I have set everything up properly (and I updated both systems).
This does not seem to me to be a router issue because they both run on the same internet network (standard port 6144) . What can be the problem?
Last edited by remko2000 on Sunday 02 September 2018 11:53, edited 2 times in total.
If I read your post correctly. You have added a user to the slave Pi which is the main user name on your master Pi and on the master Pi you have used the main user name on your slave Pi.
If that is the case then it should be changed around as below. If I’ve got it wrong please ignore me.
The additional user that you have created on the slave is the user that should be refered to in the ‘remote pi’ hardware on the master.
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
alanlsmith wrote: Sunday 02 September 2018 12:47
Could it be the user
No I don't think there is the problem. I followed excactly the instruction from the wiki. I checked it again.
I had the exact same log result, my solution was to check the checkbox: "Sharing: [ ] (Enables remote sharing of devices with this user)". This is an option in the user settings of the slave...
