Someone tried to connect air conditioners with WiFi module AEH-W4A1 (Hisense, Ballu, etc)
Looking for any information
- Spoiler: show
I also had this happen a couple of times, once it was enough to turn off the power to the air conditioner for a couple of hours, the second time I had to connect it to WiFi againzabinskiwojciech wrote: Wednesday 03 June 2020 7:12 However, we have to wait with the tests, I started checking and it turned out that for two months I stopped pinging the air conditioner. I need to check what happened, the air conditioner works, I restarted it but still doesn't respond to pings ...
maybe you know how to disable such logs in plugins because I have two more plugins and they are banging with errors but they work.2021-01-09 00:48:41.956 Error: (Klima) AC (192.168.1.131) unavailable
Original app HiSmart Life is working, I can ping AC, it is in the same subnet.2021-01-28 15:52:35.384 Error: (K1) AC (192.168.100.251) unavailable
also I did chmod +x on plugin.py and several times restarted domoticz.2021-01-28 15:55:27.269 (K1) Pushing 'onHeartbeatCallback' on to queue
2021-01-28 15:55:27.288 (K1) Processing 'onHeartbeatCallback' message
2021-01-28 15:55:27.289 (K1) Calling message handler 'onHeartbeat'.
2021-01-28 15:55:27.289 (K1) onHeartbeat called
2021-01-28 15:55:27.289 (K1) Poll unit
2021-01-28 15:55:27.387 Error: (K1) AC (192.168.100.251) unavailable
