converting LUA to dzvents
multinet
Post by multinet »
Hello i'm considering converting my lua scripts to dzvents
but I don't know how this lua command should be converted :
        val_QPluieV=os.capture('sqlite3 '..dbPath..' "select TOTAL as TOTAL from Rain_Calendar where devicerowid='..otherdevices_idx[dev_Pluviometre]..' and Date = date(\'now\', \'-1 day\')"')
This is to open the domoticz database and to execute an SQL request
Thanks !
Multinet
PI 2 - Domoticz 2021.1
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver (5 DIO 54755 + 2 DIO 54756 + 3 DIO 54798)
Z-Wave.Me ZME_UZB1 USB Stick (6 FGSD002 + 2 FGRM222 + 1 FGS223 + 1 FGMS001-ZW5 + 1 FGRGBWM441 + 1 FGBS001 + 2 FGFS101)
6 sondes DS18B20
multinet
Re: converting LUA to dzvents
Post by multinet »
Re,
My question is about os.capture more precisely
6 sondes DS18B20
multinet wrote: Saturday 18 August 2018 11:29 Hello i'm considering converting my lua scripts to dzvents
Thanks !
Multinet
The os.capture does not really need to be converted. It is not a standard lua function but more a wrapper around io.popen
somewhere in your current code the function must be defined like something as
    function os.capture(cmd, raw)
          local f = assert(io.popen(cmd, 'r'))
          local s = assert(f:read('*a'))
          f:close()
          if raw then return s end
          s = string.gsub(s, '^%s+', '')
          s = string.gsub(s, '%s+$', '')
          s = string.gsub(s, '[\n\r]+', ' ')
          return s
you can just use it in dzVents as you use it now in lua (dzVents IS Lua)
The part that need to be converted to dzVents syntax is
That need to change to
domoticz.devices(dev_Pluviometre).idx
