HUE/JSON Color
Lachris
HUE/JSON Color
Post by Lachris »
Im very new to all this Domoticz, Im looking for getting a HUE bulb showing a specific color in dzVents
From the domoticz Log i get a setcolbrightnessvalue, when I set the color I want under Switches:
Status: setcolbrightnessvalue: ID: 1de, bri: 100, color: '{m: 2, RGB: 000000, CWWW: 6b94, CT: 148}'
I found this under:
API/JSONURL
Specify Domoticz JSON color object and brightness
Example: Specify color mode with a dim blue color
/json.htm?type=command&param=setcolbrightnessvalue&idx=130&color={"m":3,"t":0,"r":0,"g":0,"b":50,"cw":0,"ww":0}&brightness=100
SO:
m should be set to: 2
r+g+b: 0?
How to replicate that color?
Re: HUE/JSON Color
Lachris wrote: Saturday 08 September 2018 7:26 ..
I am looking for getting a HUE bulb showing a specific color in dzVents
What about according to the dzVents wiki ?
light = domoticz.devices("your RGBW devicename")
light.setRGB( red, green, blue )
Lachris
Re: HUE/JSON Color
Post by Lachris »
But is it possible to make the setcolbrightnessvalue as I wrote with RGB?
I guess it only works with color and not white ambiance??
Re: HUE/JSON Color
I am not 100% sure but I don't think this is already implemented as a native dzVents method for the RGBWW devices. @dannybloe ?
If not yet implemented, you can use this.
    on         = { devices     = { "triggerDevice" }},
    logging    = { level       =   domoticz.LOG_DEBUG,
                   marker      =   "setcolbrightnessvalue" },
    execute = function(dz)
       local colorTable     = {}               -- define and populate the colorTable
       colorTable.m         = 2                -- ColorMode         [0 .. 4]
       colorTable.t         = 0                -- Color temperature [0 .. 255]
       colorTable.r         = 0                -- red level         [0 .. 255]
       colorTable.g         = 0                -- greenlevel        [0 .. 255]
       colorTable.b         = 0                -- blue level        [0 .. 255]
       colorTable.cw        = 0                -- Cold white level  [0 .. 255]
       colorTable.ww        = 0                -- Warm white level  [0 .. 255]
       local brightness     = 97               -- Brightness        [0 .. 100]
       local deviceIDX      = 157              -- your RGBWW device IDX
       local colorString    = "{"              -- transform table contents into formatted string
       for k,v in pairs(colorTable) do
            colorString = colorString .. '"' .. k .. '":' .. v .. ","
       colorString = colorString:sub(1, -2) .. "}"  -- Remove last , and add }
       local url            = dz.settings["Domoticz url"] ..      -- prepare url
                              "/json.htm?type=command&param=setcolbrightnessvalue&idx=" .. deviceIDX ..
                              "&color=" .. colorString ..
                              "&brightness=" .. brightness
       dz.log("colorTable: ".. colorString,dz.LOG_DEBUG)
       dz.openURL(url)
