[SOLVED] Set variable for setRGB()
stewdyne
Post by stewdyne »
Is it possible to set a variable in setRGB () with Dzvents? I mean something like that:
setRGB (variableRed, variableGreen, variableBlue) or something like: setRGB (variableRGBhere)
Inso80
Re: Set variable for setRGB()
Post by Inso80 »
Maybe take a look at:
https://www.domoticz.com/wiki/DzVents:_ ... object_API
and scroll down to specific devices, rgb(w)
For the call in DzVents:
https://www.domoticz.com/wiki/DzVents:_ ... terface.29
should be something like
domoticz.devices('deviceName').setRGB(red, green, blue)
stewdyne
Post by stewdyne »
Thank you for your reply.
I know how setRGB works, but that is not what I mean. I want to store a variable (like: 0,250,0) and set that in setRGB().
setRGB('Variable_here'')
output:
setRGB(0,250,0)
poudenes
Domoticz version: 3.8993
Post by poudenes »
What i did for colors is this:
Create a "global_data" dzVents file. The Even name is global_data
-- RGB          (domoticz,idx,dim,color,sec)    (domoticz,idx,100,'white',0)
local COLORS = {
                ['White']       = {255,225,255},
                ['Red']         = {255,0,1},
                ['Blue']        = {12,0,179},
                ['Green']       = {150,255,142},
                ['Romantic']    = {128,0,0}
    helpers = {
        RGB = function(domoticz,idx,dim,color,sec)
            if (dim == nil)     then dim = 100 end
        	if (color == nil)   then rgb = COLORS['White']  else rgb = COLORS[color] end
            if (sec == nil)     then sec = 0 end
            domoticz.devices(idx).setRGB(rgb[1], rgb[2], rgb[3]).afterSec(sec)
            domoticz.devices(idx).dimTo(dim).afterSec(sec)
            status = 'aangezet'
Then in your dzVents scripts you can do this:
domoticz.helpers.RGB(domoticz,BulbLivingroomAll,nil,'Green',nil)
domoticz.helpers.RGB(domoticz,BulbLivingroomAll,nil,'Blue',nil)
domoticz.helpers.RGB(domoticz,BulbLivingroomAll,nil,'Romantic',nil)
I add some things extra like dim option, and seconds. So you can have 1 line and add dim, RGB, aftersec
Last edited by poudenes on Tuesday 18 September 2018 14:52, edited 1 time in total.
Inso80
Post by Inso80 »
stewdyne wrote: Tuesday 18 September 2018 14:32 Thank you for your reply.
output:
setRGB(0,250,0)
Ah, sorry^^
you mean:
a = 50;
b = 50;
c = 50;
domoticz.devices('testrgb').setRGB(a, b, c)
Just tested within
, works.
Should also work if you use persistent / global variables
https://www.domoticz.com/wiki/DzVents:_ ... stent_data
@poudenes: that is indeed a nice way to handle it :)
stewdyne
Post by stewdyne »
Inso80 wrote: Tuesday 18 September 2018 14:52
output:
setRGB(0,250,0)
Ah, sorry^^
you mean:
a = 50;
b = 50;
c = 50;
Just tested within
, works.
Indeed, that is what I want. This is what I tried:
living.setRGB(dz.globalData.rgbRed, dz.globalData.rgbGreen, dz.globalData.rgbBlue)
No luck there. The lights just turn white.
In global data I have:
       helpers = {},
       data = {
            rgbRed = { initial = 0 },
            rgbGreen = { initial = 250 },
            rgbBlue = { initial = 0 }
@poudenes: Looks interesting! I'll look in your code this weekend. I'm not (yet) familair with Helpers.
stewdyne wrote: Wednesday 19 September 2018 7:59 ..This is what I tried:
       helpers = {},
       data = {
can you display the values by putting something like ?
dz.log(dz.globalData.rgbGreen)
in your code ? And it might help us to help you if you could show the complete script.
stewdyne
Post by stewdyne »
Ok, I've found the problem.
