EdddieN
Domoticz version: 4.9700
Re: machinon theme - (work in progress)
Post by EdddieN »
Brutus wrote: Saturday 04 August 2018 14:42 Hi Edddie and other contributors,
This theme is very nice! The colors icons everything.
Greetings.
I think your system still caching, see below, the tiles should be a bit bigger (vertical).
The 4 tiles hasn't been done, I think a few people are on holidays right now (including me :D )
Have you tried different browser in incognito mode?
Screen Shot 2018-08-04 at 19.50.16.png (269.44 KiB) Viewed 2785 times
11101101 - www.machinon.com
EdddieN
Post by EdddieN »
blauwebuis wrote: Saturday 04 August 2018 15:51 Red text will give you problems if you want to create a dark version of the theme later (and you may want to, because it's better for your eyes at night, and doesn't scream for attention if you use it on a wall tablet).
Yes, there's plan for a dark one, this is the original idea: http://www.domoticz.com/forum/viewtopic ... 60#p187090
I'm no developer so I leave it up to @landaisbenj and @DewGew to decide, they have been quite involved and making the theme possible. I'm just the designer. If you know a bit of coding, please feel free to have a go, we are all learning here :)
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
I have a script running that update a TEXT device. The text is lot of info. In the Default theme the div will change in size so the text will be always inside the device content.
Will you update this also in Machinon Theme?
landaisbenj
Domoticz version: stable
Post by landaisbenj »
Yes. Maybe with automatic overflow ?? We must open issue.
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
landaisbenj
doxikus wrote: Thursday 19 July 2018 22:58 Hi All,
Great theme, finally something nice to eye and easy to use on dashboard. Great thanks for this. Ok, now back to a reality .-). I have forked git repo, now I can see first problem here, there was some changes inside custom.css file. This is a problem, because there is inside css folder ,scss files, now this is very common setup, problem is if I use and change something inside .scss file it will generate new custom.css file and override all changes. Thing is if you want to update css do that inside .scss file and generate custom.css file :-).
As a workaround, if you are not sure what to do include another css file where will be all new changes, or at least document changes that is made so we can update .scss file accordingly.
For feature dev it will be nice to have all changes inside scss files :-).
If you need some help about this, PM me or ask here.
does domoticz compile .scss by itself?
Platforme: Rpbi3b
landaisbenj
Ok i learn css préprossessor
I think we don't need .scss file. Here we are not really coder so just 1 file must be more easy to use...
Maybe in futur, code can be organize with scss file, but not now.
Now i have some base i try to clean folder of machinon, to create more facilities to css code, but with just one file.
Platforme: Rpbi3b
EdddieN
Post by EdddieN »
couple of things I noticed a few times.
1) Can we get rid of this? sometimes in some devices it gets in the way too much: It occupies valuable screen space for (in my opinion) nothing. I think since there's already the "About" menu, there's no need to have a footer for it. In my opinion it does not bring value to the user to have that there. If it must... then I would make it very small but would prefer it it was out. I personally have no interest on seen my name there :D
2) Logo / text, it would be nice if that could be customize by the user, not really critical.
3) The log out, etc menu on mobile devices appears a bit out of place.
Ed
DewGew
Domoticz version: V4.10618
Post by DewGew »
landaisbenj wrote: Monday 06 August 2018 11:52 Yes. Maybe with automatic overflow ?? We must open issue.
On the dashboard its working already, maybe the solution is there already?
EdddieN
Post by EdddieN »
I think we are getting close to more or less glitch-free version. :)
Great work guys! Really like the possibility to switch to dark theme and the 2 settings menu option. I'll try to update the a draft of the dark theme soon...
EdddieN
Post by EdddieN »
What do you think for dark theme? I think still needs a bit more wow effect, but it is a start
HansieNL
Post by HansieNL »
I like this layout, but dislike one thing about it.
The white dot of the switch should not be white for me. Now I think it's to bright for a dark theme. Maybe you can give it a dark grey color like the disabled icon?
Blah blah blah
Oktopus
Post by Oktopus »
Is there a reason why a text device doesn't show the log command?
Never mind... just found a bug (#17) on github
EdddieN
Post by EdddieN »
HansieNL wrote:I like this layout, but dislike one thing about it.
Excellent point! Will work on that
DewGew
Post by DewGew »
Looks great. Will be much better Than my inverted. 😀
treshed
Post by treshed »
I Have the same problem, big tiles are not showing. I tried in incogniot modus and in a new browser install, but still no big tiles.
Is there anything I need to change in the config to get this working? I love the theme, but I keep going back to the stock themes because of this.
I uploaded the content from Github to my "Domoticz\www\styles\machinon" folder and copy'd the settings file to "\Domoticz\www\templates"
After that I deleted the cache from firefox and loaded the new theme. It looks great but I don't have the big tiles in my dashboard and Switches tab? Is this still in progress or is something wrong at my end?
Example from Topic start:
Greetings.
treshed
Post by treshed »
And when I go to settings I get the following screen, saying domoticz is offline, but its really not:
ayasystems
Post by ayasystems »
treshed wrote: Monday 27 August 2018 13:05 And when I go to settings I get the following screen, saying domoticz is offline, but its really not:
I have the same problem. I can not back to standard theme.
treshed
Post by treshed »
I was able to go back to standard theme by renaming the machinon directory in domoticz/www/styles. After a restart of domoticz it comes up with the standard theme.
ayasystems wrote: Monday 27 August 2018 14:56
DewGew
Post by DewGew »
treshed wrote: Monday 27 August 2018 15:18 I was able to go back to standard theme by renaming the machinon directory in domoticz/www/styles. After a restart of domoticz it comes up with the standard theme.
Did you copy the Settings.html to www/templates/ ?
EdddieN
Post by EdddieN »
How is this for updated dark screen?
and also updated the about screen to match a bit with the rest:
