globalassist
You are so right! Thanks, I forgot to give access to the "new" devices.
viriathus
I'm currently also getting the dreaded "Couldn't update the setting. Check your connection" message in Google Home Assistant when trying to link Controlicz with my Google Home.
From a Controlicz point of view, it seems to be all working ok... I have setup an account with access to my Domoticz system and it has successfully synced the devices I added to Roomplans, etc. Testing the connection from Controlicz also works as expected: "Success - your connection is working".
In Google Home assistant, like some of the people on this forum, I get as far as allowing Google in Controlicz, but I keep getting the "Couldn't update the setting. Check your connection" error message. I already tried it several times even with different login names, and nothing...
Any suggestions on what could be wrong? How do I fix this issue?
Thank you.
Thank you.
- heggink
- Domoticz version: 12451
Hey Nick,
Quick question: ever since google assistant was released supporting Dutch language, I switched to see if I can (finally) use Dutch for controlling devices (kind of weird to continue to speak English to my home automation in a Dutch house
In the mean time, I also switched phones to a galaxy S8+. Bizarrely, I cannot see any home control on my phone (despite disabling bixby altogether) but when I type English (despite the dutch settings) in the google assistant app, it will let me control the devices in my house. It won't accept any dutch language. Does that mean that your 'skill' is not enabled for Dutch? Any other hint?
H
H
P1 meter & solar panel
aure53
- Domoticz version: 4.97
I have a problem with controlicz/GH. I've in each room a temp sensor and a thermostat ( a virtual setpoint in domoticz) to control room temp. Each of this two appers as it in controlicz but with GH i cannot have the two working properly (reading temp sensor value when i ask for temperature and change the setpoint value when i ask for it).
-if i put temp sensor only in the room for reading:OK for changing: it changes (or try it in fact) the temp sensor value
-if i put setpoint only in the room for reading: it reads the setpoint value and for changing it: OK
-if i put de two for reading: it says that it connot determine the sensor and for changing it: it changes the value for the two (so it's working but it's not clean)
PS: i'm french so the room names are french and GH is used in french language.
PS2: i've search in both forum english and french and unfortunatly found nothing to solve my problem.
PS3: i try to change the names (in GH or in domoticz sensor description "controliz:thermostat du salon") of the temp sensor an set point to point it directly it changes nothing, maybe i dont use th good words?
Thank you.
Thank you.
- gijsje
- Domoticz version: Stable
As far as is know you can only use the dutch assistant for searching the web.heggink wrote: Tuesday 21 August 2018 9:25 Hey Nick,
Quick question: ever since google assistant was released supporting Dutch language, I switched to see if I can (finally) use Dutch for controlling devices (kind of weird to continue to speak English to my home automation in a Dutch house).
H
You can not use any home control yet and they think it will come before Sinterklaas
https://youtu.be/SWx1R5SRiuY?t=1m1s
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
Madgeni
Hi - if you mail me from your Controlicz profile, i'll take a look. I assume you have a subscription?viriathus wrote: Tuesday 21 August 2018 0:19 Hello,
Thank you.
Madgeni
Hi, it does sound like Google is getting confused - you could, to avoid any doubt (purely for testing), change the name of the sensor to something completely different (like 'Test') and see if it understands? Another factor is that Google still doesn't have simply a 'sensor' yet, so it's possible it's misunderstanding which you want to query. Sensors are coming soon (i've got the documentation and the code is complete, but it's not released by Google yet).aure53 wrote: Wednesday 22 August 2018 22:52 Hello,
Thank you.
- heggink
Actually, it does work and I can control my devices reasonably well with the google assistant ("ok google stel de helderheid van dinner table in op 30%" funny enough works) but there is no home control to be found anywhere.gijsje wrote:As far as is know you can only use the dutch assistant for searching the web.heggink wrote: Tuesday 21 August 2018 9:25 Hey Nick,
H
Madgeni
Yep, its a real pain! Controlicz is "available" in: Danish, Dutch, English, French, German, Italian, Norwegian, Portuguese, and Swedish (those are the languages Google allowed me to certify). However, that doesn't mean it's actually available to you, not entirely sure why. Will try and get some dates
Hi Madgeni,
I think you inverted the blind domoticz command again.
When I issue a "switch on the X blind" google command, an Off command is sent to domoticz :
2018-08-23 21:22:20.100 Status: User: Controlicz initiated a switch command (36/Volet Cuisine/Off)
Furiousz23
- Domoticz version: 4.10199
What i really would like to see in Controlicz.....: Hey Google, whats the generated energy today? Answer: the solar production of today is 20kWh
DarkG
- Domoticz version: 4.10076
is it possible to use it with ipv6?
RPi4 Shelly1 Shelly2.5 ESPEasy Tuya Domoticz Beta Dashticz 3.6
Madgeni
do you mean your network is using ipv6?
DarkG
My Internet is IPV6. I have DS Lite. Internal´in Network at home I use IPV4
DarkG
omg nearly i killed my shutter motor.
I have one lamp and 2 outputs für direction shutter in room plan.
When I say in german google switch livingroom light on he turn all 3 switches on. The motor from the shutter sounds great with 2 directions in same time
Madgeni
That doesn't sound good - in your Controlicz profile, is your shutter seen as a Blind, or a Light? Mail me from your Controlicz profile, and i'll take a look at this.
Madgeni
You can use something like https://dynv6.com as a DNS service
Masure wrote: Thursday 23 August 2018 21:25 Hi Madgeni,
When I issue a "switch on the X blind" google command, an Off command is sent to domoticz :2018-08-23 21:22:20.100 Status: User: Controlicz initiated a switch command (36/Volet Cuisine/Off)
Sorry for bumping this but it's broken again.
Madgeni
It's broken again? As in, it was working, and has now stopped, or it's been like this for about a week? Can you mail me, and i'll fix itMasure wrote: Monday 27 August 2018 18:59Masure wrote: Thursday 23 August 2018 21:25 Hi Madgeni,
It has broken again a few days before my post 08-23. It's the 2nd time it broke if I remember correctly.
