Dashticz
remko2000
Dashticz
Post by remko2000 »
I have installed dashticz in accordance with the wiki. I see now this:
Schermafbeelding 2018-09-07 om 18.58.50.png (349.3 KiB) Viewed 1952 times
However, I do not really get further. When I adjust and save settings, they are not remembered.
I also miss my favorite switches. I thought that this standard should be present. What can be the problem here?
What is a good guide to further develop this
EdwinK
Re: Dashticz
Post by EdwinK »
Try the dashticz subforum viewforum.php?f=67
HansieNL
Re: Dashticz
Post by HansieNL »
@remko2000 :
1. Only when you have PHP running and given write permission to the CONFIG.js settings are saved.
2. If you remove the comment lines you have to add your blocks, buttons, etc, to the CONFIG.js by hand.
3. A good starting point is the Wiki https://www.domoticz.com/wiki/Dashticz_V2
Blah blah blah
