Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Re: Controlicz - Easy Domoticz to Alexa Integration
Yes, it is an issue with the response, but I thought I'd fixed it, so was just checking will take another look
Yes, now all is fixed!
You are the best!
You are the best!
Yay! Glad it's working
- Domoticz version: 3.8153
please Milight RGB CCT special with CW and WW...
thanks
thanks
Apologies, will plug the bulb in tomorrow and get debugging!
Still have a probleem with Milight (ibox 2) GU10 RGBCCT ....
changing color works good but changing from warmwhite to coolwhite not ..
since few days (don't know how many) the command of my blinds are inverted if I use "routines" in alexa parameters.
If I tell to Alexa to open my blinds then she close it and if I tell her to close it then she open it.
Before all works fine and I never have any problem with that.
Another thing, I can't create a routine with only a ON command, if I crate a ON command then in Domoticz it's a "Set level" command that is received and so my blind don't work.
Any idea ?
Any idea ?
Reverting back to Controlicz after a while, just to notice that donating 20 euros six months ago ended up into subscription based service! You gotta be kidding me.
The early volunteers donating have enabled you to develop the service, and now we should be subscribing as everybody else. Sounds fair - not.
Most donators were refunded or the donations were converted to subscriptions, as I've posted it wasn't/isn't my intention to con people. Mail me from your Controlicz profile, and I'll help
the milight still not working as befor ..?
can you look at it please
Apologies, bought the wrong bulb, bayonet version on it's way - will fix it this week
Okey thanks
It's gu10 RGBCCT with ibox2
Hi hayman - try now?
With Alexa not working with Google home it's works but some times get freezing at warm white???
any update onthe milight
Solved, refunded and subscribed. Great work Nick!
Hi all - made an update to your profiles, so devices will show whether they are in a Room Plan or not. Thats should help with ensuring you're sending all the devices you want to send, and no more
Thanks still the milight cctrgb not working:(
What? So you can't change to blue/green with milight? sorry, honestly thought i'd fixed it
