installation problem
JonMiles
Post by JonMiles »
I have installed Domoticz onto a raspberry pi, and installation has completed correctly ie, it gives me the installation complete and the addresses.
I then go to the website and on any pc, I try, I get, even if I try to access it locally, i get unable to connect.:
Unable to connect
Firefox can’t establish a connection to the server at 192.168.1.109:789.
Am i missing something?
Many thanks
SweetPants
Re: installation problem
Post by SweetPants »
Are you sure domoticz is running on port 789? Did you try the default of 8080 already? If I remember correctly you need special permissions to run on ports below 1024.
Have you tried starting domoticz manually:
cd ~/domoticz
./domoticz -www 8080
Then connect to port 8080
JonMiles
Post by JonMiles »
many thanks for the reply.
I already have something using port 8080 so I need to use a different port. i have tried a higher port, but again no luck.
