Alexa, Google Home and Siri
matzeb74
Domoticz version: newest
Post by matzeb74 »
Hello
I´ve changed nothing on my connection, but if i hit Test Connection i get:
"Check you're using HTTPS"
So where is the Problem?
Madgeni
Post by Madgeni »
sstolk wrote: Friday 10 August 2018 8:14 I would like to protect my Domoticz from the outside world and opening the HTTPS port sounds good but not for me.
Can you provide me from where Controlicz is coming eg. IP's?
The load balancer is 35.176.67.167
Madgeni
Post by Madgeni »
matzeb74 wrote: Friday 10 August 2018 17:50 Hello
I can do one better - my laptop is currently 1200 miles from me. I've changed nothing :)
Brutus
Post by Brutus »
@Madgeni,
Why is Dutch Controlicz not working? We can't link it in the Google Assistant as mentioned before. I Would like to use it.
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
Madgeni
Post by Madgeni »
Hi, it’s with google, I think they’ve broken home controls in the app
Furiousz23
Domoticz version: 4.10199
Post by Furiousz23 »
I'm experiencing problems with the payment, both options (PayPal and card) doesn't work :( .
Update 12-08-2018
Still no way to make a payment :? . The site doesn't respond after clicking "subscribe".
Brutus
Post by Brutus »
Madgeni wrote: Saturday 11 August 2018 9:16 Hi, it’s with google, I think they’ve broken home controls in the app
Ok, thanks for the update.
28x Fibaro Modules
SMA Solar System
Furiousz23
After deleting my old account and creating a new one i was able to make the payment. I guess there was something wrong in the old one. Now i`ve added Controlicz to GA and added my devices :mrgreen: .
Now i have to figure out what commands i have to use. When i say: Hey Google, put the lights on, all lights go on but also my doorbell starts ringing :shock: .
Unfortunatly Controlicz is not available in Dutch right now...
bramski
Post by bramski »
I have both an echo dot and an Google home mini setup in my living room. Previously I was using the Alexa with Controllicz but wanted to compare both devices to see which one suits my needs.
Upgraded my free account to a paid subscription and Controllicz was a breeze to set up for both devices.
I did some testing by turning lights on, setting colors, dimming lights etc. With Alexa this works almost instant (within 1 second) and almost 100% of the time, however with the Google mini there is a very noticable delay (5 seconds or more). Also very frequently google tells me the lights have been changes, but nothing happens. Does anyone have similar issues with the Google device or is there something I can check?
alanlsmith
Domoticz version: Latest β
Post by alanlsmith »
I have a couple of Dots and a few Google Homes, all seem to respond in a similar (almost instantaneous) time. The Dots sometimes 'wake up' when they think (incorrectly) that the key word has been spoken and a couple of times one of the Google Homes has mistakenly tried to switch off (or on) all the devices, which was a bit of a laugh. There is a Google Home Mini in the kitchen which often responds, even though it is not the nearest to the person speaking, it then seems to get confused and says 'Something has gone wrong.' I think this could be because it is a long way from the wireless hub.
Generally though, they all respond in a timely and accurate fashion.
PS: The reason I have both is that I use the Dots (which I had first before Google Home was available in the UK) for Amazon Music, which I play through the Google Homes (better speakers). The Google Homes are the main 'smart home' communicators.
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
Madgeni
Post by Madgeni »
There is definitely some latency between asking and that request hitting controlicz, which is frustrating. But I'd put it at around 1 second. I'm hoping google will address it with a sw update
JonyBCN
Post by JonyBCN »
I have updated my account to the paid version and somehow it appears as free. When I try to pay again I receive the following error:
Error: Failed to lookup view "error" in views directory "/opt/bitnami/apps/Controlicz/views"
at EventEmitter.render (/opt/bitnami/apps/Controlicz/node_modules/express/lib/application.js:580:17)
at ServerResponse.render (/opt/bitnami/apps/Controlicz/node_modules/express/lib/response.js:1008:7)
at Object.html (/opt/bitnami/apps/Controlicz/middleware/error.js:24:13)
at ServerResponse.res.format (/opt/bitnami/apps/Controlicz/node_modules/express/lib/response.js:671:13)
at development (/opt/bitnami/apps/Controlicz/middleware/error.js:19:9)
at Layer.handle_error (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/layer.js:71:5)
at trim_prefix (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:315:13)
at /opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:284:7
at Function.process_params (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:335:12)
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:275:10)
at notFound (/opt/bitnami/apps/Controlicz/middleware/error.js:9:5)
at Layer.handle [as handle_request] (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/layer.js:95:5)
at trim_prefix (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:317:13)
Madgeni
Post by Madgeni »
JonyBCN wrote: Thursday 16 August 2018 20:22 I have updated my account to the paid version and somehow it appears as free. When I try to pay again I receive the following error:
Can you mail me from your controlicz profile?
Did you receive a receipt?
Am home tomorrow, will look at it asap.
Masure
Post by Masure »
Hi Madgeni,
It seems you changed the blinds command effect.
If I say
Switch On the blind
Domoticz log indicates :
2018-08-17 14:30:38.601 Status: User: Controlicz initiated a switch command (38/Volet Salon/Off)
I know you are waiting for Google to implement blinds properly, but receinving OFF command when you say ON is a bit cumbersome.
Madgeni
Post by Madgeni »
Just walked in the door from hols, will fix this as priority this weekend. I need to handle the "inverted" blind scenario better
Madgeni
Post by Madgeni »
Masure wrote: Friday 17 August 2018 14:36 Hi Madgeni,
If I say
Switch On the blind
Hi - can you 'sync my devices' - and re-test? Thanks
Masure
Post by Masure »
It's ok now. I did not have to sync the devices though. Why do you mean by "syncing devices" ?
globalassist
Post by globalassist »
Is there a limit to the number of devices supported?
I only see 7 devices in my "devices" and not all are usefull.
How can I select the devices that Alexa can manage?
Thanks in advance!
Jem101
Post by Jem101 »
There may well be a limit but I suspect it's a high one, I have dozens of devices controlled via Controlicz, admittedly I use the Amazon Alexa platform but I assume the Google one would be basically the same.
There are basically two things you need to do
Firstly, Controlicz will only see devices which are in a room plan, it doesn't matter which plan it is and you don't have to make a specific one for Controlic, as long as the device is in at least one room plan then you are good to go.
The second thing (and this has caught me out once or twice), best practice is to create a user account in Domoticz for Controlicz to use to go in with, so you might create a user called Controlicz_Access with a password, and that is the combination you would put into the Controlicz portal page. But you have to make sure that this user account can access the devices you want - so in the account setup page in Domoticz (Setup / More Options / Edit Users), alongside each account is a button called 'Set Devices'. Click that and make sure that all the devices you want Controllicz to access are in the right-hand column.
Do all that and then you should be able to add devices.
I firmly believe in having an open mind - although not so open that your brain falls out!
- sometimes attributed to Carl Sagan, but the original quote is much older than that
Madgeni
Post by Madgeni »
What he said :) Upper limit with Google *was* 120 devices, but think that's been raised again
