SSL certificate should be purchased for domoticz.com
leecollings
Post by leecollings »
Hi guys,
I've just noticed that the forum (and the entire domoticz.com domain) doesn't have an active SSL certificate applied.
Can this be done at all, is there any reason why not? A Wildcard SSL would be ideal as you would then be able to use it for my.domoticz.com (which would definitely need an SSL).
Anyway we can help at all?
Egregius
Domoticz version: v2024.7
Re: SSL certificate should be purchased for domoticz.com
Post by Egregius »
On the forum there's a letsencrypt certificat installed, only the redirection from http to https isn't done.
People should always use https://www.domoticz.com/forum instead of the plain text http url.
And the administrators should place a redirect from http to https.
leecollings
Hmm, yeah I see that now, that the domain is accessible via https, but you are correct, a redirect should definitely be put in place, this is going to flag up on many SEO audit tools.
leecollings
Hey, admins, the redirection to https://www still isn't happening, I naturally enter domoticz.com/forum to access this site, which loads up the non-www and non-https version.
Is this redirection set up on the cards at all?
Users browsing this forum: Patricen and 1 guest
