Migrating from zWave to KNX
emme
Domoticz version: latest
Post by emme »
Ciao,
I'm in the process to start the migration at my home from zWave to KNX (gess my wife what could think about it.... :roll: ).
zWave will still be there (for Danofss LC13 thermostat valve and other battery sensors like Pirs, reeed and other)
Domotics will be performed by KNX, but Domoticz will still have a major role in managing the house and scripting
Since there is no an hardware connecto between Domoticz and zWave my intention was to make all working toghether with mqtt/node-red
The migration will be extremely slow (KNX is NOT cheap.... really!!!) so I would like to have your opinion and experience about...
btw.... I will have tons of wired zwave devices to sell!!! :D :D
ciao
M
"We always done this way"
EdddieN
Domoticz version: 4.9700
Re: Migrating from zWave to KNX
Post by EdddieN »
Interested in this. I did go through something similar a while back (zigbee to z-wave), as my zigbee network got smaller I started to struggle with connectivity. I guess you may end up with the same but z-wave.
Why are you leaving z-wave in exchange of KNX? What about Insteon? Have you heard about monoprice?
Genuinely interested in your progress. I have similar thoughts but really looking for an economic mainstay signal that can do wireless too. Insteon seems nice but there is no much Domoticz experience there, besides I think is very US
11101101 - www.machinon.com
ben53252642
Post by ben53252642 »
EdddieN, I've been decommissioning Z-Wave devices in my home and replacing them with Zigbee (mostly Xiaomi, Philip Hue etc..) using Zigbee2MQTT and Node-Red.
I can't understand why you would want to go from Zigbee to Z-Wave? What was the reasoning, are you happier with the Z-Wave system?
My experience is the complete opposite.
emme
Post by emme »
I recently got the KNX certification and since I do not work with KNX on a daily basis, my home would be my natural playground.
more... I would like to lower consumption (I have almost 50 devices that uses 1w each... that's not much, that's not so little)
zwave is a good protocol, but it's a wireless... it means that it will work fine until the 868Mhz band is not full....
I'm starting to have issues on some nodes and I think it is for strong interferences
And most of all... I assume that KNX will rise my home value (maybe in case we will need to move :P :P)
...the real reason is: I know how to do it, and I want to do it :P :P :P
EdddieN
Post by EdddieN »
With ZigBee I had to have some gateways which is a bit of a pain. I prefer to have one gateway and that is it.
I found z-wave very stable, including my messiness... :D
I think wireless networks will always have challenges when selling a home. Who owns and manages it? Wired would be future proof but we cannot ignore popular wireless networks.
I don’t have any experience with KNX but I’m starting to hear it on BMS system on top of the ever popular BacNet.
Don’t think Domoticz supports BacNet yet, does KNX or Insteon?
ben53252642
EdddieN wrote: Monday 24 September 2018 12:59 With ZigBee I had to have some gateways which is a bit of a pain.
That used to be the case before Zigbee2MQTT and some other projects,
I've recently moved all my Xiaomi and Philip Hue devices onto Zigbee2MQTT (and subsequently removed the Xiaomi and Hue hubs).
I think Zigbee2MQTT could become the OpenZWave equivalent for Zigbee, it's very exciting. :mrgreen:
https://github.com/Koenkk/zigbee2mqtt/w ... ed-devices
EdddieN
Post by EdddieN »
Very interesting! Basically as you say, alpha of z-wave.
Is there anything KNX equivalent you found?
EdddieN
Post by EdddieN »
Just looked a bit more into KNX, devices are not cheap!
https://knxshoponline.co.uk/content/Zen ... v1.1_a.pdf do I assume you still need to run a BUS cable to it?
emme
Post by emme »
yes, KNX is NOT cheap, and yes, you need a TP bus cable (2 wires rs485) and more... you need a 1k€ licensed software :(
ben53252642
emme wrote: Wednesday 26 September 2018 17:13 you need a 1k€ licensed software :(
For that I could buy 96 Xiaomi Motion Sensors... wow!
EdddieN
Post by EdddieN »
emme wrote:yes, KNX is NOT cheap, and yes, you need a TP bus cable (2 wires rs485) and more... you need a 1k€ licensed software :(
Ouch! Still interested on the wired option. Insteon sounded good but for whatever reason is not popular here. X10 feels really old.... any other alternative?
emme
Post by emme »
think about other certified wired domotic solution. in Italy the most distributed are myHome (legrand/bTicino), byMe (Vimar), but also Gewiss has its own domotic protocol
They are cheaper than KNX but I don0t know the "open" opportunities of those protocols, even if I'm quite sure here in the forum there are few users that have myHome (openWebNet) domotic linked to Domoticz
There is also a safety certification needed in Italy for the electric system: any diy solution is not safe by a law point of view
Even if zWave is a certified protocol, I would like to create a safer environent.
but, as I told on the first post... due to costs.. it will take a LOOOOOOONG time to complete :P
EdddieN
Post by EdddieN »
Have you come across a combined circuit breaker and relay/contactor?
Looking to upgrade a few things.
Also found Z-Lynk via powerline but seems very proprietary for energy networks. Wonder if there’s a similar one for more domestic use...
