Avoid broken blinds / Bind stop
JonyBCN
Post by JonyBCN »
After an accident with a blind motor, an obstacle and a broken shutter as a result, I have been thinking about creating a system to avoid accidents.
Installing sensors to deceive obstacles would be expensive, intrusive and complex. But since any shutter driver incorporates consumer information, I think I can work with that.
I have 5 Fibaro FGRM-222, and electrical training, so I know the basic operation of any engine. With the FGRM-222, I can measure consumption at almost the moment, and if the blind finds an obstacle, consumption must rise due to over-exertion. I have done a couple of tests measuring the normal consumption and, indeed, if with the hand for a little the blind simulating an obstacle, the consumption goes up.
 With this, it is easy to create an event in Blockly with the following function:
 If "blind X consumption" < "normal consumption"
 Set: "blind X" = "stop"
The event works correctly, but the problem is that currently the STOP command does not work in domoticz, at least with the FGRM-222.
 Can someone confirm that it is a general fault or does it just happen to me? Any solution?
roblom
Re: Avoid broken blinds / Bind stop
Post by roblom »
Is it correct that the stop function still doesn't work in Domoticz?
