dzVents temperature switch
Remicade
Domoticz version: 4.10717
Post by Remicade »
Hi Forum,
After a lot of reading and trying still strugling to get this dzVents script working.
I use the Omnik script to read the temperature.
This is a Custom Device.
The fan should cool the inverterabove 25 degrees Celcius.
Can somebody please give me a suggestion why the script is faulty?
timer = 'every minute'
execute = function(domoticz)
local Sensor = domoticz.devices( 'Omnik temperature' )
if (Sensor.temperature) >= 25) then
domoticz.devices( 'Omnik Ventilator' ).switchOn()
btw what tochoose by
event name,
dzVents,
Thanks Paul
dannybloe
Re: dzVents temperature switch
Post by dannybloe »
Try to remove all the ( and ) in your if-statement.
And next time post the errors you get. That helps 😀
EdwinK
Post by EdwinK »
Can you please use the [ code ] and [ /code ] blocks. It will make everything easier to read
Thanks.
Remicade
Post by Remicade »
Hi and thanks for your support.
I will try to make it more readable...... :oops:
Now changed the script as suggested :
      local Sensor = domoticz.devices('Omnik temperature')
      if Sensor.temperature >= 25 then
         domoticz.devices('Omnik Ventilator').switchOn()
Can it be the problem with the Custom Sensor?
Or the fact that "spacebar" is used between Omnik temperature?
Thanks again!
Paul
Remicade wrote: Thursday 02 August 2018 20:16 I will try to make it more readable...... :oops:
Thanks again!
Paul
Problem is that you forgot a pair of {}
Please find corrected script below.
   on = {       timer = { 'every minute'  } },
Remicade
Post by Remicade »
Thanks waaren,
If you three guys think that the script is o.k. but it is still not working....Could it be that my devices are not correct?
I had a typo in the previous script but that seems o.k. now.
Now will try to debug, after finding out how exactly.
Paul
EdwinK
Post by EdwinK »
Sounds so easy :) Was trying to get something like this for a few weeks. Now I've two of these scripts running for the two ventilators I've got, but could those also be combined in one script?
EdwinK
Post by EdwinK »
Remicade wrote: Thursday 02 August 2018 20:56 Thanks waaren,
Paul
I have my fan's as on/off switch and the temperature is coming from two temperature devices, not custom sensors.
Paul
What about looking at the log in the GUI ? [SETUP][LOG][ALL] do you see anything there on every minute :00 ?
Remicade
Post by Remicade »
Hi EdwinK,
That did the trick.
Made a new device, but now Type Temp.
In the Omnik changed IDX.
The script is now running and switching my OmnikVentilator.
Thanks for the help!
Paul
EdwinK
Post by EdwinK »
i thought this would be working, as the fan in the living room doesn't have to be on at night.
   on = {       timer = { 'every minute at daytime'  } },
      local Sensor = domoticz.devices('HSKTemp')
      if Sensor.temperature >= 20 then
         domoticz.devices('FAN Huiskamer').switchOn()
Same would be for the bedroom fan; but then during night-time. But unfortunately, this doesn't seem to work.
Users browsing this forum: jjnh and 1 guest
