
djac
Yes, I do!
Madgeni
Oh no - can you mail me from your Controlicz profile and i'll take a look right now
- heggink
- Domoticz version: 12451
Right, so finally Dutch language on my home mini through some form of magical apparition. Nothing really worked so removed and reattached. What's weird is that in can ask Google to turn all lights on and off but not individual rooms and not individual lights. It recognises no lights by name. Maybe because I renamed all of them in the home app from English to Dutch. Will retry with the controlicz name in the description field. Bizarre. All worked fine in English .
P1 meter & solar panel
Madgeni
Several people seem to have issues so far with Dutch - scenes not being discovered is another. I'm hoping it's teething troubles, but have raised with Google Product owner
- heggink
I noticed the scenes/groups thing. Bizarre that a language has any influence over how devices are treated...Madgeni wrote:Several people seem to have issues so far with Dutch - scenes not being discovered is another. I'm hoping it's teething troubles, but have raised with Google Product owner
Madgeni
It's discovering and returning them to Google, Google is just..ignoring them
- heggink
Probably because they are too busy meddling with stuff they should really ignore
wardc
I have the same problem. Also noticed that RGB(W) are not recognized as such. They show as regular dimmable lights.gijsje wrote: Thursday 11 October 2018 23:42 Now i can also see that all temp sensors are shown as a "thermostat", does google not support separate temp sensors?
It's very annoying that scenes aren't showing in the app as I do almost everything in domoticz using scenes. What is strange is that they don't show in the home apps, but through the assistant app I was able to add the scenes to rooms. Haven't seen them anywhere since. I used this link to link the controlicz app to the Google assistant:https://assistant.google.com/services/a ... 8ba2?hl=nl
By first linking and then changing the settings (instellen) I was able to view the scenes. So Google probably knows about them but is ignoring them on purpose.
