Stella z thermostat mode cannot be set
I have an Stella z thermostat, when I try to set the thermostat mode to a diferent setting (default is Comfort) nothing happens, also after the connection time the mode still says "comfort", is this a bug or is there something I have to set to make this work properly?
Re: Stella z thermostat mode cannot be set
I've got the same issue. Did you happen to get this resolved?Blueone wrote: ↑Tuesday 03 January 2017 21:54 I have an Stella z thermostat, when I try to set the thermostat mode to a diferent setting (default is Comfort) nothing happens, also after the connection time the mode still says "comfort", is this a bug or is there something I have to set to make this work properly?
