Help is very welcome!! I'll drop you a PM and I can give you access to Zeplin where the source design files are there. You should be able to pick up anything too.heggink wrote: Tuesday 04 September 2018 20:34 Hey DewGew and EdddieN, quick request:
I really like the theme but I have a bunch of custom icons that I would love to see in this theme:
- male and female head (for presence devices)
- bluetooth icon
- apple icon
- life360 icon
- doorbell icon
- Nest thermostat icons
- webcam icon
- IOT/ESP icon
- server icon (freenas NAS ping status, multiple raspberry Pi's)
- solar radiation
- UV index
- thermostat icon (still red flame)
- gas meter icon
- ozone icon for weather forecast
- battery level icon for the battery level python plugin
- Rain icons (rain rate, buienradar python plugin)
These are the non blue-ish non machinon icons I managed to find. Are you working on these? Happy to help create but I have no clue as to the colour schemes and templates...
H
- EdddieN
- Domoticz version: 4.9700
Re: machinon theme - (work in progress)
11101101 - www.machinon.com
- EdddieN
I should also mention that there's loads of icons unsorted here:
https://github.com/EdddieN/machinon-dom ... norganised
Eventually we will use them all
Prutsium
@EddieN
Not related to your theme but did someone had the same idea for hardware (or ripped yours) : https://www.pixtend.de/
- EdddieN
There are loads of boards like this taking advantage of the RPI and I expect even more in the future so if anything it is me who is late to the party
To me what it is important is the simplicity and the application. I used boards like that before, even simpler ones like the PiFace and my distraction always has been that a fair bit of preparation work needs to be done before you can even focus on what you want to do.
My intention with machinon is that you get a tough hardware controller with Domoticz fully integrated. Switch ON, read the IP from the display and that is it! All is there ready to play, no configuration, no timers, the closest to a commercial proposition.
If you get tired or Domoticz or need something else... is a RPI so you can load anything.
I haven’t tried that model but the ones I tried before it was a real pain to make it work with Domoticz or any other software that was not the one they supplied. My vision is an open system where the owner really owns their home and privacy. I think Domoticz community is a good example where privacy comes first.
Thanks for sharing! It is always good to see products like this, as my motivation is not financial.
poudenes
- Domoticz version: 3.8993
Hi All,
Updated to latest version and looks so nice !!! Also the settings icons look great.
I have 2 devices thats not fully correct.
Text that is to long will "fall off: and Kodi part is not real issue, just cosmetic thing.
- EdddieN
Try the latest update, it has been a small fix for the text but not sure if it covers what you show there.
Re Kodi icon, have you tried clearing app cache?
poudenes
Updated to bbd765f..c2056b9
Always clear cache before i check the new update
there is no difference with this update
- EdddieN
Are you ok to submit an issue in GitHub if it hasn’t been mentioned before?
poudenes
- DewGew
- Domoticz version: V4.10618
Are you using chrome?poudenes wrote: Sunday 09 September 2018 20:27 Edit:
There is a issue already: https://github.com/EdddieN/machinon-dom ... /issues/30
poudenes
Yes i do, but also in Safari i have same problems
Hobbybob
I also have some problems with the blocks on the individual pages. On the Dashboard, eerything is OK, but when I go to Switches for example, I get blocks like these:
I'm using Firefox. In Chrome everything is OK though...
Holland
- Domoticz version: Beta Ch
@Hobbybob
I had the same problem with Firefox, but this is now resolved.
1. You are running an older version of Machinon. So do a; git pull
2. Empty your cache multiple times, until the cache of the domoticz site is close to 0 kb.
poudenes
updated this morning. Seems better. Only thing is the text thats go outside the div container
Hobbybob
Okay, just a small question: how do I do that? I'm quite new to Github, and managed to install it with instructions from Eddie, but I actually have no idea how to update... Cleaning cache I can manageHolland wrote: Tuesday 11 September 2018 10:19 @Hobbybob
poudenes
Goto the machinon folder
then give this command:
cd /home/pi/domoticz/www/styles/machinon/Code: Select all
git pullHobbybob wrote: Tuesday 11 September 2018 19:16 Okay, just a small question: how do I do that? I'm quite new to Github, and managed to install it with instructions from Eddie, but I actually have no idea how to update... Cleaning cache I can manage![]()
poudenes
Updated now to last version. Big text blocks now nicely inside the div container. Maybe option to scroll it automatic? (just a fancy thing, not a must have)
Hobbybob
hmmm... not entirely succesfull:poudenes wrote: Tuesday 11 September 2018 19:25 Goto the machinon folder
then give this command:Code: Select all
git pull
pi@raspberrypi:~/domoticz/www/styles/machinon-domoticz_theme-master $ git pull
fatal: Not a git repository (or any of the parent directories): .git
SweetPants
@Hobbybob, How did you initially install it, via zip or using git clone?
Hobbybob
I got these directions from Eddie in this post:SweetPants wrote: Tuesday 11 September 2018 20:16 @Hobbybob, How did you initially install it, via zip or using git clone?
1 .- Click on Clone or Donwload here: https://github.com/EdddieN/machinon-domoticz_theme
2.- Download the Zip file to you computer and copy its contents (unzip) inside the domoticz/www/styles/ folder. Make sure you copy the full machinon folder, not the files directly only.
3.- Go to domotiz/www/templates and copy the files inside the templates folder you downloaded there.