Had this in my global_data:
       helpers = {},
       data = {
            brightnessLiving = { initial = 100 },
            brightnessHallwayOne = { initial = 100 },
            brightnessHallwayTwo = { initial = 100 },
            brightnessToilet = { initial = 100 },
            brightnessKitchen = { initial = 100 },
            brightnessBedroom = { initial = 100 },
            colorTemperature = { initial = 100 },
            rgbRed = { initial = 50 },
            rgbBlue = { initial = 80 }
Executed this script:
		devices = {
			'Test_switch'
	execute = function(dz, switch)
        if (dz.devices('Test_switch').state == 'On') then
            dz.devices('Lampen_Woon_1').setRGB(dz.globalData.rgbRed, dz.globalData.rgbGreen, dz.globalData.rgbBlue)
The code above set the light to full white and printed 255 in log. But I have initial 250 in global data. So I tried this:
		devices = {
			'Test_switch'
            dz.globalData.rgbRed = 20
            dz.globalData.rgbGreen = 20
            dz.globalData.rgbBlue = 250
And that gave me the right color. Conclusion: my global data initial value aint working :) What is wrong with it?
stewdyne wrote: Thursday 20 September 2018 19:31 Ok, I've found the problem.
Can you confirm that nothing else can modify global data ? No internal or external dzVents script ?
I copied your script and global data and add
dz.log("Green: ".. dz.globalData.rgbGreen .. " - Red: " .. dz.globalData.rgbRed .. " - Blue: " .. dz.globalData.rgbBlue,dz.LOG_FORCE)
Before and after the setRGB line.
My result is that the RGB device changed to the requested color and the log showed:
2018-09-20 20:10:38.499  Status: dzVents: !Info: Green: 250 - Red: 50 - Blue: 80
2018-09-20 20:10:38.501  Status: dzVents: !Info: Green: 250 - Red: 50 - Blue: 80
Can you also look what the content of the file <domoticz_dir>/scripts/dzVents/data/__data_global_data.lua is ?
stewdyne
Post by stewdyne »
Hi Waaren,
I checked my scripts and indeed the values were changed at start. Everything is working fine now, thank you!
1 more question. By setting the rgb you also automaticly change the brightness of the lights. Is it possible to only change the color without changing the brightness? And how?
poudenes
Post by poudenes »
stewdyne wrote:Hi Waaren,
What I always do is goto Google search for "color picker" then you get a tool to select color and left you see rgb value.
Verzonden vanaf mijn iPhone met Tapatalk Pro
stewdyne wrote: Saturday 22 September 2018 0:03 ...By setting the rgb you also automaticly change the brightness of the lights. Is it possible to only change the color without changing the brightness? And how?
hi @stewdyne,
If my understanding of dzVents current device-adapter for RGBW devices is correct, it is not yet possible to do this with native dzVents commands. @dannybloe can give you a definitive answer on that.
If you look at https://www.domoticz.com/wiki/Domoticz_API/JSON_URL's and scroll to "Specify Domoticz JSON color object and brightness" you will see the json example:
/json.htm?type=command&param=setcolbrightnessvalue&idx=130&color={"m":3,"t":0,"r":0,"g":0,"b":50,"cw":0,"ww":0}&brightness=100
and with that information you can use the openURL command like:
domoticz.openURL({
                	url = domoticz.settings['Domoticz url'] .. "/json.htm?type=command&param=setcolbrightnessvalue&idx=130&color={"m":3,"t":0,"r":0,"g":0,"b":50,"cw":0,"ww":0}&brightness=100",
                	method = "GET",
To get to the result you want.
stewdyne
Post by stewdyne »
Thank you for your help! This topic can be set on solved.
stewdyne wrote: Monday 24 September 2018 6:59 Thank you for your help! This topic can be set on solved.
Good to hear ! You must set this topic to solved yourself (as you are the topic starter)
Inso80
Post by Inso80 »
stewdyne wrote: Saturday 22 September 2018 0:03 Hi Waaren,
On some lights you can set HSV instead of RGB when sending the command directly. Has some pros and cons, one pro is changing the color does not affect the brightnes. Con to change back to RGB for me was HSV is not as precisious for color set of the single colors as RGB is.
HSV is f.e. available for Yeelights, WS2812b, Hue..
stewdyne
Re: [SOLVED] Set variable for setRGB()
Post by stewdyne »
Ow wow! Thank you. Should have known this earlier. Now I've created a workaround that puts some load on my rpi. Will check this out tonight.
Users browsing this forum: habahabahaba and 1 guest
