I am trying to add some BOFU EY25 roller blinds to Domoticz using the RFXcom RFXtrx433E. I have loaded the Type2 firmware, and captured the button presses:
26/08/2018 01:06:57:860
Packettype = BLINDS1
subtype = Safy / RollerTrol / Hasta new
Sequence nbr = 0
id2-3 = xxxx decimal:ddddd
Unit = 1
Command = Open
Signal level = 7 -64dBm
26/08/2018 01:06:59:609
Sequence nbr = 1
Unit = 1
Command = Stop
26/08/2018 01:07:02:577
Sequence nbr = 2
Unit = 1
Command = Close
26/08/2018 01:07:04:230
Sequence nbr = 3
Unit = 1
Command = Stop
Signal level = 7 -64dBmI presume I should go to Switches->Manual Light/Switch and in the pop-up, select
Hardware: RFXtrx433
Switch type: Blinds
but in the Type: drop down, I see Blinds T5 Media Mount ... Blinds T13 Screenline, but not anything I recognize for my Bofu (Safy/RollerTrol/Hasta).
I expect this is a newbie mistake. What am I missing??
Thanks,
Jonathan.
