TFA wind sensor
stuiow
Domoticz version: 3.6857
TFA wind sensor
Post by stuiow »
Quick question, what units do the tfa anemometers output in, MPH/KPH/MS?
Cheers
Sent from my SM-G955F using Tapatalk
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
ds106
Re: TFA wind sensor
Post by ds106 »
Ruud v Gessel's "Cresta weather sensor protocol" describes Windspeed and Windgust as mph. As I can see RFLink passes sensor mph value as kmph to domoticz, rfxcom passes calculated kmph from sensor mph.
Regards Götz
koenkooi
Domoticz version: 3.7439
Re: TFA wind sensor
Post by koenkooi »
Domoticz seems to do something different here:
It gets '8' as data:
Schermafbeelding 2018-11-12 om 14.53.04.png (22.88 KiB) Viewed 3806 times
And displays '2.9 km/h'
Schermafbeelding 2018-11-12 om 14.53.10.png (50.42 KiB) Viewed 3806 times
The code has this:
        //Wind
        if (m_windunit == WINDUNIT_MS)
                m_windsign = "m/s";
                m_windscale = 0.1f;
        else if (m_windunit == WINDUNIT_KMH)
                m_windsign = "km/h";
                m_windscale = 0.36f;
        else if (m_windunit == WINDUNIT_MPH)
                m_windsign = "mph";
                m_windscale = 0.223693629205f;
        else if (m_windunit == WINDUNIT_Knots)
                m_windsign = "kn";
                m_windscale = 0.1943844492457398f;
        else if (m_windunit == WINDUNIT_Beaufort)
                m_windsign = "bf";
                m_windscale = 1;
Why does domoticz think the data is in decimeters/second?
Toulon7559
Domoticz version: <2025
Re: TFA wind sensor
Post by Toulon7559 »
In Domoticz speed expressed as 0.1m/s is aspect of definition.
See https://www.domoticz.com/wiki/Domoticz_ ... L%27s#Wind
Only reason I could imagine, is that then the practical transfer values can be expressed as integers.
koenkooi
Re: TFA wind sensor
Post by koenkooi »
So is the '8' in the data overview the value read from rfxcom (presumably in km/h) or the processed value? I ask because the '8' is a lot closer to the 10km/h from the local weather report than the 2.9km/h domoticz displays.
I don't have a different (calibrated) anemometer to compare against, so domoticz could be doing the right thing already.
Toulon7559
Re: TFA wind sensor
If you are using Nexus' USB-interface, that interface is according to TE923:
this documentation might apply for read-out.
Reading this documentation indirectly you can find practical info on Nexus' data protocol.
Last edited by Toulon7559 on Wednesday 28 November 2018 21:18, edited 1 time in total.
koenkooi
Re: TFA wind sensor
Post by koenkooi »
I'm using the 433MHz sensors with an rfxcom transceiver connected to domoticz.
sincze
Domoticz version: 2024.4
Re: TFA wind sensor
Post by sincze »
I noticed the difference as well and notified the stunt team on 28_7_18 unfortunately no response. But hopefully fixed in r49.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Toulon7559
Re: TFA wind sensor
@stuiow
Which interface are you applying to read the TFA_Nexus anemometer?
By accident (while looking for something completely different) I can confirm the observation by ds106 that in Domoticz it seems to make difference over which interface you read windspeed from TFA_Nexus
a) over the Console's TE923 USB-interface, or
b) wireless by RFXCom or
c) wireless by RFLinkGateway:
- the readouts a) and b) from the TE923-interface, respectively from the RFXCom usually agree
- the readout c) through the RFLinkGateway [in my case R46] shows much lower values [meanwhile this 'possible bug' reported to Stuntteam], possibly (?) a factor 1.6 due to output as mph vs. kmh
Furthermore, (similar to reported by sincze) generally the values coming from my TFA_Nexus' anemometer are lower than those coming from a co-located WS7000-anemometer (which I better trust, because better quality, although aged).
:? Just raises the question: which wind speed is true & correct?
